I have a TV in my Hungarian house. Sometimes I would like to watch movies /streams from Austrian or Germańs treams. Therefore I have two different VPNs to my Austrian LAN and to a German Proxy.
With these constellation I can look streams on my Laptop, Tablett or Smartphone.
But it is not possible to forward those streams on FireTV Stick or Google Chromcast (to use my TV for watching) I guess because these both only „tell“ the stick where to stream from…. But not how to use the VPN. Therefore no streams can be initiated via casting.
Is there a possibility to use my DietPi, which is in the same network ?
Thanks
Karl
Not until now. Because for Germany I only use a simple Squid-Proxy which is locted in Germany. For that the WireGuard App does not make much sense.
I also mentioned that I have influence to the network settings on my TV natively. Perhaps I can use my laptop as gateway???
But here my network skills are too weak.
BR
Karl
As stated above, I don’t think this best idea to use the Proxy.
Actually, DietPi has no built-in option to use a proxy server on network level. That’s something you would need to do manually. I found a couple of guides on the web describing hot to configure Debian to use a proxy on network level. But I did not test them. Not sure how accurate they are.
