Wake On LAN (WoL) - HP T620 + DietPi - how to enable it permanently on interface?
I’m trying to enable Wake On LAN on my PC HP T620 where I have installed DietPi. I enabled it in BIOS and I know it is working - WoL works when Windows 10 is installed.
I can see that WoL feature is available on interface, but it is disabled:
ot@DietPi:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP    MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Auto-negotiation: on
        master-slave cfg: preferred slave
        master-slave status: slave
        Port: Twisted Pair
        PHYAD: 0
        Transceiver: external
        MDI-X: Unknown
        Supports Wake-on: pumbg
        Wake-on: d           <--------------------------------- SUPPORTED, DISABLED
        Link detected: yes
I can change it manually:
root@DietPi:~# ethtool -s eth0 wol g
root@DietPi:~# ethtool eth0
Settings for eth0:
                                1000baseT/Full
                                1000baseT/Full
                                             1000baseT/Full
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 0
        MDI-X: Unknown
        Wake-on: g           <--------------------------------- ENABLED
        Link detected: yes
But after restart, it comes back do default value where it is dsiabled:
Settings for eth0:
                                1000baseT/Full
                                1000baseT/Full
                                             1000baseT/Full
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 0
        MDI-X: Unknown
        Wake-on: d           <--------------------------------- DISABLED AGAIN
        Link detected: yes
Is there any script that changes this setting to disabled before system is restarted / shut down?
How to make this change permanent?
I tried to follow steps from here Wake-on-LAN - ArchWiki but it didn’t work for me…
Cheers,
Przemek
dietpi is based on debian and uses ifupdown, so use debian wiki.
Thank you pulpe! I followed the instructions:
Add an interface config file /etc/network/interfaces.d/eth0 :
auto eth0
iface eth0 inet dhcp
ethernet-wol g
Activate it:
sudo reboot
And WoL started to work :slight_smile:
Cheers,
Przemek
eth0 interface should be defined within /etc/network/interfaces already. Hope it is not causing any conflict now.
As of now it is working fine and I don’t see any issues - DHCP is working, WoL is working :slight_smile:
