I have tried to mount a folder that is on another machine with Ubuntu NFS server through Dietpi-drive_manager but I have not succeeded, looking for the share automatically, it was hung and ended up giving timed out error.
Then I tried to mount it manually with this line:
sudo mount -t nfs 192.168.1.42:/media/WD.Cloud/Backup/1 /mnt/nfs_client/Backup1
And if it has worked including it in Fstab. The line that I have included and that works is this:
192.168.1.42:/media/WD.Cloud/Backup/1 /mnt/nfs_client/Backup1 nfs rw,auto 0 0
In principle everything works correctly on two identical raspberry pi 4.
But when I run the backup, using dietpi-backup, it runs correctly but it took almost 5 hours. The speed between both machines is gigabit, tested with iperf, around 900mb/s.
Is this behaviour normal, can I improve it somehow?
As I understand the speed will improve in later backups because only the increments were used.
Thanks in advance ![]()
PD: this is the line in /etc/exports on the ubuntu server:
/media/WD.Cloud/Backup/1 *(rw,sync,no_root_squash,no_subtree_check)
PD: The speeds was around 350 kB/s
