After reading quite a lot I finally managed to install Diet Pi on my Orange Pi Zero.
I also followed the guide on Adguard Github page to install it on my board, and I successfully completed it. However, I noticed that my Diet Pi IP is the same as my Adguard home DNS IP that I’m now using on my devices to resolve domains and block ads.
Is there any way to setup a separate IP for Adguard Home (or Pi Hole for that matter) so that I have that specific separate IP for DNS ads blocking?
I saw on wundertech blog that there’s some way of doing that by installing Docker and running this command: sudo docker network create -d macvlan -o parent=eth0 --subnet=192.168.0.1/24 --gateway=192.168.0.1 --ip-range=192.168.0.50/32 my_network
In this case, 192.168.0.50 would be the IP of Adguard home that I could use.
I tried doing that before installing Adguard home but when I was presented with Adguard Home setup I didn’t get to choose that IP.
Sorry for the long post, hope it’s clear.
Thanks in advance!
Thank you for your answer. I´m not even sure. But I´m guessing if I need to install a webserver, maybe it´d be more “clean” to have my local Diet Pi IP as that webserver, and then another IP for Adguard Home or Pi Hole.
Maybe there´s no need at all, but I don´t know for sure.
Regards,
edit: As a matter of fact, I tried to install apache web server (I need this in order to install letsencrypt), but I got an error message saying my address (the local Diet PI IP) is already being used (by AdGuard Home). So I guess that would be the reason I would like to set up an additional interface for Adguard home.
Thanks again.
usually it’s not needed to have 2 IP address on a single network adapter. You could stay with DietPi standard and install PiHole from DietPi-Software catalogue. This will install a web server automatically. Using DietPi-Letsencrypt wil use that already installed web server to generate you certificates. On DietPi you are free to choose between 3 different web server (Lighttpd, Apache or Nginx). Your web server preference can be done inside DietPi-Software.
Currently I’m not using Adguard home as I’m more in favor of PiHole. Therefore I’m not sure if there is a config file to change Adguard’s own web server port to something like 8080. Would need to do a test.
Ohh okay, so by changing Adguard Home port from 80 to 8080 would solve my issue in this case? I can try and see where I can change that.
But if not I will switch to Pihole.
If you are going for 2 IP address on a single network adapter, you would need to manually configure both Adguard as well as Apache to LISTEN on a specific IP address only. By default both tools did not expect such a configuration and will LISTEN an all interfaces, which leads to the port conflict.
Yes, the first time for the install it runs on 3000, but after it´s configured, it´s 80.
Thanks again!
edit: Oh and last question since you mentioned Docker. As for CPU and RAM usage, which one is better? Running an application on Docker or via DietPi software?
