I’m trying to get Deluge to run as a server for a client on Windows, I can get the DietPi install to connect when I add user:password:10 to the end of the auth file, installing deluge-console and allowing remote access. But after reboot I have to restart deluged for the client to able to connect.
I’ve also tried this guide that installs Deluge.1.3.11 but I couldn’t get the boot script to work on DietPi. Although the cron script worked a few times.
How would I go about getting the DietPi to start deluge at boot but not have to restart deluged to connect a client? And could this be made into an install option or a dietpi-config option please?
Yes I went through the first run setup, but that doesn’t take either, have to restart dietpi-services to be able to login in with “raspberry”.
I’m assuming by conf file you mean the core.conf, but there’s two /root/.config/deluge/ or the one in /.config/deluge/? Also I’m using Deluge 1.3.11, not in classic mode, on Win7 as the client.
Hi
I installed Dietpi as I hoped to be able to get things set up simply after running into major problems setting up a torrent box with VPN on Raspian. However I am still having problems with Deluge on Diet pi.
I followed the instructions you posted and have tried to access deluge with Thinclient from my windows PC.
I managed to log in with 127.0.0.1 with admin and raspberry as you show in tutorial but that doesnt give me access to the USB drive where my folders reside. I did (somehow) manage to log in with my Pis IP address but now that fails and I can’t connect. What password should I be using and how can I get access via my pi s IP address please.
Edit: I tried accessing via the web client and that wont accept raspberry as login either so I cannot connect! I realise I just updated to version 88 from version 87. Could this have something to do with it?
Thanks , I know how to log in to the pi, It’s deluge I cant log in to despite following your instructions the logins arnt accepted. The web Gui for deluge says password not accepted.
Here is the bug report reference code : b827ebc714cd-0
Well googling this website:http://www.howtogeek.com/142044/how-to-turn-a-raspberry-pi-into-an-always-on-bittorrent-box/ and following that
I have managed to gain access to deluge via user:admin and pass:raspberry .
However I now still cannot connect to my USD HDD to save the files. Dietpi setup these folders on the USB HDD automatically so how /what do I need to do to get deluge to recognise themand use them for downloading?
Ideally, if you can, i would recommend writing a fresh DietPi image. I’ve just done this my end, everything works, and its automatically setup to use my external HDD.
Alternatively, you should be able to change the download location from the Deluge web interface:
