Local Call Transcriber — Raspberry Pi 5 / DietPi
This is the conservative, CPU-only Raspberry Pi 5 installer for the local call transcription and speaker-diarization pipeline.
It is deliberately separate from the universal Intel/AMD/GPU installer. The Pi version stays close to the configuration already proven on the Raspberry Pi 5.
Target
- Raspberry Pi 5
- 64-bit ARM (
aarch64) - DietPi / Debian-based Linux
- CPU-only Whisper.cpp
- Sherpa-ONNX 1.13.7
- Two-speaker diarization
The installer refuses to run unless it detects a Raspberry Pi 5 and aarch64.
Known-good diarization configuration
The installer uses the corrected Sherpa-ONNX configuration:
- segmentation model:
model.int8.onnx - embedding model: 3D-Speaker
...16k.onnx - CPU provider
- 4 threads
- 2 speaker clusters
- clustering threshold
0.5 min_duration_on=0.3min_duration_off=0.5
The segmentation and embedding provider/thread settings are applied to their respective model configurations, rather than to the top-level diarization configuration. Sherpa-ONNX’s official Python example structures offline diarization as separate segmentation, embedding and clustering configurations. citeturn0search0
Install
On the Pi:
bash install.sh
The script re-executes itself with sudo if necessary. It does not run apt-get update and does not install python3-pip; the Sherpa packages are installed inside a Python virtual environment.
At startup it shows the actual OS, architecture, kernel, hardware model and CPU thread count, then asks for confirmation.
Run
After installation:
transcribe
You will be asked:
Include speaker diarization? [Y/n]:
Press Enter/Y for Speaker 1/Speaker 2 diarization, or N for transcription only.
Processing behaviour
- Original recordings are never modified or deleted.
- Any directory named
optimizedis skipped, case-insensitively. - Existing completed
.txt+.jsonresults are skipped. - Intermediate files are stored under
.workso interrupted jobs can resume. - Per-file locks prevent duplicate concurrent processing.
- A failed recording does not stop the batch.
- Whisper segments are assigned to the diarization speaker with the greatest temporal overlap.
- A Whisper sentence is not split when the speaker changes inside it.
Installed paths
/opt/whisper.cpp
/opt/sherpa-onnx-env
/opt/sherpa-onnx-models
/opt/call-pipeline
/usr/local/bin/transcribe
/etc/call-pipeline.conf
GPU
GPU support is intentionally disabled in this Pi 5 package. NVIDIA/AMD GPU experimentation belongs in the separate universal Linux installer so it cannot disturb the known-good Pi deployment.
Models
The installer uses Whisper.cpp’s model download helper and the Sherpa-ONNX speaker-diarization models documented by the project. citeturn0search0turn0search2
Review applicable project/model licenses before redistributing the installer.
INSTALL SCRIPT.
#!/usr/bin/env bash
set -euo pipefail
APP_DIR=/opt/call-pipeline
WHISPER_DIR=/opt/whisper.cpp
WHISPER_MODEL=medium.en
SHERPA_ENV=/opt/sherpa-onnx-env
SHERPA_MODELS=/opt/sherpa-onnx-models
CONFIG=/etc/call-pipeline.conf
if [[ ${EUID} -ne 0 ]]; then
exec sudo -E bash "$0" "$@"
fi
ARCH=$(uname -m)
KERNEL=$(uname -r)
MODEL="Unknown hardware"
OS_NAME="Unknown Linux"
OS_ID=""
if [[ -r /etc/os-release ]]; then
# shellcheck disable=SC1091
. /etc/os-release
OS_NAME="${PRETTY_NAME:-${NAME:-Unknown Linux}}"
OS_ID="${ID:-}"
fi
if [[ -r /proc/device-tree/model ]]; then
MODEL=$(tr -d '0' < /proc/device-tree/model)
fi
IS_PI5=0
if [[ "$MODEL" == *"Raspberry Pi 5"* || "$KERNEL" == *"rpi-2712"* ]]; then
IS_PI5=1
fi
IS_DIETPI=0
if [[ "$OS_ID" == "dietpi" ||
-f /boot/dietpi/.version ||
-f /DietPi/dietpi/.version ]]; then
IS_DIETPI=1
fi
CPU_THREADS=$(nproc 2>/dev/null || echo 1)
if [[ "$ARCH" != "aarch64" ]]; then
echo "ERROR: This installer is for Raspberry Pi 5 64-bit ARM (aarch64)." >&2
echo "Detected architecture: $ARCH" >&2
exit 1
fi
if (( IS_PI5 == 0 )); then
echo "ERROR: Raspberry Pi 5 was not detected." >&2
echo "Detected hardware: $MODEL" >&2
echo "Detected kernel: $KERNEL" >&2
exit 1
fi
echo
echo 'Call Transcriber — Raspberry Pi 5 Installer'
echo '============================================'
echo
echo 'Detected system:'
echo " OS: $OS_NAME"
echo " Architecture: $ARCH"
echo " Kernel: $KERNEL"
echo " Hardware: $MODEL"
echo " CPU threads: $CPU_THREADS"
if (( IS_DIETPI )); then
echo ' Distribution: DietPi'
else
echo ' Distribution: Raspberry Pi 5 / non-DietPi Linux'
echo ' WARNING: DietPi was not detected.'
fi
echo
echo 'Installation:'
echo ' Whisper.cpp: medium.en'
echo ' Speaker diarization: Sherpa-ONNX 1.13.7'
echo ' Processing: CPU only'
echo ' GPU acceleration: disabled'
echo ' Original recordings: never modified'
echo
read -r -p 'Continue? [Y/n]: ' confirm
case "${confirm:-Y}" in
n|N|no|NO)
echo 'Installation cancelled.'
exit 0
esac
echo
export DEBIAN_FRONTEND=noninteractive
apt-get install -y \
ca-certificates \
curl \
ffmpeg \
g++ \
git \
make \
cmake \
python3 \
python3-venv \
python3-dev \
pkg-config
mkdir -p /opt
if [[ ! -d "$WHISPER_DIR/.git" ]]; then
git clone https://github.com/ggml-org/whisper.cpp.git "$WHISPER_DIR"
else
echo "Using existing $WHISPER_DIR"
fi
cmake \
-S "$WHISPER_DIR" \
-B "$WHISPER_DIR/build" \
-DCMAKE_BUILD_TYPE=Release
cmake \
--build "$WHISPER_DIR/build" \
--config Release \
-j"$CPU_THREADS"
WHISPER_BIN="$WHISPER_DIR/build/bin/whisper-cli"
test -x "$WHISPER_BIN"
mkdir -p "$WHISPER_DIR/models"
if [[ ! -f "$WHISPER_DIR/models/ggml-${WHISPER_MODEL}.bin" ]]; then
cd "$WHISPER_DIR"
bash ./models/download-ggml-model.sh "$WHISPER_MODEL"
fi
test -f "$WHISPER_DIR/models/ggml-${WHISPER_MODEL}.bin"
python3 -m venv "$SHERPA_ENV"
"$SHERPA_ENV/bin/pip" install --upgrade pip
"$SHERPA_ENV/bin/pip" install \
'sherpa-onnx==1.13.7' \
'numpy'
mkdir -p "$SHERPA_MODELS"
SEG_TARBALL=/tmp/sherpa-segmentation.tar.bz2
SEG_URL='https://github.com/k2-fsa/sherpa-onnx/releases/download/speaker-segmentation-models/sherpa-onnx-pyannote-segmentation-3-0.tar.bz2'
EMB_URL='https://github.com/k2-fsa/sherpa-onnx/releases/download/speaker-recongition-models/3dspeaker_speech_eres2net_base_sv_zh-cn_3dspeaker_16k.onnx'
if [[ ! -f "$SHERPA_MODELS/sherpa-onnx-pyannote-segmentation-3-0/model.int8.onnx" ]]; then
curl -fL --retry 3 -o "$SEG_TARBALL" "$SEG_URL"
tar -xjf "$SEG_TARBALL" -C "$SHERPA_MODELS"
fi
if [[ ! -f "$SHERPA_MODELS/3dspeaker_speech_eres2net_base_sv_zh-cn_3dspeaker_16k.onnx" ]]; then
curl \
-fL \
--retry 3 \
-o "$SHERPA_MODELS/3dspeaker_speech_eres2net_base_sv_zh-cn_3dspeaker_16k.onnx" \
"$EMB_URL"
fi
test -f "$SHERPA_MODELS/sherpa-onnx-pyannote-segmentation-3-0/model.int8.onnx"
test -f "$SHERPA_MODELS/3dspeaker_speech_eres2net_base_sv_zh-cn_3dspeaker_16k.onnx"
mkdir -p "$APP_DIR"
cat > "$APP_DIR/diarize.py" <<'PY'
#!/usr/bin/env python3
import json
import os
import sys
import wave
from pathlib import Path
import numpy as np
import sherpa_onnx
SEG = Path(
"/opt/sherpa-onnx-models/"
"sherpa-onnx-pyannote-segmentation-3-0/model.int8.onnx"
EMB = Path(
"3dspeaker_speech_eres2net_base_sv_zh-cn_3dspeaker_16k.onnx"
def read_wav(path):
with wave.open(str(path), "rb") as w:
rate = w.getframerate()
ch = w.getnchannels()
sw = w.getsampwidth()
n = w.getnframes()
if rate != 16000 or ch != 1 or sw != 2:
raise RuntimeError(
f"Expected mono 16-bit 16kHz WAV, "
f"got {rate}Hz {ch}ch {sw * 8}bit"
audio = (
np.frombuffer(w.readframes(n), dtype=np.int16)
.astype(np.float32)
/ 32768.0
return rate, audio
def main():
if len(sys.argv) != 3:
print(
f"Usage: {sys.argv[0]} INPUT.wav OUTPUT.json",
file=sys.stderr,
raise SystemExit(2)
src = Path(sys.argv[1])
out = Path(sys.argv[2])
rate, audio = read_wav(src)
print(f"Rate: {rate} Hz")
print(f"Duration: {len(audio) / rate:.2f}s")
seg_cfg = sherpa_onnx.OfflineSpeakerSegmentationModelConfig(
pyannote=sherpa_onnx.OfflineSpeakerSegmentationPyannoteModelConfig(
model=str(SEG),
num_threads=4,
provider="cpu",
emb_cfg = sherpa_onnx.SpeakerEmbeddingExtractorConfig(
model=str(EMB),
num_threads=4,
provider="cpu",
cluster_cfg = sherpa_onnx.FastClusteringConfig(
num_clusters=2,
threshold=0.5,
cfg = sherpa_onnx.OfflineSpeakerDiarizationConfig(
segmentation=seg_cfg,
embedding=emb_cfg,
clustering=cluster_cfg,
min_duration_on=0.3,
min_duration_off=0.5,
if not cfg.validate():
raise RuntimeError(
"Sherpa-ONNX diarization configuration is invalid"
print("Starting diarization...")
d = sherpa_onnx.OfflineSpeakerDiarization(cfg)
result = d.process(audio)
segments = []
for s in result.sort_by_start_time():
segments.append(
"start": float(s.start),
"end": float(s.end),
"duration": float(s.duration),
"speaker": int(s.speaker),
payload = {
"num_speakers": int(result.num_speakers),
"num_segments": int(result.num_segments),
"segments": segments,
out.parent.mkdir(parents=True, exist_ok=True)
out.write_text(
json.dumps(payload, indent=2),
encoding="utf-8",
print(f"Speakers: {result.num_speakers}")
print(f"Segments: {result.num_segments}")
print(f"Saved: {out}")
if __name__ == "__main__":
main()
PY
chmod 755 "$APP_DIR/diarize.py"
cat > "$APP_DIR/process_calls.py" <<'PY'
import argparse
import datetime
import fcntl
import json
import os
import subprocess
import sys
WHISPER = "/opt/whisper.cpp/build/bin/whisper-cli"
WHISPER_MODEL = "/opt/whisper.cpp/models/ggml-medium.en.bin"
DIARIZER = "/opt/call-pipeline/diarize.py"
PYTHON = "/opt/sherpa-onnx-env/bin/python3"
def now():
return datetime.datetime.now(datetime.timezone.utc).isoformat()
def atomic_json(path, data):
tmp = path.with_suffix(path.suffix + ".tmp")
tmp.write_text(
json.dumps(data, indent=2),
encoding="utf-8",
os.replace(tmp, path)
def load_json(p):
return json.loads(p.read_text(encoding="utf-8"))
def update_status(p, **kw):
d = load_json(p) if p.exists() else {}
d.update(kw)
atomic_json(p, d)
def discover(root):
for p in sorted(root.rglob("*")):
if (
p.is_file()
and p.suffix.lower() == ".wav"
and not any(
x.lower() == "optimized"
for x in p.relative_to(root).parts
yield p
def overlap(a, b, c, d):
return max(0.0, min(b, d) - max(a, c))
def run(cmd):
print("$ " + " ".join(map(str, cmd)))
subprocess.run(
[str(x) for x in cmd],
check=True,
def convert(src, dst):
dst.parent.mkdir(
parents=True,
exist_ok=True,
run(
"ffmpeg",
"-hide_banner",
"-loglevel",
"error",
"-y",
"-i",
src,
"-ac",
"1",
"-ar",
"16000",
"-sample_fmt",
"s16",
dst,
def whisper(audio, outbase):
run(
WHISPER,
"-m",
WHISPER_MODEL,
"-f",
audio,
"-oj",
"-of",
outbase,
"-l",
"en",
"-t",
str(os.cpu_count() or 1),
return Path(str(outbase) + ".json")
def merge(wj, dj):
dia = load_json(dj).get("segments", [])
out = []
for s in wj.get("transcription", []):
a = float(s["offsets"]["from"]) / 1000
b = float(s["offsets"]["to"]) / 1000
best = None
score = 0
for d in dia:
sc = overlap(
a,
b,
float(d["start"]),
float(d["end"]),
if sc > score:
score = sc
best = d["speaker"]
out.append(
"start": a,
"end": b,
"text": s.get("text", "").strip(),
"speaker": (
int(best) + 1
if best is not None
else None
return out
def whisper_only(wj):
return [
"start": float(s["offsets"]["from"]) / 1000,
"end": float(s["offsets"]["to"]) / 1000,
"speaker": None,
def ts(x):
ms = round(x * 1000)
h, ms = divmod(ms, 3600000)
m, ms = divmod(ms, 60000)
s, ms = divmod(ms, 1000)
return f"{h:02d}:{m:02d}:{s:02d}.{ms:03d}"
def write_txt(p, segs):
with p.open("w", encoding="utf-8") as f:
for s in segs:
label = (
f'Speaker {s["speaker"]} | '
if s.get("speaker")
else ""
f.write(
f'[{ts(s["start"])} - {ts(s["end"])}] '
f'{label}{s["text"]}\n'
def process(src, root, outroot, use_diarization):
rel = src.relative_to(root)
stem = rel.with_suffix("")
outdir = outroot / stem.parent
outdir.mkdir(
parents=True,
exist_ok=True,
txt = outdir / (stem.name + ".txt")
js = outdir / (stem.name + ".json")
if txt.exists() and js.exists():
print(f"SKIP complete: {src}")
return "skip"
work = outroot / ".work" / stem
work.mkdir(
parents=True,
exist_ok=True,
lockp = work / "process.lock"
status = work / "status.json"
with lockp.open("w") as lf:
try:
fcntl.flock(
lf,
fcntl.LOCK_EX | fcntl.LOCK_NB,
except BlockingIOError:
print(f"SKIP locked: {src}")
return "skip"
update_status(
status,
source=str(src),
started=now(),
stage="starting",
diarization=use_diarization,
try:
audio = work / "audio-16k-mono.wav"
wbase = work / "whisper"
wjson = work / "whisper.json"
djson = work / "diarization.json"
if not audio.exists():
update_status(
status,
stage="convert",
convert(src, audio)
if not wjson.exists():
update_status(
status,
stage="whisper",
whisper(audio, wbase)
wj = load_json(wjson)
if use_diarization:
if not djson.exists():
update_status(
status,
stage="diarization",
run(
PYTHON,
DIARIZER,
audio,
djson,
segs = merge(wj, djson)
dmeta = load_json(djson)
else:
segs = whisper_only(wj)
dmeta = None
update_status(
status,
stage="writing",
write_txt(txt, segs)
payload = {
"source": str(src),
"duration_seconds": (
segs[-1]["end"]
if segs
else 0
"diarization": dmeta,
"segments": segs,
atomic_json(js, payload)
update_status(
status,
stage="complete",
finished=now(),
print(f"DONE: {src}")
return "done"
except Exception as e:
update_status(
status,
stage="error",
error=str(e),
finished=now(),
print(
f"ERROR: {src}: {e}",
file=sys.stderr,
return "error"
def main():
ap = argparse.ArgumentParser()
ap.add_argument(
"--source-root",
required=True,
ap.add_argument(
"--output-root",
required=True,
ap.add_argument(
"--no-diarization",
action="store_true",
args = ap.parse_args()
root = (
Path(args.source_root)
.expanduser()
.resolve()
out = (
Path(args.output_root)
.expanduser()
.resolve()
root.mkdir(
parents=True,
exist_ok=True,
out.mkdir(
parents=True,
exist_ok=True,
counts = {
"done": 0,
"skip": 0,
"error": 0,
files = list(discover(root))
print(f"Found {len(files)} WAV file(s)")
for p in files:
counts[
process(
p,
root,
out,
not args.no_diarization,
] += 1
print(
f"Finished: {counts['done']} done, "
f"{counts['skip']} skipped, "
f"{counts['error']} errors"
main()
PY
chmod 755 "$APP_DIR/process_calls.py"
cat > "$APP_DIR/run-calls.sh" <<'EOF'
#!/usr/bin/env bash
set -euo pipefail
source /etc/call-pipeline.conf
args=(
--source-root "$SOURCE_ROOT"
--output-root "$OUTPUT_ROOT"
if [[ "${1:-}" == "--no-diarization" ]]; then
args+=(--no-diarization)
fi
exec \
/opt/sherpa-onnx-env/bin/python3 \
/opt/call-pipeline/process_calls.py \
"${args[@]}"
EOF
chmod 755 "$APP_DIR/run-calls.sh"
ORIGINAL_USER=${SUDO_USER:-}
if [[ -z "$ORIGINAL_USER" || "$ORIGINAL_USER" == root ]]; then
DEFAULT_SOURCE=/mnt/calls
else
DEFAULT_SOURCE=/home/$ORIGINAL_USER/calls
fi
read -r -p \
"Source recordings directory [$DEFAULT_SOURCE]: " \
SOURCE_ROOT
SOURCE_ROOT=${SOURCE_ROOT:-$DEFAULT_SOURCE}
read -r -p \
"Transcript output directory [/mnt/call-transcripts]: " \
OUTPUT_ROOT
OUTPUT_ROOT=${OUTPUT_ROOT:-/mnt/call-transcripts}
mkdir -p "$SOURCE_ROOT" "$OUTPUT_ROOT"
cat > "$CONFIG" <<EOF2
SOURCE_ROOT=$(printf '%q' "$SOURCE_ROOT")
OUTPUT_ROOT=$(printf '%q' "$OUTPUT_ROOT")
EOF2
cat > /usr/local/bin/transcribe <<'EOF2'
#!/usr/bin/env bash
set -euo pipefail
read -r -p \
"Include speaker diarization? [Y/n]: " \
answer
case "${answer:-Y}" in
n|N|no|NO)
exec /opt/call-pipeline/run-calls.sh --no-diarization
esac
EOF2
chmod 755 /usr/local/bin/transcribe
"$SHERPA_ENV/bin/python3" - <<'PY2'
import sherpa_onnx
import numpy
print("sherpa-onnx: import OK")
print("numpy:", numpy.__version__)
PY2
python3 -m py_compile \
"$APP_DIR/process_calls.py" \
"$WHISPER_BIN" --help >/dev/null
echo
echo 'Installation complete.'
echo "Run: transcribe"
echo "Config: $CONFIG"
echo "Pipeline: $APP_DIR"
echo "GPU acceleration: disabled in this Pi 5 installer"
