Usb ssd stick interupt with wifi
USB ssd stick interupt with wlan
Required infos down in the bottom
First things first ,
Thanks for this great project learnd a lot here.
Also a good forum feedback = support.
Now i got a Problem costs me 2 days.
I have a ssd
-SanDisk extreme PRO Usb 3.2 Solid State Flash Drive
Usb stick always if i connect it to my pi4 it interrupts with the included wlan .
sounds weird i know.
If i dismount the san disk stick i can connet to the net. Otherwise always dhclient hangs up.
i have done my reinstalls and also grabt a new original packed san disk stick.
experimented with static ip and dhcp
Journalctl output gives me that wpa_supplicant breaks
!!! OH jeah just for mentiond my Raspberry Pi3b+ the stick works all fine so i thing it has to do with the usb3.x standard maybe !!!
journal ctl snapshots where it interups:
Aug 22 12:44:47 DietPi ifup[514]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Aug 22 12:44:47 DietPi dhclient[514]: Sending on   Socket/fallback
Aug 22 12:44:47 DietPi dhclient[514]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Aug 22 12:44:51 DietPi systemd[1]: systemd-rfkill.service: Deactivated successfully.
Aug 22 12:44:52 DietPi dhclient[465]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
Aug 22 12:44:52 DietPi ifup[465]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
Aug 22 12:44:53 DietPi dhclient[514]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
Aug 22 12:44:53 DietPi ifup[514]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
Aug 22 12:45:04 DietPi dhclient[465]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
Aug 22 12:45:04 DietPi ifup[465]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
Aug 22 12:45:05 DietPi wpa_supplicant[509]: wlan0: Failed to initiate sched scan
Aug 22 12:45:48 DietPi dhclient[465]: No DHCPOFFERS received.
Aug 22 12:45:48 DietPi ifup[465]: No DHCPOFFERS received.
Aug 22 12:45:48 DietPi ifup[465]: No working leases in persistent database - sleeping.
Aug 22 12:45:48 DietPi dhclient[465]: No working leases in persistent database - sleeping.
Aug 22 12:45:48 DietPi systemd[1]: Finished ifup@eth0.service - ifup for eth0.
Aug 22 12:45:48 DietPi dhclient[514]: No DHCPOFFERS received.
Aug 22 12:45:48 DietPi ifup[514]: No DHCPOFFERS received.
Aug 22 12:45:48 DietPi ifup[514]: No working leases in persistent database - sleeping.
Aug 22 12:45:48 DietPi dhclient[514]: No working leases in persistent database - sleeping.
Aug 22 12:45:48 DietPi systemd[1]: Finished ifup@wlan0.service - ifup for wlan0.
Aug 22 12:45:48 DietPi systemd[1]: Reached target network.target - Network.
Aug 22 12:45:48 DietPi systemd[1]: Reached target network-online.target - Network is Online.
Aug 22 12:45:48 DietPi systemd[1]: Started dietpi-postboot.service - DietPi-PostBoot.
Aug 22 12:45:48 DietPi systemd[1]: Starting nmbd.service - Samba NMB Daemon...
Aug 22 12:45:48 DietPi systemd[1]: Starting samba-ad-dc.service - Samba AD Daemon...
Aug 22 12:45:48 DietPi systemd[1]: Starting ssh.service - OpenBSD Secure Shell server...
Aug 22 12:45:48 DietPi systemd[1]: Starting systemd-user-sessions.service - Permit User Sessions...
Aug 22 12:45:48 DietPi systemd[1]: Finished systemd-user-sessions.service - Permit User Sessions.
Aug 22 12:45:48 DietPi systemd[1]: Started getty@tty1.service - Getty on tty1.
Aug 22 12:45:48 DietPi systemd[1]: Reached target getty.target - Login Prompts.
Aug 22 12:45:48 DietPi sshd[577]: Server listening on 0.0.0.0 port 22.
Aug 22 12:45:48 DietPi sshd[577]: Server listening on :: port 22.
Aug 22 12:45:48 DietPi systemd[1]: Started ssh.service - OpenBSD Secure Shell server.
Aug 22 12:45:49 DietPi systemd[1]: samba-ad-dc.service: Skipped due to 'exec-condition'.
Aug 22 12:45:49 DietPi systemd[1]: Condition check resulted in samba-ad-dc.service - Samba AD Daemon being skipped.
Aug 22 12:46:43 DietPi wpa_supplicant[509]: wlan0: Failed to initiate sched scan
Aug 22 12:46:51 DietPi wpa_supplicant[509]: wlan0: Failed to initiate sched scan
Aug 22 12:46:52 DietPi systemd[1]: Stopping systemd-timesyncd.service - Network Time Synchronization
Aug 23 08:13:43 DietPi ifdown[1263]: DHCPRELEASE of 192.168.178.55 on wlan0 to 192.168.178.1 port 67
Aug 23 08:13:43 DietPi dhclient[1263]: send_packet: Network is unreachable
Aug 23 08:13:43 DietPi ifdown[1263]: send_packet: Network is unreachable
Aug 23 08:13:43 DietPi dhclient[1263]: send_packet: please consult README file regarding broadcast address.
Aug 23 08:13:43 DietPi ifdown[1263]: send_packet: please consult README file regarding broadcast address.
Aug 23 08:13:43 DietPi dhclient[1263]: dhclient.c:3124: Failed to send 300 byte long packet over fallback interface.
Aug 23 08:13:43 DietPi ifdown[1263]: dhclient.c:3124: Failed to send 300 byte long packet over fallb
And after i disconnect the USB stick systemctl output is like
Aug 23 08:13:18 DietPi sudo[1002]: pam_unix(sudo:session): session opened for user root(uid=0) by dietpi(uid=1000)
Aug 23 08:13:23 DietPi dhclient[994]: No DHCPOFFERS received.
Aug 23 08:13:23 DietPi ifup[994]: No DHCPOFFERS received.
Aug 23 08:13:23 DietPi ifup[994]: No working leases in persistent database - sleeping.
Aug 23 08:13:23 DietPi dhclient[994]: No working leases in persistent database - sleeping.
Aug 23 08:13:24 DietPi systemd[1]: Finished ifup@eth0.service - ifup for eth0.
Aug 23 08:13:34 DietPi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Aug 23 08:13:34 DietPi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
Aug 23 08:13:39 DietPi systemd[1]: Reloading.
Aug 23 08:13:41 DietPi dhclient[1241]: Killed old client process
Aug 23 08:13:42 DietPi dhclient[1241]: Internet Systems Consortium DHCP Client 4.4.3-P1
Aug 23 08:13:42 DietPi dhclient[1241]: Copyright 2004-2022 Internet Systems Consortium.
Aug 23 08:13:42 DietPi dhclient[1241]: All rights reserved.
Aug 23 08:13:42 DietPi dhclient[1241]: For info, please visit https://www.isc.org/software/dhcp/
Aug 23 08:13:42 DietPi dhclient[1241]: Listening on LPF/eth0/2c:cf:67:5e:a0:cd
Aug 23 08:13:42 DietPi dhclient[1241]: Sending on   LPF/eth0/2c:cf:67:5e:a0:cd
Aug 23 08:13:42 DietPi dhclient[1241]: Sending on   Socket/fallback
Aug 23 08:13:42 DietPi systemd[1]: Stopping ifup@wlan0.service - ifup for wlan0...
Aug 23 08:13:42 DietPi dhclient[1263]: Killed old client process
Aug 23 08:13:42 DietPi ifdown[1263]: Killed old client process
Aug 23 08:13:43 DietPi dhclient[1263]: Internet Systems Consortium DHCP Client 4.4.3-P1
Aug 23 08:13:43 DietPi ifdown[1263]: Internet Systems Consortium DHCP Client 4.4.3-P1
Aug 23 08:13:43 DietPi dhclient[1263]: Copyright 2004-2022 Internet Systems Consortium.
Aug 23 08:13:43 DietPi ifdown[1263]: Copyright 2004-2022 Internet Systems Consortium.
Aug 23 08:13:43 DietPi dhclient[1263]: All rights reserved.
Aug 23 08:13:43 DietPi ifdown[1263]: All rights reserved.
Aug 23 08:13:43 DietPi dhclient[1263]: For info, please visit https://www.isc.org/software/dhcp/
Aug 23 08:13:43 DietPi ifdown[1263]: For info, please visit https://www.isc.org/software/dhcp/
Aug 23 08:13:43 DietPi dhclient[1263]: Listening on LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:43 DietPi ifdown[1263]: Listening on LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:43 DietPi dhclient[1263]: Sending on   LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:43 DietPi ifdown[1263]: Sending on   LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:43 DietPi dhclient[1263]: Sending on   Socket/fallback
Aug 23 08:13:43 DietPi ifdown[1263]: Sending on   Socket/fallback
Aug 23 08:13:43 DietPi dhclient[1263]: DHCPRELEASE of 192.168.178.55 on wlan0 to 192.168.178.1 port 67
Aug 23 08:13:43 DietPi ifdown[1263]: dhclient.c:3124: Failed to send 300 byte long packet over fallback interface.
Aug 23 08:13:43 DietPi systemd[1]: Reloading smbd.service - Samba SMB Daemon...
Aug 23 08:13:43 DietPi systemd[1]: Reloaded smbd.service - Samba SMB Daemon.
Aug 23 08:13:43 DietPi wpa_supplicant[509]: wlan0: CTRL-EVENT-DISCONNECTED bssid=dc:15:c8:b2:eb:59 reason=3 locally_generated=1
Aug 23 08:13:44 DietPi wpa_supplicant[509]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Aug 23 08:13:44 DietPi wpa_supplicant[509]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
Aug 23 08:13:44 DietPi wpa_supplicant[509]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 23 08:13:44 DietPi wpa_supplicant[509]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Aug 23 08:13:44 DietPi wpa_supplicant[509]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
Aug 23 08:13:44 DietPi wpa_supplicant[509]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 23 08:13:44 DietPi wpa_supplicant[509]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Aug 23 08:13:44 DietPi wpa_supplicant[509]: wlan0: CTRL-EVENT-TERMINATING
Aug 23 08:13:44 DietPi systemd[1]: ifup@wlan0.service: Deactivated successfully.
Aug 23 08:13:44 DietPi systemd[1]: Stopped ifup@wlan0.service - ifup for wlan0.
Aug 23 08:13:44 DietPi systemd[1]: Starting ifup@wlan0.service - ifup for wlan0...
Aug 23 08:13:44 DietPi wpa_supplicant[1303]: Successfully initialized wpa_supplicant
Aug 23 08:13:44 DietPi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
Aug 23 08:13:44 DietPi dhclient[1311]: Internet Systems Consortium DHCP Client 4.4.3-P1
Aug 23 08:13:44 DietPi ifup[1311]: Internet Systems Consortium DHCP Client 4.4.3-P1
Aug 23 08:13:44 DietPi ifup[1311]: Copyright 2004-2022 Internet Systems Consortium.
Aug 23 08:13:44 DietPi ifup[1311]: All rights reserved.
Aug 23 08:13:44 DietPi ifup[1311]: For info, please visit https://www.isc.org/software/dhcp/
Aug 23 08:13:44 DietPi dhclient[1311]: Copyright 2004-2022 Internet Systems Consortium.
Aug 23 08:13:44 DietPi dhclient[1311]: All rights reserved.
Aug 23 08:13:44 DietPi dhclient[1311]: For info, please visit https://www.isc.org/software/dhcp/
Aug 23 08:13:44 DietPi dhclient[1311]: Listening on LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:44 DietPi ifup[1311]: Listening on LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:44 DietPi dhclient[1311]: Sending on   LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:44 DietPi ifup[1311]: Sending on   LPF/wlan0/2c:cf:67:5e:a0:ce
Aug 23 08:13:44 DietPi dhclient[1311]: Sending on   Socket/fallback
Aug 23 08:13:44 DietPi ifup[1311]: Sending on   Socket/fallback
Aug 23 08:13:44 DietPi dhclient[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
Aug 23 08:13:44 DietPi ifup[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
Aug 23 08:13:46 DietPi wpa_supplicant[1306]: wlan0: Trying to associate with SSID 'Bremsenbefetter'
Aug 23 08:13:49 DietPi wpa_supplicant[1306]: wlan0: Associated with dc:15:c8:b2:eb:59
Aug 23 08:13:49 DietPi wpa_supplicant[1306]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Aug 23 08:13:49 DietPi wpa_supplicant[1306]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Aug 23 08:13:49 DietPi wpa_supplicant[1306]: wlan0: WPA: Key negotiation completed with dc:15:c8:b2:eb:59 [PTK=CCMP GTK=CCMP]
Aug 23 08:13:49 DietPi wpa_supplicant[1306]: wlan0: CTRL-EVENT-CONNECTED - Connection to dc:15:c8:b2:eb:59 completed [id=0 id_str=]
Aug 23 08:13:49 DietPi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 23 08:13:52 DietPi dhclient[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Aug 23 08:13:52 DietPi ifup[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Aug 23 08:14:03 DietPi dhclient[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
Aug 23 08:14:03 DietPi ifup[1311]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
Aug 23 08:14:03 DietPi dhclient[1311]: DHCPOFFER of 192.168.178.55 from 192.168.178.1
Aug 23 08:14:03 DietPi ifup[1311]: DHCPOFFER of 192.168.178.55 from 192.168.178.1
Aug 23 08:14:03 DietPi ifup[1311]: DHCPREQUEST for 192.168.178.55 on wlan0 to 255.255.255.255 port 67
Aug 23 08:14:03 DietPi dhclient[1311]: DHCPREQUEST for 192.168.178.55 on wlan0 to 255.255.255.255 po
Bottom required infos here
root@DietPi:/home/dietpi# cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=6
G_DIETPI_VERSION_RC=1
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
bookworm 0
root@DietPi:/home/dietpi# uname --all
root@DietPi:/home/dietpi# dpkg --print-architecture
normaly clear thought as i written pi4 but ok
arm64
echo $G_HW_MODEL_NAME
RPi 4 Model B (aarch64)
  • Power supply used | Original Raspberry
  • SD card used | san disk ultra
  • everything was installed via dietpi-config dietpi-drive-manager
dietpi@DietPi:~$ lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
NAME        FSTYPE LABEL  SIZE RO TYPE MOUNTPOINT PARTUUID                             UUID
mmcblk0                  29.7G  0 disk
├─mmcblk0p1 vfat          128M  0 part /boot      a580676e-01                          36B2-AF2B
└─mmcblk0p2 ext4         29.6G  0 part /          a580676e-02                          ce752fc9-a0e6-4ae5-bf1e-0375a7a6e73a
dietpi@DietPi:~$
This is a known problem with the RPi 4, the shielding does not work correctly. Only solution is to use either one of them, USB port or the wifi.
See https://forums.raspberrypi.com/viewtopic.php?t=328248
ok thanks Jappe, thats weird
