Upgrading Sonarr V3 to V4
Ugh. OK. I didn’t see that line included in your script above (but do see it mentioned in subsequent comments). I currently have the sonarr service stopped. Do you have any advice on what I might try next? Should I just try dietpi-software reinstall 144 ?
Thank you for your reply!
Just run this command, it should do all steps needed to migrate your config/database.
Yup, that did the trick. Thank you!
