- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=3
G_DIETPI_VERSION_RC=0
G_GITOWNER=‘MichaIng’ - Distro version | bullseye
- Kernel version | Linux DietPiX220t 5.10.0-28-amd64 #1 SMP Debian 5.10.209-2 (2024-01-31) x86_64 GNU/Linux
- Architecture | amd64
- SBC model | Native PC (x86_64) dell Wyse 5070
- Power supply used | standard power supply
- SD card used | SATA ssd
- Software title | wireguard / dkms / kernel
- Was the software title installed freshly or updated/migrated? update to bookworm via script
- Can this issue be replicated on a fresh installation of DietPi? didn’t try, probably not
I used the upgrade script to upgrade to bookworm. First the process broke with initramfs complaining about a swap-partition for resume it couldn’t find. I deleted the requirement. After that initramfs was fine.
However now the process stops because dkms can’t compile a kernel-module for wireguard. Rerunning the process doesn’t help.
The install script to go through to the end.
APT dist-upgrade
- Command: apt-get -y dist-upgrade
- Exit code: 100
- DietPi version: v9.3.0 (MichaIng/master) | HW_MODEL: 21 | HW_ARCH: 10 | DISTRO: 6
- Image creator: Berny
- Pre-image: https://cdimage.debian.org/debian-cd/current/amd64/bt-cd/debian-10.5.0-amd64-netinst.iso
- Error log:
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following packages were automatically installed and are no longer required:
dctrl-tools gcc-8-base glib-networking glib-networking-common
glib-networking-services gsettings-desktop-schemas libaio1 libaom0
libatk1.0-data libavcodec58 libavformat58 libavutil56 libbpf0 libcbor0
libcodec2-0.9 libdav1d4 libdns-export1110 libffi7 libgcc1
libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf2.0-0 libglew2.1 libglu1-mesa
libgtksourceview-3.0-1 libgtksourceview-3.0-common libicu67
libimobiledevice6 libisc-export1105 libjson-glib-1.0-0
libjson-glib-1.0-common libldap-2.4-2 libllvm11 liblua5.1-0 libmpdec3
libntfs-3g883 libonig5 libopengl0 libpcre3 libperl5.32 libplist3
libpoppler102 libprocps8 libproxy1v5 libpython3.9 libpython3.9-minimal
libpython3.9-stdlib librest-0.7-0 libsepol1 libsoup-gnome2.4-1 libsoup2.4-1
libsoup2.4-common libsrt1.4-gnutls libswresample3 libtiff5 libusbmuxd6
libvpx6 libvulkan1 libwavpack1 libwebp6 libx264-160 libx265-192 libxslt1.1
libzip4 linux-compiler-gcc-10-x86 linux-headers-5.10.0-28-amd64
linux-headers-5.10.0-28-common linux-image-5.10.0-28-amd64 linux-kbuild-5.10
lua-bitop lua-cjson mariadb-server-10.5 perl-modules-5.32
python3-requests-toolbelt python3-zope.component python3-zope.event
python3-zope.hookable python3-zope.interface python3.9 python3.9-minimal
Use 'apt autoremove' to remove them.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-6.1.0-20-amd64 (6.1.85-1) ...^M
/etc/kernel/postinst.d/dkms:^M
dkms: running auto installation service for kernel 6.1.0-20-amd64.^M
Sign command: /usr/lib/linux-kbuild-6.1/scripts/sign-file^M
Signing key: /var/lib/dkms/mok.key^M
Public certificate (MOK): /var/lib/dkms/mok.pub^M
Error! The /var/lib/dkms/wireguard/1.0.20210219/6.1.0-20-amd64/x86_64/dkms.conf for module wireguard includes a
BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.^M
This indicates that it should not be built.^M
Error! One or more modules failed to install during autoinstall.^M
Refer to previous errors for more information.^M
dkms: autoinstall for kernel: 6.1.0-20-amd64 failed!^M
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11^M
dpkg: error processing package linux-image-6.1.0-20-amd64 (--configure):^M
installed linux-image-6.1.0-20-amd64 package post-installation script subprocess returned error exit status 1^M
Setting up linux-headers-6.1.0-20-amd64 (6.1.85-1) ...^M
/etc/kernel/header_postinst.d/dkms:^M
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11^M
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-6.1.0-20-amd64.postinst line 11.^M
dpkg: error processing package linux-headers-6.1.0-20-amd64 (--configure):^M
installed linux-headers-6.1.0-20-amd64 package post-installation script subprocess returned error exit status 1^M
dpkg: dependency problems prevent configuration of linux-headers-amd64:^M
linux-headers-amd64 depends on linux-headers-6.1.0-20-amd64 (= 6.1.85-1); however:^M
Package linux-headers-6.1.0-20-amd64 is not configured yet.^M
^M
dpkg: error processing package linux-headers-amd64 (--configure):^M
dependency problems - leaving unconfigured^M
dpkg: dependency problems prevent configuration of linux-image-amd64:^M
linux-image-amd64 depends on linux-image-6.1.0-20-amd64 (= 6.1.85-1); however:^M
Package linux-image-6.1.0-20-amd64 is not configured yet.^M
^M
dpkg: error processing package linux-image-amd64 (--configure):^M
Errors were encountered while processing:^M
linux-image-6.1.0-20-amd64^M
linux-headers-6.1.0-20-amd64^M
linux-headers-amd64^M
linux-image-amd64^M
E: Sub-process /usr/bin/dpkg returned an error code (1)
I had installed wireguard via apt-get install before it was available as a dietPi packet
The directory dkms complains about doesn’t seem to exist:
# ls /var/lib/dkms/wireguard/1.0.20210219/
4.19.0-21-amd64 source
I tried to remove wireguard in a different shell but that didn’t work either:
apt-get remove wireguard
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Paket »wireguard« ist nicht installiert, wird also auch nicht entfernt.
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
Verwenden Sie »apt autoremove«, um sie zu entfernen.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
4 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
linux-image-6.1.0-20-amd64 (6.1.85-1) wird eingerichtet ...
Error! The /var/lib/dkms/wireguard/1.0.20210219/6.1.0-20-amd64/x86_64/dkms.conf for module wireguard includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.
dpkg: Fehler beim Bearbeiten des Paketes linux-image-6.1.0-20-amd64 (--configure):
»installiertes post-installation-Skript des Paketes linux-image-6.1.0-20-amd64«-Unterprozess gab den Fehlerwert 1 zurück
linux-headers-6.1.0-20-amd64 (6.1.85-1) wird eingerichtet ...
dpkg: Fehler beim Bearbeiten des Paketes linux-headers-6.1.0-20-amd64 (--configure):
»installiertes post-installation-Skript des Paketes linux-headers-6.1.0-20-amd64«-Unterprozess gab den Fehlerwert 1 zurück
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linux-headers-amd64:
linux-headers-amd64 hängt ab von linux-headers-6.1.0-20-amd64 (= 6.1.85-1); aber:
Paket linux-headers-6.1.0-20-amd64 ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten des Paketes linux-headers-amd64 (--configure):
Abhängigkeitsprobleme - verbleibt unkonfiguriert
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linux-image-amd64:
linux-image-amd64 hängt ab von linux-image-6.1.0-20-amd64 (= 6.1.85-1); aber:
Paket linux-image-6.1.0-20-amd64 ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten des Paketes linux-image-amd64 (--configure):
Fehler traten auf beim Bearbeiten von:
linux-headers-amd64
linux-image-amd64
What can I do to finish the upgrade?
How would I return to the backup I made before the process started?
