Hello everyone,
I’ve been using DietPi for a few weeks and I truly love it. I even donated to the project recently too. However, I’ve run into an issue that I can’t seem to resolve.
What I’m Trying to Achieve
Unbound as LAN’s DNS Resolver
All LAN devices (e.g., phones, laptops) should query Unbound on the DietPi system for DNS. -
Unbound’s Upstream Queries via VPN
Unbound’s upstream queries (to root servers) should always go through the WireGuard VPN (Mullvad), ensuring privacy. -
Fallback Behavior
- If the VPN goes down, LAN devices should still be able to query Unbound for cached results.
- Unbound should not bypass the VPN for upstream queries under any condition.
AdGuard as a Filter
I’m using AdGuard Home as a filter between LAN devices and Unbound.
System Details
- DietPi Version:
G_DIETPI_VERSION_CORE=9,G_DIETPI_VERSION_SUB=8,G_DIETPI_VERSION_RC=0 - Git Branch:
master - Kernel:
Linux DietPi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux - Distro:
bookworm - Platform:
RPi 2 Model B (armv7l)
What Works
Unbound and WireGuard Together:
- When I let WireGuard route all traffic for the DietPi system without adding iptables rules, everything works perfectly:
- DietPi resolves DNS locally.
- LAN devices can query Unbound via AdGuard and receive DNS responses.
Unbound Without VPN:
- Without WireGuard, LAN devices can query Unbound via AdGuard and get DNS responses without any issues.
What Doesn’t Work
When WireGuard is active and iptables rules are applied:
- LAN devices fail to get DNS responses from Unbound.
- AdGuard logs the DNS queries from LAN devices, but Unbound does not respond.
- LAN devices lose internet connectivity entirely when they rely on DietPi for DNS.
Configuration
WireGuard Configuration
/etc/wireguard/se-got-wg-002.conf:
[Interface]
PrivateKey = <Private Key>
Address = Mulvadip/32
DNS = 127.0.0.1
PostUp = ip rule add fwmark 0x1 lookup 100
PostUp = ip route add default dev %i table 100
PostUp = iptables -t mangle -A OUTPUT -m owner --uid-owner unbound -j MARK --set-mark 0x1
PostUp = iptables -A INPUT -s 192.168.0.0/16 -p tcp --dport 5335 -j ACCEPT
PostUp = iptables -A INPUT -s 192.168.0.0/16 -p udp --dport 5335 -j ACCEPT
PostDown = ip rule del fwmark 0x1 lookup 100
PostDown = ip route del default dev %i table 100
PostDown = iptables -t mangle -D OUTPUT -m owner --uid-owner unbound -j MARK --set-mark 0x1
PostDown = iptables -D INPUT -s 192.168.0.0/16 -p tcp --dport 5335 -j ACCEPT
PostDown = iptables -D INPUT -s 192.168.0.0/16 -p udp --dport 5335 -j ACCEPT
[Peer]
PublicKey = <Peer Public Key>
AllowedIPs = 0.0.0.0/0
Endpoint = <WireGuard Server IP>:51820
Unbound Configuration
/etc/unbound/unbound.conf.d/dietpi-unbound.conf:
server:
interface: 127.0.0.1
port: 5335
access-control: 192.168.0.0/16 allow
private-address: 192.168.0.0/16
do-daemonize: no
num-threads: 1
AdGuard Configuration
- Upstream DNS: 127.0.0.1:5335
- Private Reverse DNS Resolvers: 127.0.0.1:5335
Troubleshooting Steps Tried
Removed All iptables Rules:
- When WireGuard is disabled, DNS works for LAN devices.
- When WireGuard is active without iptables rules, LAN devices still fail to get DNS responses.
Modified iptables Rules:
- Added specific rules to allow LAN traffic (192.168.0.0/16) to access Unbound on port 5335.
- Unbound still doesn’t respond to LAN devices while routing its upstream traffic through WireGuard.
Verified Mullvad VPN Config:
- Created a new WireGuard key with DNS hijacking disabled using Mullvad’s API.
- Tested the WireGuard connection with the new configuration and verified that Unbound uses the VPN for upstream queries.
Checked Logs:
- AdGuard logs show the queries from LAN devices, but there’s no resolution.
- Unbound logs show no errors for local queries.
Reset iptables Rules:
- Reset all iptables rules (
iptables -F) and ensured there are no other interfering rules.
Current Observations
- Without any iptables modifications, WireGuard works fine, and DietPi itself can resolve DNS queries.
- LAN devices cannot get DNS responses from Unbound as long as WireGuard is active, even with permissive iptables rules.
- It appears the iptables rules restricting Unbound’s upstream traffic to WireGuard might also prevent it from responding to LAN devices.
Logs and Outputs
iptables -L -v after resetting:
Chain INPUT (policy ACCEPT 113 packets, 8300 bytes)
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 67 packets, 8480 bytes)
Unbound works locally:
Command: dig @127.0.0.1 -p 5335 example.com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14006
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
example.com. IN A 93.184.215.14
AdGuard logs DNS queries from LAN devices, but Unbound does not respond.
Request for Help
I’m reaching out to see if anyone has successfully set up a similar configuration. Specifically:
- How can I allow LAN devices to query Unbound while ensuring Unbound’s upstream traffic is routed through WireGuard?
- Are there any additional iptables or routing rules I should use to fix this?
Thank you in advance for your advice and guidance.
