can you reboot your system and check service, logs and LISTEN ports
systemctl status unbound
journalctl -u unbound
ss -tulpn | grep LISTEN
first of all, no need to do screen prints. They are not needed at all. You could copy everything from SSH terminal.
Ok Unbound is running and LISTEN to correct port. Let’s check why it did not answer DNS request
dig @127.0.0.1 -p 5335 google.com
xMike
26 September 2022 08:21
7
sorry
root@Pi-hole:~# dig @127.0.0.1 -p 5335 google.com
; <<>> DiG 9.16.33-Debian <<>> @127.0.0.1 -p 5335 google.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 41322
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;google.com. IN A
;; Query time: 4 msec
;; SERVER: 127.0.0.1#5335(127.0.0.1)
;; WHEN: Mon Sep 26 01:20:49 PDT 2022
;; MSG SIZE rcvd: 39
xMike:
status: SERVFAIL
ok Unbound is working but somehow having issues to complete the request. Let’s increase the log level and investigate further. First remove Unbound from PiHole configuration pls, until we found the issues. Once done, reboot the system and do following:
G_CONFIG_INJECT ' verbosity:' ' verbosity:2' /etc/unbound/unbound.conf.d/dietpi.conf
systemctl restart unbound
journalctl -u unbound.service
xMike
26 September 2022 09:03
9
thank you. unbound has been removed from pihole configuration and system restarted
root@Pi-hole:~# G_CONFIG_INJECT ' verbosity:' ' verbosity:2' /etc/unbound/unbound.conf.d/dietpi.conf
[ OK ] G_CONFIG_INJECT | Added setting verbosity:2 to end of file /etc/unbound/unbound.conf.d/dietpi.conf
root@Pi-hole:~# systemctl restart unbound
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 56833
;google.com. IN A
;; Query time: 216 msec
;; WHEN: Mon Sep 26 02:01:27 PDT 2022
root@Pi-hole:~# journalctl -u unbound.service
-- Journal begins at Mon 2022-09-26 01:59:58 PDT, ends at Mon 2022-09-26 02:01:27 PDT. --
Sep 26 02:00:27 Pi-hole systemd[1]: Starting Unbound DNS server...
Sep 26 02:00:28 Pi-hole systemd[1]: Started Unbound DNS server.
Sep 26 02:00:28 Pi-hole unbound[451]: [451:0] info: start of service (unbound 1.13.1).
Sep 26 02:01:21 Pi-hole unbound[451]: [451:0] info: service stopped (unbound 1.13.1).
Sep 26 02:01:21 Pi-hole systemd[1]: Stopping Unbound DNS server...
Sep 26 02:01:21 Pi-hole systemd[1]: unbound.service: Succeeded.
Sep 26 02:01:21 Pi-hole systemd[1]: Stopped Unbound DNS server.
Sep 26 02:01:21 Pi-hole systemd[1]: Starting Unbound DNS server...
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] notice: init module 0: subnet
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] notice: init module 1: validator
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] notice: init module 2: iterator
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: start of service (unbound 1.13.1).
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving . DNSKEY IN
Sep 26 02:01:21 Pi-hole systemd[1]: Started Unbound DNS server.
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: priming . IN NS
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: response for . NS IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.33.4.12#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: query response REC_LAME: recursive but not authoritative server
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: mark as REC_LAME
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.203.230.10#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 199.7.91.13#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 193.0.14.129#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.112.36.4#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.5.5.241#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 198.41.0.4#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.36.148.17#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 199.7.83.42#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 198.97.190.53#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.58.128.30#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 202.12.27.33#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 199.9.14.201#53
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: query response was ANSWER
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: priming successful for . NS IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving f.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving k.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving a.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: response for f.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: query response was nodata ANSWER
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: response for k.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: response for a.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving g.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving j.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving h.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving l.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving m.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving c.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving i.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving b.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving e.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: resolving d.root-servers.net. A IN
Sep 26 02:01:21 Pi-hole unbound[1074]: [1074:0] info: response for m.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving google.com. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving h.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving g.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving j.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving c.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving d.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving l.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving i.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving e.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving . DNSKEY IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving b.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for i.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.5.5.241#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: query response was nodata ANSWER
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 193.0.14.129#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: query response was ANSWER
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for e.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for b.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 202.12.27.33#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for l.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for c.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.36.148.17#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for d.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 199.9.14.201#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for g.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for j.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for h.root-servers.net. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.203.230.10#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for google.com. A IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 198.41.0.4#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for . DNSKEY IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: prime trust anchor
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: generate keytag query _ta-4f66. NULL IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: validate keys with anchor(DS): sec_status_bogus
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: failed to prime trust anchor -- DNSKEY rrset is not secure . DNSKEY IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: resolving _ta-4f66. NULL IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: response for _ta-4f66. NULL IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: query response was NXDOMAIN ANSWER
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 199.7.91.13#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 198.97.190.53#53
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: Could not establish a chain of trust to keys for . DNSKEY IN
Sep 26 02:01:27 Pi-hole unbound[1074]: [1074:0] info: reply from <.> 192.112.36.4#53
what is the local DNS server you are using on DietPi directly?
cat /etc/resolv.conf
xMike
26 September 2022 09:21
11
root@Pi-hole:~# cat /etc/resolv.conf
nameserver 192.168.1.2
who is 192.168.1.2?? Is this the DietPi device or something else?
xMike
26 September 2022 09:25
13
it’s the dietpi device itself. i’m guessing it’s set from my router?
ok, do you use DHCP or STATIC IP address on DietPi?
I would recommend using STATIC IP and change local DNS server to a global one like Quad9 or Cloudflare.
xMike
26 September 2022 10:02
15
dietpi was originally set for dhcp with the router having it set via static
i’ve gone ahead and made the changes as you suggested so now both dietpi and router have it set to static and dns is now cloudflare
ok let’s check it, reboot the system and have a look to logs again
ip a
The DNS on the DHCP server needs to be the IP of the Pihole machine so it hands out the DHCP requests to the clients, otherwise they won’t know where to send DNS requests…and bind Pihole to listen to it to eth0 or permit all origins, since it is behind the firewall of your router it should be safe.
You definitely want a static IP on the Pihole, or a static DNS assignment from your router.
You want the upstream DNS to be the 127.0.0.1#5335 to point pihole to send requests to the unbound service.
@WarHawk
pls don’t mix-up thinks. The issue is with unbound direcly not being able to initilize. This has nothing to do with DHCP settings and or PiHole. At least not directly
Ah so his Unbound service isn’t starting…gotcha
xMike
26 September 2022 10:19
20
root@Pi-hole:~# ip a
link/ether dc:a6:32:5c:b4:63 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.2/24 brd 192.168.1.255 scope global eth0
nameserver 1.1.1.1
nameserver 1.0.0.1
root@Pi-hole:~# journalctl -u unbound. Service
Failed to add match 'Service': Invalid argument
@WarHawk
thank you for trying to help though. it’s been driving me crazy
