I seek your advise on connection to dietpi to my University’s wifi. It is based on PEAP-MSChapV2 and no validation required. Thank you.
This is just WPA 2 enterprise, right?
Did it not work with dietpi-config
→ 7 : Network Options: Adapter
no, i am unable to find the option to configure the wifi.
Can you please fill out the troubleshooting form?
Required
- DietPi version |
cat /boot/dietpi/.version
- Distro version |
- Kernel version |
uname -a
- Architecture |
dpkg --print-architecture
- SBC model |
echo $G_HW_MODEL_NAME
or (EG: RPi3) - Power supply used | (EG: 5V 1A RAVpower)
- SDcard used | (EG: SanDisk ultra)
DietPi version |
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=2
Distro version |
bullseye 0
Kernel version |
Architecture | arm64
SBC model | RPi 4 Model B (aarch64)
SD card used | 32GB SanDisk ultra
Software title | Wifi
Fresh Install
Can this issue be replicated on a fresh installation of DietPi? | Yes
You are trying to use on-board WiFi? Does it is enabled within dietpi-config
? If yes, did you reboot afterwards to make the interface available?
i am able to connect to other wifi. However, i am unable to connect to univeristy’s with wifi that requires wpa2 enterprise.
Looks like some manuell steps are needed RPi 3b+ or RPi 4 WPA2e (WPA2 Enterprise) - Raspberry Pi Forums
