Unable to access Webinterface FHEM (Homeautomation) after installation of PI-Hole (DNS Problem)
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=12
    G_DIETPI_VERSION_RC=1
    bookworm
    Linux server 5.10.66-27-rockchip-gea60d388902d #rockchip SMP Mon Oct 24 08:25:47 UTC 2022 aarch64 GNU/Linux
    arm64
    Generic Device (aarch64)
  • Power supply used
    other
  • SD card used
    other
  • Software title
    FHEM | Pi-Hole
    Pi-Hole was freshly installed | FHEM was already installed (long ago)
  • Can this issue be replicated on a fresh installation of DietPi
    untested but I think so
  1. Install Pi-Hole on a Diet-Pi-Server with existing services with webinterface
  2. …
  • Normal function of webinterface
  • After installation of Pi-Hole the webinterface of another service on the same server isn’t accessible anymore over dns-name (until you stop pi-hole service)
You can’t open the Webinterface of FHEM by servername (DNS) while PI-Hole is running.
Do I have to add the servername to pi-hole manually for dns-resolution and how is this done (without domain)?
Thanks in advance.
hmtec
Pihole has a section where you can add custom DNS records
I already tested this with servername only (without domain).
It do function with the pseudo-domain of the router after the servername (server.router.tld).
Thank you!
You can add whatever domain name to PiHole without using the pseudo domain of the router
