Turn off HDMI dispkay via "vcgencmd display_power 0"
I’m trying to simply turn off my HDMI display using vcgencmd display_power 0
root@DietPi:~# vcgencmd display_power 0
display_power=1
root@DietPI:~#
But as a reply I get “display_power=1”… :thinking: I know that is “1/ON” I want to turn it off…
Any suggestion? Why the command doesn’t set the “0” state?
Thanks!
https://www.reddit.com/r/dietpi/comments/x0tlpp/comment/jee7g86/
It’s not supported any more.
Great thanks, this worked!
At least on RPi, you can set headless mode via dietpi-config
Yes, this also saves some power!
