I’m running DietPi through VirtualBox installed in Lubuntu. I’ve been having a hell of a time getting shares added to the DietPi VM. I’ve tried everything I can think of, and have failed every step of the way.
First, I wanted to use USB. Unfortunately, my system has 10 different USB HDDs, and Virtualbox had a limit of 7 or 8. Then I tried using VirtualBox’s shared drive function, hoping to just share the entire /media/ folder. I followed every guide I could find. I ran the guest addons ISO in Dietpi and attempted to install. After this, my DietPi boot time went from about 30 seconds to around 5-8minutes, as I assume something went wrong. And then no folder I ever tried to share ever became available. And within dietpi, I did add the root user to the vboxsf group. Still no luck. Ok, so I removed the guest addons (boot time went back to normal!) and then tried to share the folder with NFS. I used known working NFS commands that I had configured on my old server that I took offline (2 days ago), The command added the NFS user to UID 1000 and GID 1000, which are indeed the appropriate user/group IDs that have ownership of those files/folders within Lubuntu, and yet I was still getting permissions errors when trying to access the NFS folder.
My goal with all of this is to re-create the NAS/media download server I had been running in Ubuntu Mate (which I could still boot whenever I want since that drive is still untouched). I just wanted to fundamentally change how I run everything and do all tasks through VMs with a very vanilla base-OS (Lubuntu). I want to share the HDDs connected out via both NFS and samba. That’s the goal. I’d rather not make my Vanilla OS essentially run as a file server so that DietPi can ALSO run as a file server. Doesn’t seem to make sense.
If you need more details about anything in particular, please feel free to ask. Very sorry if I provide bad details, I’m just dealing with high levels of frustration as I’ve been working on getting my server back to a working state for about 2 days now.
