Hi everyone,
I’m trying to disable the bcm2708_fb
framebuffer and enable vc4-kms-v3d
(KMS driver with hardware acceleration) on my Raspberry Pi running DietPi OS, but without success so far.
What I understand:
bcm2708_fb
is a legacy framebuffer driver.- It only supports software rendering, no GPU acceleration.
- For full hardware acceleration (DRM/KMS,
/dev/dri
, Chromium acceleration), I should usevc4-kms-v3d
instead.
Problem:
Even after multiple attempts, bcm2708_fb is still loaded at boot:
[ 0.596451] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.627463] Console: switching to colour frame buffer device 240x67
[ 0.631116] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
What I have tried:
1. Edited /boot/config.txt
I added:
dtoverlay=vc4-kms-v3d
gpu_mem=128
max_framebuffers=2
disable_fw_kms_setup=1
2. Checked /boot/cmdline.txt
No mention of bcm2708_fb there — only standard entries like:
root=PARTUUID=503f5518-02 rootfstype=ext4 rootwait net.ifnames=0 logo.nologo console=tty1 video=HDMI-A-2:4096x2160d video=HDMI-A-1:4096x2160d snd_bcm2835.enable_headphones=0
3. Tried blacklisting the module
Created /etc/modprobe.d/disable-bcm2708.conf with:
blacklist bcm2708_fb
4. Rebooted after each change
Result:
Unfortunately, after reboot, bcm2708_fb still loads, and no /dev/dri exists.
As a result, Chromium runs without GPU acceleration, and the system is slow.
What is the correct procedure to completely disable bcm2708_fb
on DietPi?
