Hi
I’m wondering if one of you knows the trick to mount a writable SD card on MacOS to edit the file /boot/dietpi.txt as ext4fuse only mounts as readonly the Linux FileSystem ?
Cheers
Charles
Hi
Cheers
Charles
Hi
usually /boot is located on a vfat partition. What kind of image you are using
image of dietpi buster has been flashed on the SD card
DietPi is offering more than 1 image, depending on your device. Maybe you can share the image name or your device
Device is : RockPro64
Image: DietPi_ROCKPro64-ARMv8-Buster.img
ok compare to other images, the ROCKPro64 has an ext4 partition only.
There are limited options as Apple is not supporting ext4
https://github.com/alperakcan/fuse-ext2
https://osxfuse.github.io/
or use a VM temporarily
probably better to reach out to an Apple forum. Maybe there are more guys having experience on getting ext4 support on MacOS
I have mounted the USB - SD card on another Pi box for the moment and then I can edit the file ![]()
indeed a 4th option, compare to using a VM ![]()
A 5th option (which relies on virtualbox) is to use vagrant tool to boot a Linux VM and next scp files to the USB card
See : https://github.com/ch007m/home-devices/tree/master/vagrant
