Thanks for creating such a great distro.
I’m using dedicated USB install.
With Syncthing, I accidentally sync over a few GB of files to the USB drive.
Login as root user, I deleted all the unwanted files from the USB drive.
My questions:
Is there a trash folder that is storing these deleted files?
Is it necessary to empty trash, and if yes, how?
Thank you.
moka:
My questions:
Thank you.
Hi Moka,
Our LXDE desktop installation does not have a “trash can”. This allows us to keep the installation lightweight. Once the files are deleted, they are gone
Thanks for the prompt reply, Fourdee.
