kannz
8 August 2026 02:13
21
oh yeah sorry i forgot to say i did that. i stopped the service then edited and then restarted using dietpi-launcher/services
EDIT: for anyone not wanting to use the ui pretty sure this works to start and stop transmission also.
dietpi-services stop transmission-daemon
dietpi-services start transmission-daemon
kannz:
EDIT: for anyone not wanting to use the ui pretty sure this works to start and stop tranmission also.
Better:
systemctl stop transmission-daemon
systemctl start transmission-daemon
Can you verify this:
sleep 2
grep 'rpc-whitelist-enabled' /etc/transmission-daemon/settings.json
G_CONFIG_INJECT '"rpc-whitelist-enabled"' ' "rpc-whitelist-enabled": false,' /etc/transmission-daemon/settings.json '^\{$'
sleep 2
I don’t remember that Transmission would overwrite or sync back settings, unless you explicitly change them in the GUI and hit “save”. So even a systemctl restart transmission-daemon should work, without actively stopping the service first.
kannz
9 August 2026 07:17
23
I’ll try this out tomorrow
