My goal is to move all configuration and files from a x86/64 laptop (a dell latitude) to a raspberry pi 3. I would not like to go again to configure everything (deluge, plex, pihole, wireguard, samba, network rules…) and I have also some other software that I have installed with scripts (for instance jDownloader)
I have seen on the main dietpi page that there ‘s now a DietPi backup (backup/restore) and I wonder if it would work for me. My dietpi in a laptop and it has been running for years. I stopped updating when I faced a bug that won’t allowed the x86 version of dietpi to boot properly afetr an upgrade and now I am not in a late release.
I was going to give a shot by doing
-Upgrade the current system in the PC (runs in the SSD)
-Run the backup and restore against the new SD card where the pi will run
-Boot the raspberry pi
I am not sure if it would work since the architecture and package names would be different. If anyone knows that this wont work I would save time installing everyhing from scratch again on the pi.
As you already suspected this is not possible because of the architectural differences, dietpi-backup does a full system backup.
Unfortunately you would need to backup your configs etc manually.
But some apps have included backup tools, like pihole.
Since those are 2 different laptops with different hardwares drivers are different, will linux take care of them? I run usually in server mode (console, no screen attached, no GUI)
I managed to get a usb case and did the backup to another drive
┌──────────────────────────────────────────────────┤ DietPi-Backup ├───────────────────────────────────────────────────┐
│ Current backup and restore location: │
│ - /mnt/usbdisk/dietpi-backup │
│ - 2025-10-23_09:08:37 Backup completed
Now, should I install dietpi normally in the new laptop and choose restore backup from the usb disk or how to proceed?
I started running it and I am facing the first challenge
Native PC (x86_64) | IP: 192.168.31.52
┌──────────────────────────────┤ DietPi-Backup ├───────────────────────────────┐
│ [WARNING] UUIDs of the backup and the current system differ │
│ The file systems unique identifiers, usually used to mount the drives at │
│ boot, seem to differ between the backup and the current system. │
│ This usually indicates that you try to restore an old backup onto a newly │
│ flashed DietPi system. │
│ But we were able to find the boot configuration, where those UUIDs would │
│ need to be adjusted, to assure that the system will boot. │
│ It should be hence safe to restore this backup, but if the UUIDs were used │
│ elsewhere, you might need to adjust it manually. │
│ Do you want to restore this backup? │
│ <Ok> <Cancel> │
I guess I need to boot in recovery and adapt uuids
When I trigger it gets some warnings
[ INFO ] DietPi-Backup | Restore from /mnt/usbdisk/dietpi-backup in progress, please wait...
building file list ...
cannot send file with empty name in "/mnt/usbdisk/dietpi-backup/data/mnt/dietpi_userdata/openmediavault/openmediavault/deb/openmediavault/srv/salt/omv/setup/resolvconf/"
cannot send file with empty name in "/mnt/usbdisk/dietpi-backup/data/usr/lib/modules/4.19.0-21-amd64/kernel/drivers/gpu/drm/i915/"
cannot send file with empty name in "/mnt/usbdisk/dietpi-backup/data/usr/share/zoneinfo/America/North_Dakota/"
cannot send file with empty name in "/mnt/usbdisk/dietpi-backup/data/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/b/717d5274932b4c45391897ead87b49dde8087bc.bundle/Contents/Thumbnails/"
done
That’s typical in backups, the backup is done… but now restoring it is another different story. I am installing from scratch and copying all configurations, might be easier
