DietPi version |
cat /boot/dietpi/.version -
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=9
G_DIETPI_VERSION_RC=0
G_LIVE_PATCH_STATUS[2]=‘not applicable’ -
Distro version |
bookworm -
Kernel version |
uname --all -
Linux DietPi 6.6.54-current-rockchip #1 SMP Fri Oct 4 14:30:05 UTC 2024 armv7l GNU/Linux
Architecture |
dpkg --print-architecture -
armhf
SBC model |
ASUS Tinker Board (armv7l) -
benchtop psu at 5.1V via diy heavy gauge micro usb cable (have also tried with GPIO pins) -
Sandisk Industrial 32GB
- sudo shutdown now
- board should stop drawing power after shutdown
- board still draws around 360mA (with nothing plugged in, more with usb devices connected)
With ASUS’s Tinker OS the board stops drawing power after shutdown. With DietPi and also with Armbian, the board continues to draw power after shutdown.
Is there something I can do (other than turning it off at the wall) to make it shut down power like with Tinker OS? My linux knowledge is very limited.
To be honest, it’s not a huge problem since I turn my 3d printer off anyway with a wifi power socket but I am a bit worried that maybe it’s not shutting down properly.
