Thanks and a problem
I just installed dietpi on a 4B, first time for the distro and first RPi.
This is great stuff!
Everything was intuitive, absolutely no problems until after a couple of reboots.
All my dietpi software is gone. No cpu, no dietpi-config, no dietpi-anything.
What could have happened and how do I fix this? apt search dietpi comes back with nothing.
Thanks,
John
dietpi is not an apt package you can install. It’s a set of bash scripts located on /boot/dietpi
Can you check if it is still there?
Thank you, yes.
I see I shot myself in the ass on this one by including unalias -a in my .bash_profile
Thanks for the help and the fast answer!
BTW, unset HISTFILE doesn’t seem to stop .bash_history from being created although it works for me on my other Linux boxes. Is there a Debian-approved way to fix this?
not sure if this is Debian specific but you could try running bellow command if you like to disable command history system wide
echo 'set +o history' >> /etc/profile
Thanks, I’ll try it asap. I read that caused that even temporary command history is unavailable in the shell, which is not what I wanted.
Maybe I needed to do history -c, after that it seems to behave as I saw elsewhere. Not sure why it was need on this distro though.
at the end DietPi is not an own OS. We use a base image to have our shell scripts running on. And thinks like this are depending on the OS used. In case of Raspberry Pi it is Raspberry OS
I understand. And you guys did a fantastic job.
