Strange problem with scp
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=9
    G_DIETPI_VERSION_RC=0
    G_LIVE_PATCH_STATUS[2]=‘not applicable’
    G_LIVE_PATCH_STATUS[3]=‘not applicable’
    bookworm
    Linux t62.FQDN 6.1.84-vendor-rk35xx #1 SMP Tue Dec 24 13:36:04 UTC 2024 aarch64 GNU/Linux
    arm64
    NanoPi 6 series (aarch64)
    Mean Well LRS-50-12 (50W/12V)
    System is running from the eMMC
    scp
    Freshly
    Duno
Add this line :
neofetch
at the end of $HOME/.bashrc
As this line do not break anything in Debian, I expect DietPi to act the same way.
ssh works normally, but opposite to all other machines, scp is failing, saying it received a too long string - insisting on tab shows a lot of backslashes.
I commented my line and everything came back to normal.
This is weird as it looks like a very old bug in the ssh server.
Another (funny) thing is DietPi is reversing all devices order (mmcblk 0 and 1, eth 0 and 1) but it is not a bug, just a bit strange.
When you include neofetch in .bashrc, it outputs system information every time a new shell session is initiated, even in non-interactive sessions (like SCP).
So you can add a condition to only execute if in non-interactive sessions:
if [ -n "$PS1" ]; then
    neofetch
fi
or test if SSH_TTY is set, it’s also only set in ssh sessions but not scp
if [ -n "$SSH_TTY" ]; then /usr/bin/neofetch; fi
Thanks a lot Jappe, as I took my .bashrc from Debian, PS1 is always defined, but SSH_TTY did the trick.
