Hy,
i used xu4 with the latest dietpi. But i dont have sound.
root@DietPi:/etc# aplay -l
card 0: OdroidXU4 [Odroid-XU4], device 0: Primary multicodec-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
root@DietPi:/etc# cat /etc/asound.conf
pcm.!default {
type hw
card 0
device 0
#format S16_LE
#channels 2
#rate 44100
ctl.!default {
type hw
card 0
The sound test is well played.
root@DietPi:/etc# speaker-test -c2
speaker-test 1.1.3
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 128 to 131072
Period size range from 64 to 65536
Using max buffer size 131072
Periods = 4
was set period_size = 32768
was set buffer_size = 131072
0 - Front Left
1 - Front Right
Time per period = 2,751413
0 - Front Left
1 - Front Right
^CTime per period = 3,833856
Bad information. This is 16 bit, 44kHz file.
root@DietPi:/etc# aplay /mnt/data/dietpi_userdata/Music/Andy\ C\ -\ Nightlife\ 6/01\ -\ DC\ Breaks\ -\ Shaman\ \(Original\ Mix\).mp3 -V -v
Playing raw data '/mnt/data/dietpi_userdata/Music/Andy C - Nightlife 6/01 - DC Breaks - Shaman (Original Mix).mp3' : Unsigned 8 bit, Rate 8000 Hz, Mono
aplay: set_params:1299: Sample format non available
Available formats:
- S16_LE
- S24_LE
Kodi is stop playing the movie, and no sound.
How can i solve the issue?
