installed v8.23 on rock 5b
NO SOUND start off after install any clues ?
in the audio config e8316 which is h.4 on the list I have highlighted it
still no sound ALSA is activated
audio conversion on
any help would be appreciated
audio conversion on
Via HDMI or 3.5mm jack?
Can you show output of aplay -L
please.
root@DietPi:~# aplay-l
bash: aplay-l: command not found
root@DietPi:~# Aplay-L
bash: Aplay-L: command not found
root@DietPi:~# aplay-L
bash: aplay-L: command not found
root@DietPi:~# aplay -l
card 0: rockchiphdmi0 [rockchip-hdmi0], device 0: rockchip-hdmi0 i2s-hifi-0 [rockchip-hdmi0 i2s-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: rockchiphdmi1 [rockchip-hdmi1], device 0: rockchip-hdmi1 i2s-hifi-0 [rockchip-hdmi1 i2s-hifi-0]
Subdevices: 1/1
card 2: rockchipdp0 [rockchip,dp0], device 0: rockchip,dp0 spdif-hifi-0 [rockchip,dp0 spdif-hifi-0]
Subdevices: 1/1
card 4: rockchipes8316 [rockchip-es8316], device 0: dailink-multicodecs ES8316 HiFi-0 [dailink-multicodecs ES8316 HiFi-0]
Subdevices: 0/1
What happens when you do
aplay -Dhw:4,0 test.wav
card 4 device 0 should be the 3.5mm jack. If you want to test HDMI output just change the device number.
Alsa Lib Pcm, C:2660: (snd_pcm_open_noupdate) unkowen PCM fw:4.0 aplay :main 830: audio open error : no such file or directory
this is what I get back from typing in the command line
Yes makes sense, since aplay gave back Subdevices: 0/1
for this card. Maybe there is a overlay or something missing?
@MichaIng can surely help
Are you sure that this was not a typo “fw:0,4” vs “hw:0,4”?
If you selected card 4 via dietpi-config
, can you show the output of:
cat /etc/asound.conf
speaker-test
