Sound card code always changed randomly
I use Dietpi Native PC on mini PC BeeLink. And after rebooting, sound card id always change but randomly. First time hw:1,3 hw:1,7 hw:1,8 than next time change to hw:0,3 hw:0,7 hw:0,8.
Than after rebooting I should change sound card from dietpi-config
DietPi version | cat /boot/dietpi/.version
Distro version | echo $G_DISTRO_NAME $G_RASPBIAN
Kernel version | uname --all
Architecture | dpkg --print-architecture
SBC model | echo $G_HW_MODEL_NAME
or (EG: RPi3)
Best regards
Thanks
Hello, anyone can help me to solve this problem?
Jappe
27 January 2025 10:36
3
CAn you please fill out the troubleshoot templateE:
SBC model | echo $G_HW_MODEL_NAME or (EG: RPi3)
And can you share the output of
aplay -l
cat /etc/asound.conf
Jappe:
aplay -l
# aplay -l
card 0: Audio [KT USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
Jappe:
# cat /etc/asound.conf
pcm.!default {
type hw
card 0
device 3
ctl.!default {
type hw
card 0
What should I change?
Thanks in advance
@MichaIng can you have a look pls.
Jappe
28 January 2025 12:37
9
So card 0 is USB audio and card 1 is HDMI
You can change your alsa conf to the following, if you want to use USB:
pcm.!default {
type hw
card Audio
device 0
ctl.!default {
type hw
card Audio
Then restart alsa
sudo systemctl restart alsa
Thanks for your suggestion. If I want to use HDMI, how to modify config?
Thanks
Jappe
28 January 2025 14:15
11
Then just change the card type from Audio
to PCH
and select the HDMI output you wanna use, like:
pcm.!default {
type hw
card PCH
device 3
ctl.!default {
type hw
card PCH
Still change randomly after twice rebooting. Before this hw:0,3 hw:0,7 and hw:0,8, after rebooting it changes to hw:1,3 hw:1,7 and hw:1,8. Where set 0 and 1 for soundcard?
Thanks
