Sonarr Mono is not running with --debug switch
Hello
The last few days in sonarr I get this error in logs Mono is not running with --debug switch
Sonarr is running but doesn’t perform automatically search for the missing episodes
I tried this command
/usr/bin/mono -O=-aot /opt/NzbDrone/NzbDrone.exe -nobrowser -data=/mnt/dietpi_userdata/sonarr
But I get the below
Cannot open assembly ‘/opt/NzbDrone/NzbDrone.exe’: No such file or directory.
Any advice how can I fix it?
Was there an issue of filling the troubleshooting template?
not sure if there is a misunderstanding. But NzbDrone was an old name/executable for Sonarr. Nowadays we start Sonarr using
/usr/bin/mono /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/mnt/dietpi_userdata/sonarr
Thank you for your reply
I tried the above and I get the below
[Warn] MonoDebugCheck: Mono is not running with --debug switch
I think you need to add --debug to get rid of this warning: https://www.mono-project.com/docs/debug+profile/debug/
/usr/bin/mono --debug /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/mnt/dietpi_userdata/sonarr
this is a warning, northing more and you should be able to ignore them.
