SOLVED : Networking and samba
Hello!
I’m trying to mount a samba share, the share is in my network, I had made some homework and I have
the cifs-utils installed, and I have made several tries in dietpi-drive manager, with user password and global password.
Here is my system I try to mount the share
DietPi v8.2.2 : 11:10 - Tue 03/22/22
 - Device model : Native PC (x86_64)
 - CPU temp : 38 °C / 100 °F : Cool runnings
System:
  Kernel: 5.10.0-12-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
  Desktop: LXDE 0.10.1 Distro: Debian GNU/Linux 11 (bullseye)
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
  v: 0975100000405F00001620180 serial: <filter>
  Mobo: Hewlett-Packard model: 22CE v: 93.32 serial: <filter>
  UEFI [Legacy]: Insyde v: F.42 date: 11/04/2015
Battery:
  ID-1: BAT1 charge: 28.0 Wh condition: 36.2/36.2 Wh (100%)
  model: 13-14 OA04041 status: Charging
CPU:
  Info: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
  bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 2 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 15969
  Speed: 1608 MHz min/max: 1000/1800 MHz boost: enabled Core speeds (MHz):
  1: 1608 2: 1795 3: 1790 4: 1918
my samba share is on another raspi pi 3b+ running dietpi 6.x.x .
Also when I try open PCmanFM and Thunar and press Go and select Network I get a Error sign
that tells me that operation not supported both in root and in dietpi user mode.
I also have minidlna-server install at the samba server and that works as it should.
And I have checked all logs in /var/log but they are empty.
I can come back later and post my errors when I try to mount my samba share in dietpi-drive-manager.
Probably is there something i just forgot to install or some other user error.
Cheers
-----UPDATES-----
I installed the gvfs-backends package, and now I get no prompt when trying to open network in File manager.
more updates in a couple of hours.
Are you trying to login with the valid user for that share and with the password created with smbpasswd ?
Maybe you can share all relevante information of the Server as well on the Client side
  • Kernel version | uname -a
Maybe the samba package running on the DietPi 6.x system is to old and not working together with the client running DietPi 8.x
of course
First server side
cat /boot/dietpi/.version
_DIETPI_VERSION_CORE=6
G_DIETPI_VERSION_SUB=34
G_DIETPI_VERSION_RC=3
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
buster 1
uname -a
Linux MopidyNest 5.4.83-v7+ #1379 SMP Mon Dec 14 13:08:57 GMT 2020 armv7l GNU/Linux
echo $G_HW_MODEL_NAME
RPi 3 Model B (armv7l)
Client side where I try to mount the samba share to:
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=2
G_DIETPI_VERSION_RC=2
bullseye
uname -a
Linux Unicron-II-PC 5.10.0-12-amd64 #1 SMP Debian 5.10.103-1 (2022-03-07) x86_64 GNU/Linux
Native PC (x86_64)
additional info I change samba password to a new fresh
I have set the share path as in drive manager first ip number then path dietpi/mnt/externaldrive , set user as dietpi as written in smb.conf at server side, and then password.
Error log from driver manager
[FAILED] Samba mount failed with the following error output:                                                         │
         │ mount error(2): No such file or directory        │
         │ Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)                         │
         │ mount error(20): Not a directory        │
log from driver-manager
[ INFO ] DietPi-Drive_Manager | Detecting drives, please wait...
[ INFO ] DietPi-Drive_Manager |  - Detected mounted physical drive: /dev/sda1 > /
[ INFO ] DietPi-Drive_Manager |  - Detected unformatted drive: /dev/sr0
[  OK  ] DietPi-Drive_Manager | mv .fstab /etc/fstab
[  OK  ] DietPi-Drive_Manager | systemctl daemon-reload
[ INFO ] DietPi-Drive_Manager | Checking for required APT packages: e2fsprogs
[  OK  ] DietPi-Drive_Manager | sync
[ INFO ] DietPi-Drive_Manager | Checking for required APT packages: cifs-utils smbclient
[  OK  ] DietPi-Drive_Manager | Desired setting in /boot/dietpi/.installed was already set: aSOFTWARE_INSTALL_STATE[1]=2
[  OK  ] DietPi-Drive_Manager | mkdir -p /mnt/samba
[ INFO ] DietPi-Drive_Manager | Attempting to mount with CIFS version: 3.1.1
[ INFO ] DietPi-Drive_Manager | Attempting to mount with CIFS version: 3.0
[ INFO ] DietPi-Drive_Manager | Attempting to mount with CIFS version: 2.1
[ INFO ] DietPi-Drive_Manager | Attempting to mount with CIFS version: 2.0
[ INFO ] DietPi-Drive_Manager | Attempting to mount with CIFS version: 1.0
Setting the share name dietpi/mnt/externaldrive is incorrect. The share is called dietpi only on our default configuration. And on a default setup, it will point to directory /mnt/dietpi_userdata on server side.
Yes! that was the problem, thanks ,
Solution
<IP-ADRESS> /DIETPI>
I shall remember that to next time.
