[solved] mpd + ympd -- ympd web says 'not authorized' / ympd logs show fail to connect
:check_box_with_check: I have searched the existing open and closed issues
  • DietPi version 10.0.1 / master
  • Distro version: trixie 1
  • Kernel version: Linux DietPi 6.12.62+rpt-rpi-v6 #1 Raspbian 1:6.12.62-1+rpt1 (2025-12-18) armv6l GNU/Linux
  • Architecture armhf
  • SBC model: RPi B / RPi Zero W
  • Power supply used: 5A USB
  • SD card used: SanDisk 16 GB
  1. Install fresh MPD and ympd
  2. Confirm MPD OK by playing music from any other MPD client
  3. Attempt to control MPD via ympd’s http://diept:1337/
  • YMPD’s web tool says ‘connected’ and then shows MPD library and current play queue
  • YMPD Web says ‘connected’ once, then all other actions have a status block ‘not authorized’
  • YMPD’s log files show `MPD connection: no such file or directory / MPD connection failed.
  • The MPD suite is socket-activated by systemd but the ypmd.service file depends on ympd.service and not ympd.socket. Changing the ympd.service dependency so that ympd service runs only after systemd has created the required /run/mpd/socket file allows ympd to connect and control the mpd service.
  • I’ve made a PR for this small change.
  • Thanks to the community and to Micha for this great project.
I recommend staying on Github with this. Just to keep everything on one place mpd + ympd -- ympd web says 'not authorized' / ympd logs show fail to connect by k3ninho · Pull Request #7986 · MichaIng/DietPi · GitHub
