I follow the procedure
-dietpi
-Raspberry Pi using Peter Scargill’s script
Mosquitto
Node-Red
In Node-Red I try a flow that uses mqtt in / out the state of is connecting and connected !!
but
dietpi-launcher
nmbd : active | Affinity 0-0
smbd : active | Affinity 0-0
apache2 : active | Affinity 0-0
mosquitto : active | Affinity 0-
node-red : active | Affinity 0-0
cron : active | Affinity 0-0
ssh : active | Affinity 0-0
vncserver : active | Affinity 0-0
root@Natacha:~# service mosquitto status
● mosquitto.service - LSB: mosquitto MQTT v3.1 message broker
Loaded: loaded (/etc/init.d/mosquitto; generated; vendor preset: enabled)
Active: active (running) since Sat 2019-11-30 17:03:59 CET; 8min a
go
Docs: man:systemd-sysv-generator(8)
Process: 967 ExecStart=/etc/init.d/mosquitto start (code=exited, status=0/SUCC
ESS)
CGroup: /system.slice/mosquitto.service
└─972 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
nov 30 17:03:58 Natacha systemd[1]: Starting LSB: mosquitto MQTT v3.1 message br
oker...
nov 30 17:03:59 Natacha mosquitto[967]: Starting network daemon:: mosquitto.
nov 30 17:03:59 Natacha systemd[1]: Started LSB: mosquitto MQTT v3.1 message bro
ker.
root@Natacha:~# netstat -tlnp | grep mosq
tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 972/mosquitto
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 972/mosquitto
tcp6 0 0 :::1883 :::* LISTEN 972/mosquitto
if I kill the kill (by htop) and
root@Natacha:~# mosquitto -v
1575131094: mosquitto version 1.4.10 (build date Wed, 13 Feb 2019 00:45:38 +0000) starting
1575131094: Using default config.
1575131094: Opening ipv4 listen socket on port 1883.
1575131094: Opening ipv6 listen socket on port 1883.
1575131097: New connection from 192.168.1.101 on port 1883.
1575131097: New client connected from 192.168.1.101 as Test (c1, k60).
1575131097: Sending CONNACK to Test (0, 0)
1575131097: Received SUBSCRIBE from Test
1575131097: sensors/# (QoS 0)
1575131097: Test 0 sensors/#
1575131097: Sending SUBACK to Test
when the process is finished the state connecting
Why when the boot is done node-red mqtt in / out the state of is connecting
