hello i have a raspberry pi 4 4gb with 16gb sdcard installed dietpi, and an external hd 3tb , i would like to know how to move the /var/lib/plexmediaserver folder to the external hd (dietpiuserdata) thanks.
well theoretically you could move the entire plexmediaserver folder to your HDD using mv command and created a symbolic link from /var/lib/plexmediaserver to the new location.
thank you, worked perfectly
