Showing banner current RAM usage doesn't work
Hello, when updating my dietpi to 9.2 the new function of showing the ram in the banner is not working, does anyone know if it is a bug or do I need to apply some command to make it work?
Did you tried running dietpi-banner to configure the fields shown?
Yes, but I hadn’t seen the option, I restarted the machine here and it appeared, I don’t know if it was an oversight on my part that I didn’t see or it only worked after restarting, thanks anyway, It was probably my mistake.
