Hi, I’m trying to use Shairport with my USB DAC. Using aplay -l, I see that it is hw:1 and so in /usr/local/etc/shairport-sync.conf, I added the following under alsa:
alsa =
output_device = “hw:1”;
output_rate = 44100;
output_format = “S32”;
// mixer_control_name = “PCM”;
// output_rate = 44100; // can be 44100, 88200, 176400 or 352800
// output_format = “S16”; // can be “U8”, “S8”, “S16”, “S24”, “S24_3LE”, "S24_$
However, when I play, I do not get any sound. Doing some googling, I see that output_format has to be supported by my DAC (Auralic Vega) and through trial and error, I think S32 is supported because when I try the other settings, when I play and so a systemctl status shairport-sync -l, I see error messages and when I use S32, I don’t get an error message.
However, I am still not getting any sound. I will note the HQplayer NAA and Raspotify play fine and I get sound.
Any thoughts would be greatly appreciated! Thank you!
