thanks for trying so hard. I was just trying again to reproduce it.
I have to be in the TSDash folder and call java.
But when I do that then java can’t find any files.
It can find the TSDash.jar when I am calling it out of the java folder, but then looks for TSDash.properties where I am calling it from.
I need to be in the TSDash folder and get java to open TSDash.jar
how do I do that?
when I am in the TSDash folder then it can’t find any files.
but when I am in the java folder then it can find the TSDash.jar but will be looking for the TSDash.properties in the java folder …
executing out of the java folder: It is looking for the TSDash.properties inside the java folcer
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# java -jar /home/tsdash/TSDash/TSDash.jar
Jar Name:TSDash.jar
ERROR loading TSDash.properties
java.io.FileNotFoundException: TSDash.properties (No such file or directory)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(Unknown Source)
at java.base/java.io.FileInputStream.<init>(Unknown Source)
at p.a.c(Unknown Source)
at p.a.d(Unknown Source)
at p.a.a(Unknown Source)
at p.a.f(Unknown Source)
at p.a.h(Unknown Source)
at p.a.t(Unknown Source)
at ecuhubdash.EcuHubDash.main(Unknown Source)
Looking in: /usr/lib/jvm/temurin-8-jre-arm64/bin/.
Registration file not found.
19/09/2025, 19:06:51 :Debug: Unable to load user properties, looking in:
We are almost there. Why can it not find the TSDash.jar when I am inside the TSDash folder?
root@DietPi:/home/tsdash/TSDash# java -jar /home/tsdash/TSDash/TSDash.jar
Jar Name:TSDash.jar
19/09/2025, 19:10:04 :Debug: Unable to load user properties, looking in:
/home/tsdash/TSDash/.
root@DietPi:/home/tsdash/TSDash# java -jar TSDash.jar
Jar Name:TSDash.jar
19/09/2025, 19:10:22 :Debug: Unable to load user properties, looking in:
root@DietPi:/home/tsdash/TSDash# /usr/lib/jvm/temurin-8-jre-arm64/bin/java -jar TSDash.jar
Jar Name:TSDash.jar
19/09/25 19:11:26 :Debug: Unable to load user properties, looking in:
root@DietPi:/home/tsdash/TSDash# /usr/lib/jvm/temurin-8-jre-arm64/bin/java -jar /home/tsdash/TSDash/TSDash.jar
Jar Name:TSDash.jar
19/09/25 19:12:15 :Debug: Unable to load user properties, looking in:
changing the java version:
root@DietPi:/home/tsdash/TSDash# java -version
openjdk version "21.0.8" 2025-07-15 LTS
OpenJDK Runtime Environment Temurin-21.0.8+9 (build 21.0.8+9-LTS)
OpenJDK 64-Bit Server VM Temurin-21.0.8+9 (build 21.0.8+9-LTS, mixed mode, sharing)
root@DietPi:/home/tsdash/TSDash# sudo update-alternatives --config java
There are 3 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/temurin-21-jre-arm64/bin/java 2112 auto mode
1 /usr/lib/jvm/temurin-11-jre-arm64/bin/java 1112 manual mode
2 /usr/lib/jvm/temurin-21-jre-arm64/bin/java 2112 manual mode
3 /usr/lib/jvm/temurin-8-jre-arm64/bin/java 1082 manual mode
Press <enter> to keep the current choice[*], or type selection number: 3
update-alternatives: using /usr/lib/jvm/temurin-8-jre-arm64/bin/java to provide /usr/bin/java (java) in manual mode
openjdk version "1.8.0_462"
OpenJDK Runtime Environment (Temurin)(build 1.8.0_462-b08)
OpenJDK 64-Bit Server VM (Temurin)(build 25.462-b08, mixed mode)
copied TSDash.properties to the location where it will be looking for it:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# /usr/lib/jvm/temurin-8-jre-arm64/bin/java -jar /ho me/tsdash/TSDash/TSDash.jar
Jar Name:TSDash.jar
19/09/25 19:35:05 :Debug: Unable to load user properties, looking in:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# ls
java keytool pack200 rmid servertool TSDash.properties
jjs orbd policytool rmiregistry tnameserv unpack200
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# rm TSDash.properties
java jjs keytool orbd pack200 policytool rmid rmiregistry servertool tnameserv unpack200
Jar Name:TSDash.jar
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at java.io.FileInputStream.<init>(FileInputStream.java:93)
19/09/25 19:35:43 :Debug: Unable to load user properties, looking in:
I will try to extract the TSDash files into the java folder …
java keytool pack200 rmid servertool TSDash unpack200
jjs orbd policytool rmiregistry tnameserv TSDash_v0.9.09.02_Beta.tar.gz
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# cd TSDash
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TSDash# ls
config inc Projects Staging.class tsdash.png TSDash.sh
Dash lib README.txt TSDash.jar TSDash.properties web
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TSDash# cp *.* /usr/lib/jvm/temurin-8-jre-arm64/bin
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TSDash# cd ..
java pack200 rmiregistry TSDash TSDash.sh
jjs policytool servertool TSDash.jar TSDash_v0.9.09.02_Beta.tar.gz
keytool README.txt Staging.class tsdash.png unpack200
orbd rmid tnameserv TSDash.properties
it’s a mess:
java orb.db rmid tnameserv TSDash.properties
jjs pack200 rmiregistry TSDash TSDash.sh
keytool policytool servertool TSDash.jar TSDash_v0.9.09.02_Beta.tar.gz
orbd README.txt Staging.class tsdash.png unpack200
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# java -jar TSDash.jar
Jar Name:TSDash.jar
19/09/2025, 19:48:02 :Debug: Unable to load user properties, looking in:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# /usr/lib/jvm/temurin-21-jre-arm64/bin/java -jar /usr/lib/jvm/temurin-8-jre-arm64/bin/TSDash.jar
Jar Name:TSDash.jar
19/09/2025, 19:49:13 :Debug: Unable to load user properties, looking in:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# /usr/lib/jvm/temurin-8-jre-arm64/bin/java -jar /usr/lib/jvm/temurin-8-jre-arm64/bin/TSDash.jar
Jar Name:TSDash.jar
19/09/25 19:49:31 :Debug: Unable to load user properties, looking in:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# ./TSDash.sh
Jar Name:TSDash.jar
19/09/2025, 19:52:14 :Debug: Unable to load user properties, looking in:
now with tunerstudio installed:
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TunerStudioMS# /usr/lib/jvm/temurin-21-jre-arm64/bin/java -jar TunerStudioMS.jar
Jar Name:TunerStudioMS.jar
19/09/2025, 20:13:10 :Info: gupam
19/09/2025, 20:13:10 :Debug: Unable to load user properties, looking in:
/usr/lib/jvm/temurin-8-jre-arm64/bin/TunerStudioMS/.
19/09/2025, 20:13:10 :Debug: hid: 653.92053
19/09/2025, 20:13:38 :Info: gupam
19/09/2025, 20:13:39 :Debug: hid: 484.9717
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TunerStudioMS# ls
config help License.rtf plugins Staging.class TunerStudio.properties
content inc License.txt Projects TSicon.ico TunerStudio.sh
Dash lib LogViewer.properties README.TXT TunerStudioMS.jar TuneView
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TunerStudioMS# cp *.* /usr/lib/jvm/temurin-8-jre-arm64/bin/
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin/TunerStudioMS# cd ..
java pack200 tnameserv TunerStudioMS
jjs policytool TSDash TunerStudioMS.jar
keytool README.txt TSDash.jar TunerStudioMS_v3.3.00.tar.gz
License.rtf README.TXT tsdash.png TunerStudio.properties
License.txt rmid TSDash.properties TunerStudio.sh
LogViewer.properties rmiregistry TSDash.sh unpack200
orbd servertool TSDash_v0.9.09.02_Beta.tar.gz
orb.db Staging.class TSicon.ico
root@DietPi:/usr/lib/jvm/temurin-8-jre-arm64/bin# /usr/lib/jvm/temurin-21-jre-arm64/bin/java -jar TunerStudioMS.jar
19/09/2025, 20:14:43 :Info: gupam
19/09/2025, 20:14:44 :Debug: hid: 517.5082
well it seem to be missing a registration file, possibly this is the paid version only?
