I am finding it difficult to connect radarr with rutorrent. I am using the default configuration for rutorrent. Can someone help with what needs to be updated in radarr in the Port and Url Path section. Thanks
pls can you share the DietPi version you are running on? As well pls post following output
ls -la /etc/lighttpd/conf-{enabled,available}
cat /etc/lighttpd/lighttpd.conf
I am on DietPi v7.2.3. Here you go for the rest:
First Output
/etc/lighttpd/conf-available:
total 144
drwxr-xr-x 2 root root 4096 Jun 1 20:33 .
drwxr-xr-x 4 root root 4096 May 2 10:52 ..
-rw-r--r-- 1 root root 839 Jan 28 2019 05-auth.conf
-rw-r--r-- 1 root root 91 Jan 28 2019 10-accesslog.conf
-rw-r--r-- 1 root root 396 Jan 28 2019 10-cgi.conf
-rw-r--r-- 1 root root 63 Jan 28 2019 10-dir-listing.conf
-rw-r--r-- 1 root root 36 Jan 28 2019 10-evasive.conf
-rw-r--r-- 1 root root 128 Jan 28 2019 10-evhost.conf
-rw-r--r-- 1 root root 104 Jan 28 2019 10-expire.conf
-rw-r--r-- 1 root root 177 Jan 28 2019 10-fastcgi.conf
-rw-r--r-- 1 root root 42 Jan 28 2019 10-flv-streaming.conf
-rw-r--r-- 1 root root 82 Jan 28 2019 10-no-www.conf
-rw-r--r-- 1 root root 849 Jan 28 2019 10-proxy.conf
-rw-r--r-- 1 root root 176 Jan 28 2019 10-rewrite.conf
-rw-r--r-- 1 root root 253 Jan 28 2019 10-rrdtool.conf
-rw-r--r-- 1 root root 398 Jan 28 2019 10-simple-vhost.conf
-rw-r--r-- 1 root root 449 Jan 28 2019 10-sockproxy.conf
-rw-r--r-- 1 root root 99 Jan 28 2019 10-ssi.conf
-rw-r--r-- 1 root root 203 Feb 23 2019 10-ssl.conf
-rw-r--r-- 1 root root 460 Jan 28 2019 10-status.conf
-rw-r--r-- 1 root root 450 Jan 28 2019 10-userdir.conf
-rw-r--r-- 1 root root 38 Jan 28 2019 10-usertrack.conf
-rw-r--r-- 1 root root 168 Jan 28 2019 11-extforward.conf
-rw-r--r-- 1 root root 372 Sep 19 2020 15-fastcgi-php.conf
-rw-r--r-- 1 root root 2208 May 31 09:28 50-dietpi-https.conf
-rw-r--r-- 1 root root 508 Jan 28 2019 90-debian-doc.conf
-rw-r--r-- 1 root root 134 May 31 09:28 98-dietpi-hsts.conf
-rw-r--r-- 1 root root 221 May 31 09:28 98-dietpi-https_redirect.conf
-rw-r--r-- 1 root root 655 Jun 1 20:33 98-dietpi-rtorrent.conf
-rw-r--r-- 1 root root 338 Apr 14 16:20 99-dietpi-dav_redirect.conf
-rw-r--r-- 1 root root 1203 Sep 19 2020 99-dietpi-nextcloud.conf
-rw-r--r-- 1 root root 1299 May 12 22:29 99-dietpi-nextcloud.conf.dietpi-new
-rw-r--r-- 1 root root 189 Oct 1 2020 99-dietpi-pihole-block_public_admin.conf
-rw-r--r-- 1 root root 887 Oct 1 2020 99-dietpi-pihole.conf
-rw-r--r-- 1 root root 162 Jan 28 2019 99-unconfigured.conf
-rw-r--r-- 1 root root 843 Jan 28 2019 README
/etc/lighttpd/conf-enabled:
total 12
lrwxrwxrwx 1 root root 33 Sep 19 2020 10-fastcgi.conf -> ../conf-available/10-fastcgi.conf
lrwxrwxrwx 1 root root 33 Sep 19 2020 10-rewrite.conf -> ../conf-available/10-rewrite.conf
lrwxrwxrwx 1 root root 37 Sep 19 2020 15-fastcgi-php.conf -> ../conf-available/15-fastcgi-php.conf
lrwxrwxrwx 1 root root 38 Nov 21 2020 50-dietpi-https.conf -> ../conf-available/50-dietpi-https.conf
lrwxrwxrwx 1 root root 37 Nov 21 2020 98-dietpi-hsts.conf -> ../conf-available/98-dietpi-hsts.conf
lrwxrwxrwx 1 root root 47 Nov 21 2020 98-dietpi-https_redirect.conf -> ../conf-available/98-dietpi-https_redirect.conf
lrwxrwxrwx 1 root root 41 Jun 1 20:33 98-dietpi-rtorrent.conf -> ../conf-available/98-dietpi-rtorrent.conf
lrwxrwxrwx 1 root root 45 Sep 19 2020 99-dietpi-dav_redirect.conf -> ../conf-available/99-dietpi-dav_redirect.conf
-rw-r--r-- 1 root root 187 Apr 14 16:25 99-dietpi-dav_redirect.conf.save
lrwxrwxrwx 1 root root 42 Sep 19 2020 99-dietpi-nextcloud.conf -> ../conf-available/99-dietpi-nextcloud.conf
lrwxrwxrwx 1 root root 58 Sep 20 2020 99-dietpi-pihole-block_public_admin.conf -> ../conf-available/99-dietpi-pihole-block_public_admin.conf
lrwxrwxrwx 1 root root 39 Sep 19 2020 99-dietpi-pihole.conf -> ../conf-available/99-dietpi-pihole.conf
lrwxrwxrwx 1 root root 38 Sep 19 2020 99-unconfigured.conf -> ../conf-available/99-unconfigured.conf
Second Output
server.modules = (
"mod_indexfile",
"mod_setenv",
"mod_access",
"mod_alias",
"mod_redirect",
server.document-root = "/var/www"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.max-worker = 4
# strict parsing and normalization of URL for consistency and security
# https://redmine.lighttpd.net/projects/lighttpd/wiki/Server_http-parseoptsDetails
# (might need to explicitly set "url-path-2f-decode" = "disable"
# if a specific application is encoding URLs inside url-path)
server.http-parseopts = (
"header-strict" => "disable",# default
"host-strict" => "disable",# default
"host-normalize" => "disable",# default
"url-normalize-unreserved"=> "disable",# recommended highly
"url-normalize-required" => "disable",# recommended
"url-ctrls-reject" => "disable",# recommended
"url-path-2f-decode" => "disable",# recommended highly (unless breaks app)
#"url-path-2f-reject" => "disable",
"url-path-dotseg-remove" => "disable",# recommended highly (unless breaks app)
#"url-path-dotseg-reject" => "disable",
#"url-query-20-plus" => "disable",# consistency in query string
index-file.names = ( "index.php", "index.html" )
url.access-deny = ( "~", ".inc" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
include_shell "/usr/share/lighttpd/create-mime.conf.pl"
include "/etc/lighttpd/conf-enabled/*.conf"
#server.compat-module-load = "disable"
server.modules += (
"mod_compress",
"mod_dirlisting",
"mod_staticfile",
Thanks for responding.
ok configuration looks fine.
The password you have entered is your global application password?
Yes
can you try to re-enter the password. I did a test installation and for me this was working fine.
I am away from the system. I will test and report back.
I tried rentering the password but it gives me the same error. Following is the error log from radarr
2021-06-04 07:57:14.1|Error|RTorrent|Failed to test rTorrent
[v3.2.1.5070] NzbDrone.Core.Download.Clients.DownloadClientException: Unable to connect to rTorrent, please check your settings
---> CookComputing.XmlRpc.XmlRpcServerException: Unauthorized
at CookComputing.XmlRpc.XmlRpcClientProtocol.ReadResponse(XmlRpcRequest req, WebResponse webResp, Stream respStm, Type returnType)
at CookComputing.XmlRpc.XmlRpcClientProtocol.Invoke(Object clientObj, MethodInfo mi, Object[] parameters)
at CookComputing.XmlRpc.XmlRpcClientProtocol.Invoke(MethodInfo mi, Object[] parameters)
at XmlRpcProxyce5c6d78-4972-4f13-ac13-69fef1de3071.GetVersion()
at NzbDrone.Core.Download.Clients.RTorrent.RTorrentProxy.<>c__DisplayClass2_0.<GetVersion>b__0() in D:\a\1\s\src\NzbDrone.Core\Download\Clients\rTorrent\RTorrentProxy.cs:line 67
at NzbDrone.Core.Download.Clients.RTorrent.RTorrentProxy.ExecuteRequest[T](Func`1 task) in D:\a\1\s\src\NzbDrone.Core\Download\Clients\rTorrent\RTorrentProxy.cs:line 262
--- End of inner exception stack trace ---
at NzbDrone.Core.Download.Clients.RTorrent.RTorrentProxy.ExecuteRequest[T](Func`1 task) in D:\a\1\s\src\NzbDrone.Core\Download\Clients\rTorrent\RTorrentProxy.cs:line 266
at NzbDrone.Core.Download.Clients.RTorrent.RTorrentProxy.GetVersion(RTorrentSettings settings) in D:\a\1\s\src\NzbDrone.Core\Download\Clients\rTorrent\RTorrentProxy.cs:line 67
at NzbDrone.Core.Download.Clients.RTorrent.RTorrent.TestConnection() in D:\a\1\s\src\NzbDrone.Core\Download\Clients\rTorrent\RTorrent.cs:line 203
it looks like an authorization issue. Something seems to be wrong with user/password I guess
I am going to use qbittorrent. Not sure what was the issue. I am able to autheticate via web broser. Not sure what is wrong with radarr. Thanks for the help.
ok strange indeed. But good you found an alternative.
