I did this and then spent a few hours trying all my USB flash drives - none worked - unless you had a FAT 32 formatted SD card with bootcode.bin on it in the SD slot - but what’s the point of that?
Read in the Pi forum that pink Silicon Power drives worked - the other ones said to work are the more expensive Samsung and Sandisk brands.
Got an 8 GB pink Silicon Power USB 2.0 and then followed this guide:
Thanks for sharing your results and info, much appreciated.
We have a request for adding SD > USBHDD feature into DietPi, so i’ll make a note to check your post in detail when we start work on it: https://github.com/Fourdee/DietPi/issues/509
I’m not that impressed with this setup as it is very slow and if you try to edit config files with WinSCP it can time out. This may be a feature of the USB flash drive - a cheap brand that I know are slow - but I’ll investigate further.
root@Pi3:~# hdparm -t /dev/sda
/dev/sda:
Timing buffered disk reads: 10 MB in 38.38 seconds = 266.83 kB/sec
/dev/sda:
Timing buffered disk reads: 4 MB in 38.42 seconds = 106.60 kB/sec
Yes very slow. No doubt a USB HD (or Sandisk/Samsung flash drive) would be better but I don’t have a spare to try.
hi guys, i’m new to dietpi and try this guide. Everything looks ok, fresh dietpi image boot from external usb ssd drive but startup configuration just broke it. Do you have any sugestion how to resolve this problem?
