Hi MichaIng Joulinar
Which USB wifi dongles/adapters can you recommended to use with RPi4 with latest DietPi ?
Something that works out of the box
Can be small dongle or with antenna
I want something with good supported driver, known to work well out of the box
Many thanks
I have the same question: https://dietpi.com/forum/t/good-wifi-5-802-11ac-usb-adapter/6201/1
But if you need it for RPi 4 specifically, I recommend to ask on the RPi forum. The DietPi version is not relevant, only the hardware, firmware/kernel version, which is the same as with RPi OS. Here one example which you shouldn’t buy at time of writing: https://forums.raspberrypi.com/viewtopic.php?t=330500
