[Rpi4] No audio over HDMI
  • DietPi version:
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=18
G_DIETPI_VERSION_RC=2
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
G_LIVE_PATCH_STATUS[0]='not applicable'
  • Distro version: bookworm 0
  • Kernel version: 6.1.21-v8+
  • Architecture: arm64
  • SBC model: RPi 4 Model B (aarch64)
  • Power supply used: Official Rpi4
PROBLEM DESCRIPTION
No sound over HDMI.
I am using the KMS video stack, which means in config.txt I have:
dtoverlay=vc4-kms-v3d
I can see these devices available:
root@dietpi:~# aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault
    Default Audio Device
hw:CARD=vc4hdmi0,DEV=0
    vc4-hdmi-0, MAI PCM i2s-hifi-0
    Direct hardware device without any conversions
plughw:CARD=vc4hdmi0,DEV=0
    Hardware device with all software conversions
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
    HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
    Direct sample mixing device
hw:CARD=vc4hdmi1,DEV=0
    vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
    HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
Also, in dietpi-config I have:
Sound card          : [rpi-bcm2835-hdmi-plug]
Auto-conversion     : [On] Automatic software conversions
…which results on this /etc/asound.conf:
pcm.!default {
        type plug
        slave.pcm {
                type hw
                card 0
                device 0
ctl.!default {
        type hw
        card 0
With speaker-test, I can manually do this and there is sound:
speaker-test -Dsysdefault
…But since programs try to use ALSA Default instead of Sysdefault, sound only works in speaker-test.
EDIT: Deleting /etc/asound.conf, audio works normally.
So there is a problem with the dietpi-config generated /etc/asound.conf
Let’s ping our developer @MichaIng to have a look into the case.
