RPi 7in touchscreen click not working properly
I have installes the RPi touchscreen (official board). It seems to work more or less fine under MATE
here are my two observations:
  1. The left click works only on the top level menus: when selecting “Applications” “Places” “System”, and the first submenu only. I hardly can select the second sebmenu. The click is not enable on the other items of the desktop display
  2. While writing these lines, the menu bar has moved .
Is there any way to fix this ?
I was worried my screen was not working properly, so I tried a Raspbina distribution. The touchscreen is working perfectly fine, and I can click on the menus.
So my first conclusions are something is missing either in DietPi or in Mate.
as a beginer I cannot go further. As I mess up with my distribution, I am afraid I need to redo the whole system.
next time, I will create a restoration point. :smiley:
