I have searched the existing open and closed issues.
- DietPi version | 9.14.2 master MichaIng
- Distro version | bookworm 0
- Kernel version | Linux DietPi 6.12.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64 GNU/Linux
- Architecture | arm64
- SBC model | RPi 3 Model B (aarch64)
- Power supply used | 5V 1A RAVpower
- SD card used | USB SSD (no SD card)
- updated/migrated from DietPi 9.12 to DietPi 9.14 using dietpi-update command.
- Rebooted system and found it won’t boot from the USB SSD anymore. Was working fine under DietPi 9.12.
- Can this issue be replicated on a fresh installation of DietPi? YES, fresh install of DietPi does the same thing on the RPI 3B booting from the originally updated USB SSD (exact same USB SSD).
- Start with an Installed working DietPi 9.12 version, or start with a fresh install of DietPi 9.14, install on a USB SSD.
- Run ‘dietpi-update’ if running DietPi 9.12
- Or try to boot the fresh installed DietPi 9.14
- Should boot to OS like it did when running DietPi 9.12. Booting and running from the same USB SSD was working fine for months on DietPi 9.12.x. The 9.14 update seems to have broken it on the RPI 3B.
- Boot stops with a black screen, no information available about what’s happened or where it stops (that I know of)
- The DietPi 9.14 updated USB SSD does boot and work work on a RPI 3B+ (booting using the exact same USB SSD).
- Also, a fresh install of DietPi 9.14 with boot fine on the RPI 3B+.
- It seems as if the DietPi 9.14 update broke working on a RPI 3B booting from the same USB SSD. Again, DietPi 9.12 was working and booting perfectly fine on a RPI 3B using the same USB SSD.
