new to DietPi, trying v8.5 on a RPi 3A+ (the one without eth interface).
Initially tried the ARMv8 64-bit image, which didnt boot at all.
ARMv7 32-bit image does boot fine, so i continued to setup my wifi connection, but it does not work. I can do an SSID scan, it sees my 2.4 and 5 ghz ssids, i enter the password … after saving the credentials i can see a brief message it couldnt bring up eth0 (why does it try to bring up eth0 on the RPi 3A+ which does not have an ethernet interface?) and then conncts and starts DHCP discovery, never suceeds and then quits.
The entered credentials are 100% correct i checked several times. Are there known issues with the RPI3A+ and wifi? The only uncommon thing i did was to configure a 256mb memory split since i am going to do video related stuff on the device.
Any ideas anyone
