Hello!
I want to upgrade my Rock 5B to Bookworm with the command provided, but I get errors in relation to the sources.
bash <(curl -sSf 'https://raw.githubusercontent.com/MichaIng/DietPi/master/.meta/dietpi-bookworm-upgrade')
I installed the image of the os from Radxa as there are no image from dietpi at this time. Afterwards I installed dietpi on top (was a little bit tricky).
Now there are sources in apt which aren’t availabe any longer.
Can you give me the correct sources for the update?
Thanks in advance.
Error Log:
- DietPi has encountered an error -
- Please create a ticket: https://github.com/MichaIng/DietPi/issues -
- Copy and paste only the BLUE lines below into the ticket -
#### Details:
- Date | Wed Mar 27 08:41:09 CET 2024
- DietPi version | v9.2.1 (MichaIng/master)
- Image creator | rock5b
- Pre-image | ROCK 5 Debian
- Hardware | Generic Device (aarch64) (ID=22)
- Kernel version | `Linux XXXXXX 5.10.66-27-rockchip-gea60d388902d #rockchip SMP Mon Oct 24 08:25:47 UTC 2022 aarch64 GNU/Linux`
- Distro | bullseye (ID=6)
- Command | `apt-get -y -eany update`
- Exit code | 100
- Software title | dietpi-bookworm-upgrade
#### Steps to reproduce:
<!-- Explain how to reproduce the issue -->
1. ...
2. ...
#### Expected behaviour:
<!-- What SHOULD happen? -->
#### Actual behaviour:
<!-- What IS happening? -->
#### Extra details:
<!-- Please post any extra details that might help solve the issue -->
#### Additional logs:
Get:2 https://deb.debian.org/debian bookworm InRelease [151 kB]
Ign:3 http://apt.radxa.com/bookworm-stable bookworm InRelease
Get:4 https://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Hit:1 https://linux-packages.resilio.com/resilio-sync/deb resilio-sync InRelease
Get:5 https://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Ign:6 https://pkg.ltec.ch/public bookworm InRelease
Get:7 https://deb.debian.org/debian bookworm-backports InRelease [56.5 kB]
Err:8 https://pkg.ltec.ch/public bookworm Release
404 Not Found [IP: 95.143.48.181 443]
Err:9 http://apt.radxa.com/bookworm-stable bookworm Release
404 Not Found [IP: 185.199.109.153 80]
Get:10 https://deb.debian.org/debian bookworm/contrib arm64 Packages [45.6 kB]
Get:11 https://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [5824 B]
Get:12 https://deb.debian.org/debian bookworm/main arm64 Packages [8685 kB]
Get:13 https://deb.debian.org/debian bookworm/non-free arm64 Packages [75.4 kB]
Get:14 https://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Packages [616 B]
Get:15 https://deb.debian.org/debian bookworm-updates/main arm64 Packages [12.5 kB]
Get:16 https://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB]
Get:17 https://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B]
Get:18 https://deb.debian.org/debian-security bookworm-security/main arm64 Packages [145 kB]
Get:19 https://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4700 B]
Get:20 https://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B]
Get:21 https://deb.debian.org/debian bookworm-backports/main arm64 Packages [185 kB]
Reading package lists...
E: The repository 'https://pkg.ltec.ch/public bookworm Release' does not have a Release file.
E: The repository 'http://apt.radxa.com/bookworm-stable bookworm Release' does not have a Release file.
