THIS A DRAFT I NEED TO CHECK SETTINGS
You need to have installed
Nginx
dietpi-software install 85 - Transmission
- Generated Certbot certificate
Create file in /etc/nginx/sites-dietpi/transmission.conf
sudo nano /etc/nginx/sites-dietpi/transmission.conf
Copy this text to transmission.conf file
location /transmission/ {
proxy_read_timeout 300;
proxy_pass_header X-Transmission-Session-Id;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# if you changed the port number for transmission daemon, then adjust the
# folllowing line
proxy_pass http://127.0.0.1:9091/transmission/web/;
# Also Transmission specific
location /rpc {
proxy_pass http://127.0.0.1:9091/transmission/rpc;
Restart nginx service
sudo dietpi-services restart nginx
Go to https://YourDietpi-IP/transmission address in Web browser
