Does anyone use a tool other than Remote.it (or No Machine). Sadly, Remote.it has gone insane with its pricing structure and they went from providing unlimited endpoints for $10 a month to $25 per 10 per month . A person like me who runs a bunch of small devices is priced out. If you have a 100 small Dietpi system, the bill is $250 / month.
I really like Remote.it, but I cannot afford the new price tag. Can anyone recommend a similar tool that maybe costs a lot less or even an open source self hosted solution?
you can have a look to https://rustdesk.com/
Thanks for the quick response. I am actually using Rustdesk on my windows desktops. I will do some more research on this. What I liked about the Remote.it is
- Installation from DietPi
- The device can auto provision itself in the field
- Nice console
- Different services can be accessed securely.
Not sure if Rustdesk provides these. But will give it a look.
Can this be added as installation package to Diet-Pi?
Of course it can be implemented, it just requires volunteers starting it ![]()
Depending on your actual need, a VPN like WireGuard, ZeroTier or Tailscale could actually be another idea.
Thanks for the suggestions. I will look into those as well. I am also looking at MeshCentral and it looks very promising for multi end point support.
