Reinstall DietPi/help with Lighttpd
Hello, I pulled out my Raspberry Pi from storage and hooked it up. All I used it for was Pi Hole. I’m not sure why but I can’t access the web interface for PiHole. Everything else with PiHole runs fine but Lighttpd is the issue.
sudo service lighthttpd restart
Failed to restart lighthttpd.service: Unit lighthttpd.service not found.
I don’t know what would be easier, to reinstall DietPi or try to fix Lighttpd with your help? I tried doing apt remove lighttpd and apt install lighttpd, but I don’t know enough about Linux to troubleshoot further. I did try doing Pihole -f (fix command), too. All comes clear, but going to the admin console doesn’t work (since lighttpd is broken)
ps is there a way to reinstall DietPi without taking out the SD card, rewriting the image on another computer, and reinstalling?
Something like a dietpi -reinstall command that will wipe everything and do a clean install without having to take out the SD card?
well it depends on you, if you like to find out what happen (why your web server is not working) or if your like to quickly get it done by reinstalling your system. :sunglasses:
If you like to reinstall, I would recommend to perform a fresh and clean installation by re-flashing your SD card. But yeah, this would mean to take out the SD card. If you don’t like to take out the SD card, you could try to run the following scripts as describe on this GitHub post. But there is no grantee that it will work.
Attention
Before doing this, you would need to ensure that some other device in your local network will take over DNS functionality (as PiHole will be away for 1-2 hours). Not sure if you use DHCP as well on your PiHole. If yes, it might be needed to re-activate DHCP functionality on your Internet Router.
Another option would be to reinstall lighttpd by running the following
dietpi-software reinstall 84
However, if your like to find out what happen on your web server, some more information are needed.
pls try the following
systemctl restart lighttpd
systemctl status lighttpd
journalctl -u lighttpd
cat /var/log/lighttpd/error.log
Maybe resetting lighttpd would be easiest?
Job for lighttpd.service failed because the control process exited with error code.
See “systemctl status lighttpd.service” and “journalctl -xe” for details.
root@DietPi:~# systemctl status lighttpd
● lighttpd.service - Lighttpd Daemon
   Loaded: loaded (/lib/systemd/system/lighttpd.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2020-02-01 18:45:30 CST; 30s ago
  Process: 22562 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Feb 01 18:45:30 DietPi systemd[1]: Failed to start Lighttpd Daemon.
Feb 01 18:45:30 DietPi systemd[1]: lighttpd.service: Unit entered failed state.
Feb 01 18:45:30 DietPi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 01 18:45:30 DietPi systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 01 18:45:30 DietPi systemd[1]: Stopped Lighttpd Daemon.
Feb 01 18:45:30 DietPi systemd[1]: lighttpd.service: Start request repeated too quickly.
For journalctl -u lighttpd I’m not sure how to copy the entire output from the terminal window since I can’t scroll up and select more :frowning: I’m very newbie, sorry!
But here is what I can select
Feb 01 18:45:29 DietPi lighttpd[22553]: 2020-02-01 18:45:29: (configfile.c.1154) source: /etc/lighttpd/conf-enabled/99-dietpi-pihole.
conf line: 33 pos: 1 parser failed somehow near here: (EOL)
Feb 01 18:45:29 DietPi lighttpd[22553]: 2020-02-01 18:45:29: (configfile.c.1154) source: find /etc/lighttpd/conf-enabled -name '*.con
f' -a ! -name 'letsencrypt.conf' -printf 'include "%p"\n' 2>/dev/null line: 3 pos: 8 parser failed somehow near here: (EOL)
Feb 01 18:45:29 DietPi lighttpd[22553]: 2020-02-01 18:45:29: (configfile.c.1154) source: /etc/lighttpd/lighttpd.conf line: 56 pos: 1
Feb 01 18:45:29 DietPi systemd[1]: lighttpd.service: Control process exited, code=exited status=255
Feb 01 18:45:29 DietPi systemd[1]: Failed to start Lighttpd Daemon.
Feb 01 18:45:29 DietPi systemd[1]: lighttpd.service: Unit entered failed state.
Feb 01 18:45:29 DietPi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 01 18:45:30 DietPi systemd[1]: Starting Lighttpd Daemon...
Feb 01 18:45:30 DietPi lighttpd[22562]: /bin/sh: 1: /usr/share/lighttpd/create-mime.conf.pl: not found
Feb 01 18:45:30 DietPi lighttpd[22562]: Duplicate config variable in conditional 0 global: server.error-handler-404
Feb 01 18:45:30 DietPi lighttpd[22562]: 2020-02-01 18:45:30: (configfile.c.1154) source: /etc/lighttpd/conf-enabled/99-dietpi-pihole.
Feb 01 18:45:30 DietPi lighttpd[22562]: 2020-02-01 18:45:30: (configfile.c.1154) source: find /etc/lighttpd/conf-enabled -name '*.con
Feb 01 18:45:30 DietPi lighttpd[22562]: 2020-02-01 18:45:30: (configfile.c.1154) source: /etc/lighttpd/lighttpd.conf line: 56 pos: 1
Feb 01 18:45:30 DietPi systemd[1]: lighttpd.service: Control process exited, code=exited status=255
empty
pls can you past output of
grep -r 'server.error-handler-404' /etc/lighttpd/
If you at least receive 2 lines back, you can try running the following to fix Lighttpd,
sed -i '/^[[:blank:]]*server.error-handler-404/d' /etc/lighttpd/lighttpd.conf
  • Note that this removes any custom 404 handler page. Pi-hole itself uses the 404 handler to show the blocking page on blocked requests.
  • If you want to disable the blocking page instead, run the above command with /etc/lighttpd/conf-available/99-dietpi-pihole.conf as target.
  • Finally (re)start Lighttpd: systemctl restart lighttpd
Hey thank you, it got the page to work, but it is not usable, it is missing all the page elements. It looks as if Javascript were turned off or something. It’s okay, I will reinstall DietPi, with the help of the tutorial you had kindly provided.
Thank you Joulinar :sunglasses:
