So I tried to install Plex, I know its not supported due to being weak but I was only gonna stream music so I thought id try it anyway but well I got an error halting its launch. So I decided id give Jellyfin ago as thats seems to be supported still howeverI get this error.
jellyfin.service - Jellyfin Media Server
Loaded: loaded (/lib/systemd/system/jellyfin.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/jellyfin.service.d
└─jellyfin.service.conf
Active: failed (Result: signal) since Thu 2020-11-12 22:57:24 GMT; 5s ago
Process: 454 ExecStart=/usr/bin/jellyfin ${JELLYFIN_WEB_OPT} ${JELLYFIN_RESTART_OPT} ${JELLYFIN_FFMPEG_OPT} ${JELLYFIN_SERVICE_OPT} ${JELLYFIN_NOWEBAPP_OPT} (code=killed, signal=SEGV)
Main PID: 454 (code=killed, signal=SEGV)
Nov 12 22:57:24 DietPi systemd[1]: jellyfin.service: Service RestartSec=100ms expired, scheduling restart.
Nov 12 22:57:24 DietPi systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 5.
Nov 12 22:57:24 DietPi systemd[1]: Stopped Jellyfin Media Server.
Nov 12 22:57:24 DietPi systemd[1]: jellyfin.service: Start request repeated too quickly.
Nov 12 22:57:24 DietPi systemd[1]: jellyfin.service: Failed with result ‘signal’.
Nov 12 22:57:24 DietPi systemd[1]: Failed to start Jellyfin Media Server.
I have no clue why? If anyone would be able to help id really appriciate it. As all I want to do is stream my music to me while im out without having to leave my pc on
Thanks for the quick reply how would I got about grabbing this from my PI? I tried to just take the SD card out and put in my pc but cant find it. Is there a command to grab it or something?
So going through the files to /var/log/jellyfin There is absolutley nothing there. I changed the log system to full and still nothing so I dont think its staying on enough to even log.
Searching online the fault people say its a corrupt sd card, but it cant be as qbittorrent works just fine, and its a fresh install and does it every flash. Could it be because its a PI 1?
Just testing Pi Hole also works fine…
Indeed it could be an issue of Jellyfin not being able to run on RPi1 boards. I have similar behaviour on my RPi1 test system. Probably they did not support armv6l ???
installed jellyfin and did a reboot
i cant access jellyfin webpage. looked under services (in dietpi-launcher) and found service failed to start. Restarted service but no use.
Any suggestions…
We trust you have received the usual lecture from the local Sys
tem
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility.
[sudo] password for dietpi:
Sorry, user dietpi is not allowed to execute ‘/usr/bin/jellyfin
–webdir=/usr/share/jellyfin/web --restartpath=/usr/lib/jellyf
in/restart.sh --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg’ as jellyfin on DietPi.
hmm I tried to follow instructions on jellyfin.org, but it seems armv6l boards are not supported anymore. I did not tested it but maybe running on Docker might be an alternative.
It is up and running…testing by copying a movie over to the /home/warhawk/jellyfin/media directory…however I think I may create a mapping to my main UNRaid server to see if it can go thru my vast library on my main server
I did have to use portainer to re-create the docker file because I screwed up the user flag before and had to “tweak” it to get it working
