DietPi version |
G_DIETPI_VERSION_CORE=9 G_DIETPI_VERSION_SUB=8 G_DIETPI_VERSION_RC=0 G_GITBRANCH='master' G_GITOWNER='MichaIng' -
Distro version |
bookworm -
Kernel version |
Linux DietPi 6.1.75-vendor-rk35xx #1 SMP Wed Oct 9 05:12:23 UTC 2024 aarch64 GNU/Linux -
Architecture |
arm64 -
SBC model |
ROCK 5B (aarch64)or (EG: RPi3) -
Power supply used | I don’t remember the name but 140W PD
SD card used | emmc
- Probably yes
- connect the external drive in the enclosure doesn’t matter if nvme or HDD
- Drive should be visible in the system and shouldn’t cause any error
- the disk is not seen in the system, every now and then an error pops up that some unexpected voltage is present
error unexpected power on pd6sd 1:0:0:0: [sdb] asking for cache data failed- , dietpi-drive_manager stops and loads endlessly
- I don’t know yet if it’s only within this system but I’ll check it soon, I had both disks connected to Orange Pi 3b before and they worked, so the problem will be with either the computer or the system for Radx Rock 5b,
- another thing i noticed is that when this disk is connected the system probably won’t start (i don’t have the patience to wait more than 20 min) and when this disk is disconnected the system starts in a few seconds
