Radarr won't start
Pardon me if I’m missing sharing any key details.
I’m currently running DietPi v. 6.34.3 (beta) and all of my applications are running just fine with the exception of Radarr.
Sonarr, Jackett, qbittorrent, wireguard are working just fine. However, when using dietpi-services radarr shows the status “failed”. When I try to manually start it it’ll show either “Active” or “Activating” and immediately switch back to failed.
When I look under “status” it shows the following:
radarr.service - Radarr Daemon (DietPi)
│    Loaded: loaded (/etc/systemd/system/radarr.service; disabled; vendor
│ preset: enabled)
│   Drop-In: /etc/systemd/system/radarr.service.d
│            └─dietpi-services_edit.conf
│    Active: failed (Result: exit-code) since Mon 2020-12-21 16:35:18 GMT;
│ 7min ago
│   Process: 1645 ExecStart=/opt/radarr/Radarr -nobrowser
│ -data=/mnt/dietpi_userdata/radarr (code=exited, status=226/NAMESPACE)
│  Main PID: 1645 (code=exited, status=226/NAMESPACE)
│ Dec 21 16:35:18 DietPi systemd[1]: radarr.service: Service RestartSec=100ms
│ expired, scheduling restart.
│ Dec 21 16:35:18 DietPi systemd[1]: radarr.service: Scheduled restart job,
│ restart counter is at 5.
│ Dec 21 16:35:18 DietPi systemd[1]: Stopped Radarr Daemon (DietPi).
│ Dec 21 16:35:18 DietPi systemd[1]: radarr.service: Start request repeated
│ too quickly.
I did search this forum and didn’t seem to find any recent posts regarding this sort of issue with Radarr.
I’ve tried removing and reinstalling the application but I cannot get it to start (or access it by browser of course).
Hopefully I’m just missing something simple. I’ve checked for any updates( apt-get update/upgrade) with nothing showing. I don’t believe it’s a mono issue as both Sonarr and Jackett work.
Thank you.
many thanks for your message. Can you check radarr log file for error messages
systemctl restart radarr.service
cat /var/log/radarr/radarr.txt
Hello and thank you for the reply.
root@DietPi:~# systemctl restart radarr.service
root@DietPi:~# cat /var/log/radarr/radarr.txt
cat: /var/log/radarr/radarr.txt: No such file or directory
This is weird right? It was working up and until at least last week (last time I checked it at least) so not sure why I don’t have anything here.
can you try to have radarr started manually
sudo -u radarr /opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
It’s worked!
root@DietPi:~# sudo -u radarr /opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
[Info] Bootstrap: Starting Radarr - /opt/radarr/Radarr.dll - Version 3.0.1.4259
[Info] AppFolderInfo: Data directory is being overridden to [/mnt/dietpi_userdata/radarr]
[Info] Router: Application mode: Interactive
[Info] MigrationController: *** Migrating data source=/mnt/dietpi_userdata/radarr/radarr.db;cache size=-20000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] MigrationController: *** Migrating data source=/mnt/dietpi_userdata/radarr/logs.db;cache size=-20000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] WebHostController: Listening on the following URLs:
[Info] WebHostController:   http://*:7878
[Info] RadarrBootstrapper: Starting Web Server
[Info] CommandExecutor: Starting 2 threads for tasks.
Strange…I wonder why DietPi cannot start it (and manage it) automatically.
Well DietPi is doing nothing else. There is a Radarr service and this should contain exactly the same ExecStart command. Can you check how service configuration looks like
systemctl cat radarr.service
root@DietPi:~# systemctl cat radarr.service
# /etc/systemd/system/radarr.service
[Unit]
Description=Radarr Daemon (DietPi)
Wants=network-online.target
After=network-online.target dietpi-boot.service
[Service]
SyslogIdentifier=Radarr
User=radarr
UMask=002
ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
TimeoutStopSec=20
KillMode=process
Restart=on-failure
# Hardening
ProtectSystem=strict
ProtectHome=true
PrivateDevices=true
ProtectKernelTunables=true
ProtectControlGroups=true
ReadWritePaths=/opt/radarr /mnt /media /var/log/radarr /tmp
[Install]
WantedBy=multi-user.target
# /etc/systemd/system/radarr.service.d/dietpi-services_edit.conf
[Unit]
#Description=Radarr Daemon (DietPi)
#Wants=network-online.target
#After=network-online.target dietpi-boot.service
[Service]
#SyslogIdentifier=Radarr
#User=radarr
#UMask=002
#ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
#TimeoutStopSec=20
#KillMode=process
#Restart=on-failure
# Hardening
#ProtectSystem=strict
#ProtectHome=true
#PrivateDevices=true
#ProtectKernelTunables=true
#ProtectControlGroups=true
#ReadWritePaths=/opt/radarr /mnt /media /var/log/radarr /tmp
[Install]
#WantedBy=multi-user.target
I tried using your service configuration and it was working without issue. Let’s check on the log file if there are issues.
ls -la /var/log
ls -la /var/log/radarr
Thank you for your assistance with all this.
root@DietPi:~# ls -la /var/log
total 976
drwxr-xr-x  7 root   root     4096 Dec 21 22:21 .
drwxr-xr-x 12 root   root     4096 Aug  4 19:39 ..
-rw-r--r--  1 root   root     8245 Dec 21 15:38 alternatives.log
drwxr-xr-x  2 root   root     4096 Dec 21 15:54 apt
-rw-rw----  1 root   utmp     4992 Dec 21 03:59 btmp
-rw-r--r--  1 root   root   438207 Dec 21 15:55 dpkg.log
-rw-rw-r--  1 root   utmp   291416 Dec 21 22:26 lastlog
drwx------  2 root   root     4096 Jun  8  2020 private
drwxr-xr-x  2 radarr dietpi   4096 Dec 21 22:27 radarr
drwxr-x---  3 root   adm      4096 Dec 20 22:03 samba
drwxr-xr-x  2 sonarr dietpi   4096 Aug  4 19:39 sonarr
-rw-rw-r--  1 root   utmp   489216 Dec 21 22:26 wtmp
root@DietPi:~# ls -la /var/log/radarr
total 72
drwxr-xr-x 2 radarr dietpi  4096 Dec 21 22:27 .
drwxr-xr-x 7 root   root    4096 Dec 21 22:21 ..
-rw-r--r-- 1 radarr dietpi 32768 Dec 21 22:27 logs.db
-rw-r--r-- 1 radarr dietpi 31728 Dec 21 22:27 radarr.txt
I’m not sure what caused everything to break recently but I think I know where some of my issue may be from.
When the change was done for DietPi installs of Sonarr and Radarr there was something I changed (that I can’t recall or replicate, unfortunately) to allow Radarr and Sonarr to see all of my rclone-mounted media folders that, by default, the DietPi installed versions were blind to.
If you wouldn’t mind I have two questions:
  1. How can I fully remove every instance of Radarr from my system so I can start completely new? Because, as it stands, even when I uninstall Radarr via dietpi-software and reinstall it the service still fails to start.
  2. What setting can I change to allow Radarr to access any folder on my filesystem?
I apologize for these awful n00b questions. I’m mildly tech-literate usually but I have almost no real experience with Linux.
there is a protection/hardening setting inside radarr service configuration allowing access to following folder only :wink:
Basically use dietpi-software to remove radarr. Once done reboot your systems. Back online, just check for files related to radarr
find / -name "radarr"
Greetings and Happy Holidays!
I am also having this exact same problem I tried the fix:
But I am unable to execute /opt/radarr/Radarr
sudo: unable to execute /opt/radarr/Radarr: No such file or directory
I tried uninstalling, rebooting, and find / -name “radarr”
But sadly still run into the same error that Mike originally had
root@DietPi:~# systemctl status radarr.service
● radarr.service - Radarr Daemon (DietPi)
   Loaded: loaded (/etc/systemd/system/radarr.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Tue 2020-12-22 18:16:38 EST; 6min ago
  Process: 830 ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr (code=exited, status
=203/EXEC)
 Main PID: 830 (code=exited, status=203/EXEC)
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Main process exited, code=exited, status=2
03/EXEC
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Service RestartSec=100ms expired, scheduling restart.
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 5.
Dec 22 18:16:38 DietPi systemd[1]: Stopped Radarr Daemon (DietPi).
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Start request repeated too quickly.
Dec 22 18:16:38 DietPi systemd[1]: Failed to start Radarr Daemon (DietPi).
Any help would be appreciated, Happy Holidays!
not sure if this is the same issue as you are missing the executable /opt/radarr/Radarr: No such file or directory
Can you check if it’s available
ls -la /opt/radarr/
I wasn’t sure how much of the output you needed so I copied it all my bad if its long
root@DietPi:~# ls -la /opt/radarr/
total 123080
drwxr-xr-x 6 radarr dietpi    24576 Dec 10 22:59 .
drwxr-xr-x 6 root   root       4096 Dec 22 18:14 ..
-rw-r--r-- 1 radarr dietpi   116992 Dec 10 22:59 createdump
-rw-r--r-- 1 radarr dietpi   190464 Dec 10 22:59 Dapper.dll
drwxr-xr-x 2 radarr dietpi     4096 Dec 10 22:59 de-DE
-rw-r--r-- 1 radarr dietpi    91648 Dec 10 22:59 FluentMigrator.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    54272 Dec 10 22:59 FluentMigrator.dll
-rw-r--r-- 1 radarr dietpi   114176 Dec 10 22:59 FluentMigrator.Runner.Core.dll
-rw-r--r-- 1 radarr dietpi    67072 Dec 10 22:59 FluentMigrator.Runner.dll
-rw-r--r-- 1 radarr dietpi    21504 Dec 10 22:59 FluentMigrator.Runner.SQLite.dll
-rw-r--r-- 1 radarr dietpi   339456 Dec 10 22:59 FluentValidation.dll
-rw-r--r-- 1 radarr dietpi   187392 Dec 10 22:59 Ical.Net.dll
-rw-r--r-- 1 radarr dietpi   198144 Dec 10 22:59 ICSharpCode.SharpZipLib.dll
-rw-r--r-- 1 radarr dietpi    20992 Dec 10 22:59 Interop.NetFwTypeLib.dll
-rw-r--r-- 1 radarr dietpi    80384 Dec 10 22:59 Kveer.XmlRPC.dll
-rw-r--r-- 1 radarr dietpi  2932264 Dec 10 22:59 libclrjit.so
-rw-r--r-- 1 radarr dietpi  9496592 Dec 10 22:59 libcoreclr.so
-rw-r--r-- 1 radarr dietpi   749400 Dec 10 22:59 libcoreclrtraceptprovider.so
-rw-r--r-- 1 radarr dietpi   974368 Dec 10 22:59 libdbgshim.so
-rw-r--r-- 1 radarr dietpi   397464 Dec 10 22:59 libhostfxr.so
-rw-r--r-- 1 radarr dietpi   331992 Dec 10 22:59 libhostpolicy.so
-rw-r--r-- 1 radarr dietpi   246736 Dec 10 22:59 libMonoPosixHelper.so
-rw-r--r-- 1 radarr dietpi  3620904 Dec 10 22:59 libmscordaccore.so
-rw-r--r-- 1 radarr dietpi  2883680 Dec 10 22:59 libmscordbi.so
-rw-r--r-- 1 radarr dietpi    35141 Dec 10 22:59 LICENSE
drwxr-xr-x 3 radarr dietpi     4096 Dec 10 22:59 Localization
-rw-r--r-- 1 radarr dietpi   115080 Dec 10 22:59 Microsoft.AspNetCore.Antiforgery.dll
-rw-r--r-- 1 radarr dietpi    53640 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   113032 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Cookies.dll
-rw-r--r-- 1 radarr dietpi    84872 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Core.dll
-rw-r--r-- 1 radarr dietpi   160136 Dec 10 22:59 Microsoft.AspNetCore.Authentication.dll
-rw-r--r-- 1 radarr dietpi    97672 Dec 10 22:59 Microsoft.AspNetCore.Authentication.OAuth.dll
-rw-r--r-- 1 radarr dietpi    88968 Dec 10 22:59 Microsoft.AspNetCore.Authorization.dll
-rw-r--r-- 1 radarr dietpi    53632 Dec 10 22:59 Microsoft.AspNetCore.Authorization.Policy.dll
-rw-r--r-- 1 radarr dietpi    48008 Dec 10 22:59 Microsoft.AspNetCore.Components.Authorization.dll
-rw-r--r-- 1 radarr dietpi   432520 Dec 10 22:59 Microsoft.AspNetCore.Components.dll
-rw-r--r-- 1 radarr dietpi    60808 Dec 10 22:59 Microsoft.AspNetCore.Components.Forms.dll
-rw-r--r-- 1 radarr dietpi   865160 Dec 10 22:59 Microsoft.AspNetCore.Components.Server.dll
-rw-r--r-- 1 radarr dietpi   122240 Dec 10 22:59 Microsoft.AspNetCore.Components.Web.dll
-rw-r--r-- 1 radarr dietpi    36224 Dec 10 22:59 Microsoft.AspNetCore.Connections.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    46464 Dec 10 22:59 Microsoft.AspNetCore.CookiePolicy.dll
-rw-r--r-- 1 radarr dietpi    87936 Dec 10 22:59 Microsoft.AspNetCore.Cors.dll
-rw-r--r-- 1 radarr dietpi    71048 Dec 10 22:59 Microsoft.AspNetCore.Cryptography.Internal.dll
-rw-r--r-- 1 radarr dietpi    36744 Dec 10 22:59 Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
-rw-r--r-- 1 radarr dietpi    42888 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   445320 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.dll
-rw-r--r-- 1 radarr dietpi    36744 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.Extensions.dll
-rw-r--r-- 1 radarr dietpi    21384 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   440712 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.dll
-rw-r--r-- 1 radarr dietpi    46976 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi    37768 Dec 10 22:59 Microsoft.AspNetCore.dll
-rw-r--r-- 1 radarr dietpi    35208 Dec 10 22:59 Microsoft.AspNetCore.HostFiltering.dll
-rw-r--r-- 1 radarr dietpi    33672 Dec 10 22:59 Microsoft.AspNetCore.Hosting.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   416648 Dec 10 22:59 Microsoft.AspNetCore.Hosting.dll
-rw-r--r-- 1 radarr dietpi    18304 Dec 10 22:59 Microsoft.AspNetCore.Hosting.Server.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    33160 Dec 10 22:59 Microsoft.AspNetCore.Html.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   238984 Dec 10 22:59 Microsoft.AspNetCore.Http.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    49536 Dec 10 22:59 Microsoft.AspNetCore.Http.Connections.Common.dll
-rw-r--r-- 1 radarr dietpi   313736 Dec 10 22:59 Microsoft.AspNetCore.Http.Connections.dll
-rw-r--r-- 1 radarr dietpi   247176 Dec 10 22:59 Microsoft.AspNetCore.Http.dll
-rw-r--r-- 1 radarr dietpi    94600 Dec 10 22:59 Microsoft.AspNetCore.Http.Extensions.dll
-rw-r--r-- 1 radarr dietpi    30600 Dec 10 22:59 Microsoft.AspNetCore.Http.Features.dll
-rw-r--r-- 1 radarr dietpi    67464 Dec 10 22:59 Microsoft.AspNetCore.HttpOverrides.dll
-rw-r--r-- 1 radarr dietpi    41352 Dec 10 22:59 Microsoft.AspNetCore.HttpsPolicy.dll
-rw-r--r-- 1 radarr dietpi   219520 Dec 10 22:59 Microsoft.AspNetCore.Identity.dll
-rw-r--r-- 1 radarr dietpi    59264 Dec 10 22:59 Microsoft.AspNetCore.Localization.dll
-rw-r--r-- 1 radarr dietpi    19848 Dec 10 22:59 Microsoft.AspNetCore.Localization.Routing.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 Microsoft.AspNetCore.Metadata.dll
-rw-r--r-- 1 radarr dietpi   219008 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    82312 Dec 10 22:59 Microsoft.AspNetCore.Mvc.ApiExplorer.dll
-rw-r--r-- 1 radarr dietpi  2149760 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Core.dll
-rw-r--r-- 1 radarr dietpi    48008 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Cors.dll
-rw-r--r-- 1 radarr dietpi   119688 Dec 10 22:59 Microsoft.AspNetCore.Mvc.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi    28552 Dec 10 22:59 Microsoft.AspNetCore.Mvc.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Formatters.Json.dll
-rw-r--r-- 1 radarr dietpi   125824 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Formatters.Xml.dll
-rw-r--r-- 1 radarr dietpi    45448 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Localization.dll
-rw-r--r-- 1 radarr dietpi   269704 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Razor.dll
-rw-r--r-- 1 radarr dietpi   510344 Dec 10 22:59 Microsoft.AspNetCore.Mvc.RazorPages.dll
-rw-r--r-- 1 radarr dietpi   326024 Dec 10 22:59 Microsoft.AspNetCore.Mvc.TagHelpers.dll
-rw-r--r-- 1 radarr dietpi   918920 Dec 10 22:59 Microsoft.AspNetCore.Mvc.ViewFeatures.dll
-rw-r--r-- 1 radarr dietpi    80256 Dec 10 22:59 Microsoft.AspNetCore.Owin.dll
-rw-r--r-- 1 radarr dietpi    72072 Dec 10 22:59 Microsoft.AspNetCore.Razor.dll
-rw-r--r-- 1 radarr dietpi    68488 Dec 10 22:59 Microsoft.AspNetCore.Razor.Runtime.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 Microsoft.AspNetCore.ResponseCaching.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   144264 Dec 10 22:59 Microsoft.AspNetCore.ResponseCaching.dll
-rw-r--r-- 1 radarr dietpi    76680 Dec 10 22:59 Microsoft.AspNetCore.ResponseCompression.dll
-rw-r--r-- 1 radarr dietpi   241544 Dec 10 22:59 Microsoft.AspNetCore.Rewrite.dll
-rw-r--r-- 1 radarr dietpi    57224 Dec 10 22:59 Microsoft.AspNetCore.Routing.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   763784 Dec 10 22:59 Microsoft.AspNetCore.Routing.dll
-rw-r--r-- 1 radarr dietpi   579464 Dec 10 22:59 Microsoft.AspNetCore.Server.HttpSys.dll
-rw-r--r-- 1 radarr dietpi   662920 Dec 10 22:59 Microsoft.AspNetCore.Server.IIS.dll
-rw-r--r-- 1 radarr dietpi    48008 Dec 10 22:59 Microsoft.AspNetCore.Server.IISIntegration.dll
-rw-r--r-- 1 radarr dietpi  1599880 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.Core.dll
-rw-r--r-- 1 radarr dietpi    21888 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.dll
-rw-r--r-- 1 radarr dietpi   151432 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
-rw-r--r-- 1 radarr dietpi    87432 Dec 10 22:59 Microsoft.AspNetCore.Session.dll
-rw-r--r-- 1 radarr dietpi    37256 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Common.dll
-rw-r--r-- 1 radarr dietpi   425352 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Core.dll
-rw-r--r-- 1 radarr dietpi    33160 Dec 10 22:59 Microsoft.AspNetCore.SignalR.dll
-rw-r--r-- 1 radarr dietpi    77192 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Protocols.Json.dll
-rw-r--r-- 1 radarr dietpi    35208 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Protocols.NewtonsoftJson.dll
-rw-r--r-- 1 radarr dietpi   162176 Dec 10 22:59 Microsoft.AspNetCore.StaticFiles.dll
-rw-r--r-- 1 radarr dietpi    40840 Dec 10 22:59 Microsoft.AspNetCore.WebSockets.dll
-rw-r--r-- 1 radarr dietpi   234368 Dec 10 22:59 Microsoft.AspNetCore.WebUtilities.dll
-rw-r--r-- 1 radarr dietpi   990080 Dec 10 22:59 Microsoft.CSharp.dll
-rw-r--r-- 1 radarr dietpi    22632 Dec 10 22:59 Microsoft.DotNet.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi    49032 Dec 10 22:59 Microsoft.Extensions.Caching.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    64392 Dec 10 22:59 Microsoft.Extensions.Caching.Memory.dll
-rw-r--r-- 1 radarr dietpi    21384 Dec 10 22:59 Microsoft.Extensions.Configuration.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    25480 Dec 10 22:59 Microsoft.Extensions.Configuration.Binder.dll
-rw-r--r-- 1 radarr dietpi    19848 Dec 10 22:59 Microsoft.Extensions.Configuration.CommandLine.dll
-rw-r--r-- 1 radarr dietpi    27528 Dec 10 22:59 Microsoft.Extensions.Configuration.dll
-rw-r--r-- 1 radarr dietpi    20872 Dec 10 22:59 Microsoft.Extensions.Configuration.EnvironmentVariables.dll
-rw-r--r-- 1 radarr dietpi    22920 Dec 10 22:59 Microsoft.Extensions.Configuration.FileExtensions.dll
-rw-r--r-- 1 radarr dietpi    30592 Dec 10 22:59 Microsoft.Extensions.Configuration.Ini.dll
-rw-r--r-- 1 radarr dietpi    21896 Dec 10 22:59 Microsoft.Extensions.Configuration.Json.dll
-rw-r--r-- 1 radarr dietpi    27528 Dec 10 22:59 Microsoft.Extensions.Configuration.KeyPerFile.dll
-rw-r--r-- 1 radarr dietpi    20872 Dec 10 22:59 Microsoft.Extensions.Configuration.UserSecrets.dll
-rw-r--r-- 1 radarr dietpi    42376 Dec 10 22:59 Microsoft.Extensions.Configuration.Xml.dll
-rw-r--r-- 1 radarr dietpi    37768 Dec 10 22:59 Microsoft.Extensions.DependencyInjection.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    72584 Dec 10 22:59 Microsoft.Extensions.DependencyInjection.dll
-rw-r--r-- 1 radarr dietpi    58472 Dec 10 22:59 Microsoft.Extensions.DependencyModel.dll
-rw-r--r-- 1 radarr dietpi    31624 Dec 10 22:59 Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   100232 Dec 10 22:59 Microsoft.Extensions.Diagnostics.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi    17800 Dec 10 22:59 Microsoft.Extensions.FileProviders.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    23424 Dec 10 22:59 Microsoft.Extensions.FileProviders.Composite.dll
-rw-r--r-- 1 radarr dietpi    69000 Dec 10 22:59 Microsoft.Extensions.FileProviders.Embedded.dll
-rw-r--r-- 1 radarr dietpi    35712 Dec 10 22:59 Microsoft.Extensions.FileProviders.Physical.dll
-rw-r--r-- 1 radarr dietpi    39304 Dec 10 22:59 Microsoft.Extensions.FileSystemGlobbing.dll
-rw-r--r-- 1 radarr dietpi    25984 Dec 10 22:59 Microsoft.Extensions.Hosting.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    41352 Dec 10 22:59 Microsoft.Extensions.Hosting.dll
-rw-r--r-- 1 radarr dietpi    21384 Dec 10 22:59 Microsoft.Extensions.Hosting.WindowsServices.dll
-rw-r--r-- 1 radarr dietpi   142728 Dec 10 22:59 Microsoft.Extensions.Http.dll
-rw-r--r-- 1 radarr dietpi   524160 Dec 10 22:59 Microsoft.Extensions.Identity.Core.dll
-rw-r--r-- 1 radarr dietpi    85376 Dec 10 22:59 Microsoft.Extensions.Identity.Stores.dll
-rw-r--r-- 1 radarr dietpi    21896 Dec 10 22:59 Microsoft.Extensions.Localization.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    58248 Dec 10 22:59 Microsoft.Extensions.Localization.dll
-rw-r--r-- 1 radarr dietpi    48520 Dec 10 22:59 Microsoft.Extensions.Logging.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    20360 Dec 10 22:59 Microsoft.Extensions.Logging.Configuration.dll
-rw-r--r-- 1 radarr dietpi    28040 Dec 10 22:59 Microsoft.Extensions.Logging.Console.dll
-rw-r--r-- 1 radarr dietpi    17800 Dec 10 22:59 Microsoft.Extensions.Logging.Debug.dll
-rw-r--r-- 1 radarr dietpi    34184 Dec 10 22:59 Microsoft.Extensions.Logging.dll
-rw-r--r-- 1 radarr dietpi    21896 Dec 10 22:59 Microsoft.Extensions.Logging.EventLog.dll
-rw-r--r-- 1 radarr dietpi    29568 Dec 10 22:59 Microsoft.Extensions.Logging.EventSource.dll
-rw-r--r-- 1 radarr dietpi    29576 Dec 10 22:59 Microsoft.Extensions.Logging.TraceSource.dll
-rw-r--r-- 1 radarr dietpi    32136 Dec 10 22:59 Microsoft.Extensions.ObjectPool.dll
-rw-r--r-- 1 radarr dietpi    18312 Dec 10 22:59 Microsoft.Extensions.Options.ConfigurationExtensions.dll
-rw-r--r-- 1 radarr dietpi    20872 Dec 10 22:59 Microsoft.Extensions.Options.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi    50568 Dec 10 22:59 Microsoft.Extensions.Options.dll
-rw-r--r-- 1 radarr dietpi    16376 Dec 10 22:59 Microsoft.Extensions.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi    38792 Dec 10 22:59 Microsoft.Extensions.Primitives.dll
-rw-r--r-- 1 radarr dietpi    30600 Dec 10 22:59 Microsoft.Extensions.WebEncoders.dll
-rw-r--r-- 1 radarr dietpi    96136 Dec 10 22:59 Microsoft.JSInterop.dll
-rw-r--r-- 1 radarr dietpi   249736 Dec 10 22:59 Microsoft.Net.Http.Headers.dll
-rw-r--r-- 1 radarr dietpi  1492360 Dec 10 22:59 Microsoft.VisualBasic.Core.dll
-rw-r--r-- 1 radarr dietpi    17280 Dec 10 22:59 Microsoft.VisualBasic.dll
-rw-r--r-- 1 radarr dietpi    21896 Dec 10 22:59 Microsoft.Win32.Primitives.dll
-rw-r--r-- 1 radarr dietpi    68488 Dec 10 22:59 Microsoft.Win32.Registry.dll
-rw-r--r-- 1 radarr dietpi    23112 Dec 10 22:59 Microsoft.Win32.SystemEvents.dll
-rw-r--r-- 1 radarr dietpi    64000 Dec 10 22:59 Mono.Nat.dll
-rw-r--r-- 1 radarr dietpi   190080 Dec 10 22:59 Mono.Posix.NETStandard.dll
-rw-r--r-- 1 radarr dietpi   556544 Dec 10 22:59 MonoTorrent.dll
-rw-r--r-- 1 radarr dietpi    56704 Dec 10 22:59 mscorlib.dll
-rw-r--r-- 1 radarr dietpi     8704 Dec 10 22:59 Nancy.Authentication.Basic.dll
-rw-r--r-- 1 radarr dietpi    13824 Dec 10 22:59 Nancy.Authentication.Forms.dll
-rw-r--r-- 1 radarr dietpi   919552 Dec 10 22:59 Nancy.dll
-rw-r--r-- 1 radarr dietpi   114568 Dec 10 22:59 netstandard.dll
-rw-r--r-- 1 radarr dietpi   693680 Dec 10 22:59 Newtonsoft.Json.dll
-rw-r--r-- 1 radarr dietpi   803328 Dec 10 22:59 NLog.dll
-rw-r--r-- 1 radarr dietpi    45056 Dec 10 22:59 NLog.Extensions.Logging.dll
-rw-r--r-- 1 radarr dietpi   436224 Dec 10 22:59 NodaTime.dll
-rw-r--r-- 1 radarr dietpi    28672 Dec 10 22:59 Org.Mentalis.dll
-rwxr-xr-x 1 radarr dietpi   135968 Dec 10 22:59 Radarr
-rw-r--r-- 1 radarr dietpi   137206 Dec 10 22:59 Radarr.Api.deps.json
-rw-r--r-- 1 radarr dietpi   192000 Dec 10 22:59 Radarr.Api.dll
-rw-r--r-- 1 radarr dietpi    78424 Dec 10 22:59 Radarr.Api.pdb
-rw-r--r-- 1 radarr dietpi   137243 Dec 10 22:59 Radarr.Api.V3.deps.json
-rw-r--r-- 1 radarr dietpi   261120 Dec 10 22:59 Radarr.Api.V3.dll
-rw-r--r-- 1 radarr dietpi    98392 Dec 10 22:59 Radarr.Api.V3.pdb
-rw-r--r-- 1 radarr dietpi    45799 Dec 10 22:59 Radarr.Common.deps.json
-rw-r--r-- 1 radarr dietpi   271360 Dec 10 22:59 Radarr.Common.dll
-rw-r--r-- 1 radarr dietpi   108832 Dec 10 22:59 Radarr.Common.pdb
-rw-r--r-- 1 radarr dietpi    58908 Dec 10 22:59 Radarr.Core.deps.json
-rw-r--r-- 1 radarr dietpi  1819648 Dec 10 22:59 Radarr.Core.dll
-rw-r--r-- 1 radarr dietpi      356 Dec 10 22:59 Radarr.Core.dll.config
-rw-r--r-- 1 radarr dietpi   633156 Dec 10 22:59 Radarr.Core.pdb
-rw-r--r-- 1 radarr dietpi   193154 Dec 10 22:59 Radarr.deps.json
-rw-r--r-- 1 radarr dietpi   119296 Dec 10 22:59 Radarr.dll
-rw-r--r-- 1 radarr dietpi      431 Dec 10 22:59 Radarr.dll.config
-rw-r--r-- 1 radarr dietpi   313190 Dec 10 22:59 Radarr.Host.deps.json
-rw-r--r-- 1 radarr dietpi    33280 Dec 10 22:59 Radarr.Host.dll
-rw-r--r-- 1 radarr dietpi    29008 Dec 10 22:59 Radarr.Host.pdb
-rw-r--r-- 1 radarr dietpi   132351 Dec 10 22:59 Radarr.Http.deps.json
-rw-r--r-- 1 radarr dietpi    86016 Dec 10 22:59 Radarr.Http.dll
-rw-r--r-- 1 radarr dietpi    47900 Dec 10 22:59 Radarr.Http.pdb
-rw-r--r-- 1 radarr dietpi    46978 Dec 10 22:59 Radarr.Mono.deps.json
-rw-r--r-- 1 radarr dietpi    26624 Dec 10 22:59 Radarr.Mono.dll
-rw-r--r-- 1 radarr dietpi    20868 Dec 10 22:59 Radarr.Mono.pdb
-rw-r--r-- 1 radarr dietpi    21536 Dec 10 22:59 Radarr.pdb
-rw-r--r-- 1 radarr dietpi      279 Dec 10 22:59 Radarr.runtimeconfig.json
-rw-r--r-- 1 radarr dietpi   182696 Dec 10 22:59 Radarr.SignalR.deps.json
-rw-r--r-- 1 radarr dietpi     9216 Dec 10 22:59 Radarr.SignalR.dll
-rw-r--r-- 1 radarr dietpi    20820 Dec 10 22:59 Radarr.SignalR.pdb
drwxr-xr-x 2 radarr dietpi    20480 Dec 10 22:59 Radarr.Update
-rw-r--r-- 1 radarr dietpi    21504 Dec 10 22:59 ReusableTasks.dll
-rw-r--r-- 1 radarr dietpi    85504 Dec 10 22:59 Sentry.dll
-rw-r--r-- 1 radarr dietpi    11264 Dec 10 22:59 Sentry.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi    50688 Dec 10 22:59 Sentry.Protocol.dll
-rw-r--r-- 1 radarr dietpi   135968 Dec 10 22:59 ServiceInstall
-rw-r--r-- 1 radarr dietpi   135968 Dec 10 22:59 ServiceUninstall
-rw-r--r-- 1 radarr dietpi  1148928 Dec 10 22:59 SixLabors.ImageSharp.dll
-rw-r--r-- 1 radarr dietpi    10752 Dec 10 22:59 SocksWebProxy.dll
-rw-r--r-- 1 radarr dietpi      272 Dec 10 22:59 SOS_README.md
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.AppContext.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Buffers.dll
-rw-r--r-- 1 radarr dietpi   228736 Dec 10 22:59 System.Collections.Concurrent.dll
-rw-r--r-- 1 radarr dietpi   416128 Dec 10 22:59 System.Collections.dll
-rw-r--r-- 1 radarr dietpi   828808 Dec 10 22:59 System.Collections.Immutable.dll
-rw-r--r-- 1 radarr dietpi   118152 Dec 10 22:59 System.Collections.NonGeneric.dll
-rw-r--r-- 1 radarr dietpi   109960 Dec 10 22:59 System.Collections.Specialized.dll
-rw-r--r-- 1 radarr dietpi   198016 Dec 10 22:59 System.ComponentModel.Annotations.dll
-rw-r--r-- 1 radarr dietpi    16264 Dec 10 22:59 System.ComponentModel.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi    16776 Dec 10 22:59 System.ComponentModel.dll
-rw-r--r-- 1 radarr dietpi    39304 Dec 10 22:59 System.ComponentModel.EventBasedAsync.dll
-rw-r--r-- 1 radarr dietpi    63368 Dec 10 22:59 System.ComponentModel.Primitives.dll
-rw-r--r-- 1 radarr dietpi   886144 Dec 10 22:59 System.ComponentModel.TypeConverter.dll
-rw-r--r-- 1 radarr dietpi   375912 Dec 10 22:59 System.Configuration.ConfigurationManager.dll
-rw-r--r-- 1 radarr dietpi    19336 Dec 10 22:59 System.Configuration.dll
-rw-r--r-- 1 radarr dietpi   224136 Dec 10 22:59 System.Console.dll
-rw-r--r-- 1 radarr dietpi    23944 Dec 10 22:59 System.Core.dll
-rw-r--r-- 1 radarr dietpi  3758976 Dec 10 22:59 System.Data.Common.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Data.DataSetExtensions.dll
-rw-r--r-- 1 radarr dietpi    25992 Dec 10 22:59 System.Data.dll
-rw-r--r-- 1 radarr dietpi   351744 Dec 10 22:59 System.Data.SQLite.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Diagnostics.Contracts.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Diagnostics.Debug.dll
-rw-r--r-- 1 radarr dietpi   117640 Dec 10 22:59 System.Diagnostics.DiagnosticSource.dll
-rw-r--r-- 1 radarr dietpi    49256 Dec 10 22:59 System.Diagnostics.EventLog.dll
-rw-r--r-- 1 radarr dietpi    40840 Dec 10 22:59 System.Diagnostics.FileVersionInfo.dll
-rw-r--r-- 1 radarr dietpi   273288 Dec 10 22:59 System.Diagnostics.Process.dll
-rw-r--r-- 1 radarr dietpi    37768 Dec 10 22:59 System.Diagnostics.StackTrace.dll
-rw-r--r-- 1 radarr dietpi    67976 Dec 10 22:59 System.Diagnostics.TextWriterTraceListener.dll
-rw-r--r-- 1 radarr dietpi    17800 Dec 10 22:59 System.Diagnostics.Tools.dll
-rw-r--r-- 1 radarr dietpi   157576 Dec 10 22:59 System.Diagnostics.TraceSource.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 System.Diagnostics.Tracing.dll
-rw-r--r-- 1 radarr dietpi    54664 Dec 10 22:59 System.dll
-rw-r--r-- 1 radarr dietpi   372840 Dec 10 22:59 System.Drawing.Common.dll
-rw-r--r-- 1 radarr dietpi    20864 Dec 10 22:59 System.Drawing.dll
-rw-r--r-- 1 radarr dietpi   136064 Dec 10 22:59 System.Drawing.Primitives.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 System.Dynamic.Runtime.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Globalization.Calendars.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Globalization.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Globalization.Extensions.dll
-rw-r--r-- 1 radarr dietpi    59288 Dec 10 22:59 System.Globalization.Native.so
-rw-r--r-- 1 radarr dietpi    80776 Dec 10 22:59 System.IO.Compression.Brotli.dll
-rw-r--r-- 1 radarr dietpi   302984 Dec 10 22:59 System.IO.Compression.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.IO.Compression.FileSystem.dll
-rw-r--r-- 1 radarr dietpi  3042390 Dec 10 22:59 System.IO.Compression.Native.a
-rw-r--r-- 1 radarr dietpi   723864 Dec 10 22:59 System.IO.Compression.Native.so
-rw-r--r-- 1 radarr dietpi    38280 Dec 10 22:59 System.IO.Compression.ZipFile.dll
-rw-r--r-- 1 radarr dietpi    15232 Dec 10 22:59 System.IO.dll
-rw-r--r-- 1 radarr dietpi    35208 Dec 10 22:59 System.IO.FileSystem.AccessControl.dll
-rw-r--r-- 1 radarr dietpi   262016 Dec 10 22:59 System.IO.FileSystem.dll
-rw-r--r-- 1 radarr dietpi    84872 Dec 10 22:59 System.IO.FileSystem.DriveInfo.dll
-rw-r--r-- 1 radarr dietpi    14720 Dec 10 22:59 System.IO.FileSystem.Primitives.dll
-rw-r--r-- 1 radarr dietpi   109960 Dec 10 22:59 System.IO.FileSystem.Watcher.dll
-rw-r--r-- 1 radarr dietpi    92040 Dec 10 22:59 System.IO.IsolatedStorage.dll
-rw-r--r-- 1 radarr dietpi    79240 Dec 10 22:59 System.IO.MemoryMappedFiles.dll
-rw-r--r-- 1 radarr dietpi    65928 Dec 10 22:59 System.IO.Pipelines.dll
-rw-r--r-- 1 radarr dietpi    24968 Dec 10 22:59 System.IO.Pipes.AccessControl.dll
-rw-r--r-- 1 radarr dietpi   141192 Dec 10 22:59 System.IO.Pipes.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.IO.UnmanagedMemoryStream.dll
-rw-r--r-- 1 radarr dietpi   519048 Dec 10 22:59 System.Linq.dll
-rw-r--r-- 1 radarr dietpi  7621000 Dec 10 22:59 System.Linq.Expressions.dll
-rw-r--r-- 1 radarr dietpi  1665408 Dec 10 22:59 System.Linq.Parallel.dll
-rw-r--r-- 1 radarr dietpi   240008 Dec 10 22:59 System.Linq.Queryable.dll
-rw-r--r-- 1 radarr dietpi   225672 Dec 10 22:59 System.Memory.dll
-rw-r--r-- 1 radarr dietpi   461328 Dec 10 22:59 System.Native.a
-rw-r--r-- 1 radarr dietpi    69296 Dec 10 22:59 System.Native.so
-rw-r--r-- 1 radarr dietpi    16776 Dec 10 22:59 System.Net.dll
-rw-r--r-- 1 radarr dietpi  1837448 Dec 10 22:59 System.Net.Http.dll
-rw-r--r-- 1 radarr dietpi   379784 Dec 10 22:59 System.Net.HttpListener.dll
-rw-r--r-- 1 radarr dietpi    84684 Dec 10 22:59 System.Net.Http.Native.a
-rw-r--r-- 1 radarr dietpi    68256 Dec 10 22:59 System.Net.Http.Native.so
-rw-r--r-- 1 radarr dietpi   621960 Dec 10 22:59 System.Net.Mail.dll
-rw-r--r-- 1 radarr dietpi    96136 Dec 10 22:59 System.Net.NameResolution.dll
-rw-r--r-- 1 radarr dietpi   196992 Dec 10 22:59 System.Net.NetworkInformation.dll
-rw-r--r-- 1 radarr dietpi   131976 Dec 10 22:59 System.Net.Ping.dll
-rw-r--r-- 1 radarr dietpi   272264 Dec 10 22:59 System.Net.Primitives.dll
-rw-r--r-- 1 radarr dietpi   430976 Dec 10 22:59 System.Net.Requests.dll
-rw-r--r-- 1 radarr dietpi   757128 Dec 10 22:59 System.Net.Security.dll
-rw-r--r-- 1 radarr dietpi    40170 Dec 10 22:59 System.Net.Security.Native.a
-rw-r--r-- 1 radarr dietpi    68264 Dec 10 22:59 System.Net.Security.Native.so
-rw-r--r-- 1 radarr dietpi    36744 Dec 10 22:59 System.Net.ServicePoint.dll
-rw-r--r-- 1 radarr dietpi   748936 Dec 10 22:59 System.Net.Sockets.dll
-rw-r--r-- 1 radarr dietpi   191880 Dec 10 22:59 System.Net.WebClient.dll
-rw-r--r-- 1 radarr dietpi    82312 Dec 10 22:59 System.Net.WebHeaderCollection.dll
-rw-r--r-- 1 radarr dietpi    29568 Dec 10 22:59 System.Net.WebProxy.dll
-rw-r--r-- 1 radarr dietpi    83336 Dec 10 22:59 System.Net.WebSockets.Client.dll
-rw-r--r-- 1 radarr dietpi   167816 Dec 10 22:59 System.Net.WebSockets.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Numerics.dll
-rw-r--r-- 1 radarr dietpi   154496 Dec 10 22:59 System.Numerics.Vectors.dll
-rw-r--r-- 1 radarr dietpi   105856 Dec 10 22:59 System.ObjectModel.dll
-rw-r--r-- 1 radarr dietpi 11440520 Dec 10 22:59 System.Private.CoreLib.dll
-rw-r--r-- 1 radarr dietpi  2621320 Dec 10 22:59 System.Private.DataContractSerialization.dll
-rw-r--r-- 1 radarr dietpi   285064 Dec 10 22:59 System.Private.Uri.dll
-rw-r--r-- 1 radarr dietpi 10656128 Dec 10 22:59 System.Private.Xml.dll
-rw-r--r-- 1 radarr dietpi   462720 Dec 10 22:59 System.Private.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi    82816 Dec 10 22:59 System.Reflection.DispatchProxy.dll
-rw-r--r-- 1 radarr dietpi    15744 Dec 10 22:59 System.Reflection.dll
-rw-r--r-- 1 radarr dietpi    15232 Dec 10 22:59 System.Reflection.Emit.dll
-rw-r--r-- 1 radarr dietpi    15232 Dec 10 22:59 System.Reflection.Emit.ILGeneration.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Reflection.Emit.Lightweight.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Reflection.Extensions.dll
-rw-r--r-- 1 radarr dietpi  1287560 Dec 10 22:59 System.Reflection.Metadata.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Reflection.Primitives.dll
-rw-r--r-- 1 radarr dietpi    33160 Dec 10 22:59 System.Reflection.TypeExtensions.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Resources.Reader.dll
-rw-r--r-- 1 radarr dietpi    15232 Dec 10 22:59 System.Resources.ResourceManager.dll
-rw-r--r-- 1 radarr dietpi    49032 Dec 10 22:59 System.Resources.Writer.dll
-rw-r--r-- 1 radarr dietpi    18824 Dec 10 22:59 System.Runtime.CompilerServices.Unsafe.dll
-rw-r--r-- 1 radarr dietpi    18312 Dec 10 22:59 System.Runtime.CompilerServices.VisualC.dll
-rw-r--r-- 1 radarr dietpi    55176 Dec 10 22:59 System.Runtime.dll
-rw-r--r-- 1 radarr dietpi   250752 Dec 10 22:59 System.Runtime.Extensions.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Runtime.Handles.dll
-rw-r--r-- 1 radarr dietpi    58760 Dec 10 22:59 System.Runtime.InteropServices.dll
-rw-r--r-- 1 radarr dietpi    28544 Dec 10 22:59 System.Runtime.InteropServices.RuntimeInformation.dll
-rw-r--r-- 1 radarr dietpi    25480 Dec 10 22:59 System.Runtime.InteropServices.WindowsRuntime.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Runtime.Intrinsics.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Runtime.Loader.dll
-rw-r--r-- 1 radarr dietpi   225672 Dec 10 22:59 System.Runtime.Numerics.dll
-rw-r--r-- 1 radarr dietpi    16776 Dec 10 22:59 System.Runtime.Serialization.dll
-rw-r--r-- 1 radarr dietpi   379272 Dec 10 22:59 System.Runtime.Serialization.Formatters.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Runtime.Serialization.Json.dll
-rw-r--r-- 1 radarr dietpi    27528 Dec 10 22:59 System.Runtime.Serialization.Primitives.dll
-rw-r--r-- 1 radarr dietpi    16256 Dec 10 22:59 System.Runtime.Serialization.Xml.dll
-rw-r--r-- 1 radarr dietpi    51080 Dec 10 22:59 System.Runtime.WindowsRuntime.dll
-rw-r--r-- 1 radarr dietpi    54656 Dec 10 22:59 System.Runtime.WindowsRuntime.UI.Xaml.dll
-rw-r--r-- 1 radarr dietpi    83840 Dec 10 22:59 System.Security.AccessControl.dll
-rw-r--r-- 1 radarr dietpi   104840 Dec 10 22:59 System.Security.Claims.dll
-rw-r--r-- 1 radarr dietpi   793480 Dec 10 22:59 System.Security.Cryptography.Algorithms.dll
-rw-r--r-- 1 radarr dietpi    80264 Dec 10 22:59 System.Security.Cryptography.Cng.dll
-rw-r--r-- 1 radarr dietpi   136072 Dec 10 22:59 System.Security.Cryptography.Csp.dll
-rw-r--r-- 1 radarr dietpi    86920 Dec 10 22:59 System.Security.Cryptography.Encoding.dll
-rw-r--r-- 1 radarr dietpi  1027120 Dec 10 22:59 System.Security.Cryptography.Native.OpenSsl.a
-rw-r--r-- 1 radarr dietpi   133912 Dec 10 22:59 System.Security.Cryptography.Native.OpenSsl.so
-rw-r--r-- 1 radarr dietpi   231816 Dec 10 22:59 System.Security.Cryptography.OpenSsl.dll
-rw-r--r-- 1 radarr dietpi   933256 Dec 10 22:59 System.Security.Cryptography.Pkcs.dll
-rw-r--r-- 1 radarr dietpi   121224 Dec 10 22:59 System.Security.Cryptography.Primitives.dll
-rw-r--r-- 1 radarr dietpi    17784 Dec 10 22:59 System.Security.Cryptography.ProtectedData.dll
-rw-r--r-- 1 radarr dietpi   748424 Dec 10 22:59 System.Security.Cryptography.X509Certificates.dll
-rw-r--r-- 1 radarr dietpi   544136 Dec 10 22:59 System.Security.Cryptography.Xml.dll
-rw-r--r-- 1 radarr dietpi    17792 Dec 10 22:59 System.Security.dll
-rw-r--r-- 1 radarr dietpi    92536 Dec 10 22:59 System.Security.Permissions.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Security.Principal.dll
-rw-r--r-- 1 radarr dietpi    45960 Dec 10 22:59 System.Security.Principal.Windows.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Security.SecureString.dll
-rw-r--r-- 1 radarr dietpi   119160 Dec 10 22:59 System.ServiceModel.Syndication.dll
-rw-r--r-- 1 radarr dietpi    16256 Dec 10 22:59 System.ServiceModel.Web.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.ServiceProcess.dll
-rw-r--r-- 1 radarr dietpi    30584 Dec 10 22:59 System.ServiceProcess.ServiceController.dll
-rw-r--r-- 1 radarr dietpi   899976 Dec 10 22:59 System.Text.Encoding.CodePages.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Text.Encoding.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Text.Encoding.Extensions.dll
-rw-r--r-- 1 radarr dietpi   115080 Dec 10 22:59 System.Text.Encodings.Web.dll
-rw-r--r-- 1 radarr dietpi  1013128 Dec 10 22:59 System.Text.Json.dll
-rw-r--r-- 1 radarr dietpi   500616 Dec 10 22:59 System.Text.RegularExpressions.dll
-rw-r--r-- 1 radarr dietpi   135560 Dec 10 22:59 System.Threading.Channels.dll
-rw-r--r-- 1 radarr dietpi    91016 Dec 10 22:59 System.Threading.dll
-rw-r--r-- 1 radarr dietpi    16256 Dec 10 22:59 System.Threading.Overlapped.dll
-rw-r--r-- 1 radarr dietpi   591240 Dec 10 22:59 System.Threading.Tasks.Dataflow.dll
-rw-r--r-- 1 radarr dietpi    16264 Dec 10 22:59 System.Threading.Tasks.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Threading.Tasks.Extensions.dll
-rw-r--r-- 1 radarr dietpi   129928 Dec 10 22:59 System.Threading.Tasks.Parallel.dll
-rw-r--r-- 1 radarr dietpi    17800 Dec 10 22:59 System.Threading.Thread.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Threading.ThreadPool.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Threading.Timer.dll
-rw-r--r-- 1 radarr dietpi    16264 Dec 10 22:59 System.Transactions.dll
-rw-r--r-- 1 radarr dietpi   424840 Dec 10 22:59 System.Transactions.Local.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.ValueTuple.dll
-rw-r--r-- 1 radarr dietpi    14728 Dec 10 22:59 System.Web.dll
-rw-r--r-- 1 radarr dietpi    53128 Dec 10 22:59 System.Web.HttpUtility.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Windows.dll
-rw-r--r-- 1 radarr dietpi    25976 Dec 10 22:59 System.Windows.Extensions.dll
-rw-r--r-- 1 radarr dietpi    24456 Dec 10 22:59 System.Xml.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi    22408 Dec 10 22:59 System.Xml.ReaderWriter.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 System.Xml.Serialization.dll
-rw-r--r-- 1 radarr dietpi    15240 Dec 10 22:59 System.Xml.XDocument.dll
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 System.Xml.XmlDocument.dll
-rw-r--r-- 1 radarr dietpi    17800 Dec 10 22:59 System.Xml.XmlSerializer.dll
-rw-r--r-- 1 radarr dietpi    15232 Dec 10 22:59 System.Xml.XPath.dll
-rw-r--r-- 1 radarr dietpi    16776 Dec 10 22:59 System.Xml.XPath.XDocument.dll
drwxr-xr-x 3 radarr dietpi     4096 Dec 10 22:59 UI
-rw-r--r-- 1 radarr dietpi      558 Dec 10 22:59 web.config
-rw-r--r-- 1 radarr dietpi    15752 Dec 10 22:59 WindowsBase.dll
looks like Radarr executable is there. But you are still not able to have it started manually?
No its kind of weird says its not there
that’s quite strange. can you move inside the directory and try to execute Radarr
cd /opt/radarr/
./Radarr
No I cannot :frowning:
root@DietPi:~# cd /opt/radarr/
root@DietPi:/opt/radarr# ./Radarr
-bash: ./Radarr: No such file or directory
Even though when I ls i see the Radarr executable
I don’t get it how this should be possible :frowning:
Did you tried to remove radarr completely and perform a new installation?
Uninstalled, rebooted and reinstalled multiple times. Might just have to fresh install but I want that as the last resort, have any other ideas?
last try. Go inside the radarr directory
cd /opt/radarr/
and just type ./Rad
Than use TAB to complete the command. Usually it should compete automatically to ./Radarr
