Radarr web interface constantly crashing
I am running Dietpi with the following applications (PiHole, Dataplicity, ResilioSync, Plex, Radarr, Sonarr, Transmission, Jacket).
All applications work perfectly, except for Radarr. The web interface constantly shows ‘This site can’t be reached: ERR_CONNECTION_REFUSED’ in browsers.
Looking online I found I can get the web interface working again temporarily running the following command, but it will then crash after a few minutes.
sudo -u radarr /opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
I ran journalctl and got the following. It shows Radarr constantly trying to restart but crashing and exiting.
Note: I am a complete DietPi/Linux noob, so please keep things simple for me. This problem has been plaguing me for a long time, looking forward to fixing it! Thanks!
Jul 06 16:03:28 DomDietPi systemd[1]: Starting Transmission BitTorrent Daemon...
Jul 06 16:03:28 DomDietPi systemd[1]: Started Transmission BitTorrent Daemon.
Jul 06 16:03:28 DomDietPi systemd[1]: Starting Plex Media Server...
Jul 06 16:03:28 DomDietPi systemd[1]: Started Plex Media Server.
Jul 06 16:03:28 DomDietPi systemd[1]: Started Jackett (DietPi).
Jul 06 16:03:28 DomDietPi systemd[1]: /etc/systemd/system/sonarr.service.d/dietpi-services_edit.conf:3: ReadWritePaths= path is not absolute, ignoring: Shows
Jul 06 16:03:28 DomDietPi systemd[1]: Started Sonarr Daemon (DietPi).
Jul 06 16:03:28 DomDietPi systemd[1]: Started Radarr (DietPi).
Jul 06 16:03:28 DomDietPi systemd[599]: radarr.service:Failed to set up mount namespacing: No such file or directory
Jul 06 16:03:28 DomDietPi systemd[599]: radarr.service:Failed at step NAMESPACE spawning /opt/radarr/Radarr: No such file or directory
Jul 06 16:03:28 DomDietPi systemd[1]: radarr.service: Main process exited, code=exited, status=226/NAMESPACE
Jul 06 16:03:28 DomDietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Jul 06 16:03:28 DomDietPi systemd[1]: Started Bazarr (DietPi).
Jul 06 16:03:28 DomDietPi systemd[1]: Started Regular background program processing daemon.
Jul 06 16:03:28 DomDietPi cron[606]: (CRON) INFO (pidfile fd = 3)
Jul 06 16:03:29 DomDietPi systemd[1]: radarr.service: Service RestartSec=100ms expired, scheduling restart.
Jul 06 16:03:29 DomDietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 1.
Jul 06 16:03:29 DomDietPi systemd[1]: Stopped Radarr (DietPi).
Jul 06 16:03:29 DomDietPi systemd[1]: Started Radarr (DietPi).
Jul 06 16:03:29 DomDietPi cron[606]: (CRON) INFO (Running @reboot jobs)
Jul 06 16:03:29 DomDietPi systemd[619]: radarr.service:Failed to set up mount namespacing: No such file or directory
Jul 06 16:03:29 DomDietPi systemd[619]: radarr.service:Failed at step NAMESPACE spawning /opt/radarr/Radarr: No such file or directory
Jul 06 16:03:29 DomDietPi systemd[1]: radarr.service: Main process exited, code=exited, status=226/NAMESPACE
Jul 06 16:03:29 DomDietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Welcome to our community
If I remember well, we had a couple of such reports in the past. We never found out what the issue was. But usually it was fixed to reinstall Radarr. [Resolved] Radarr and Sonarr services failed - #3 by thewhatofwhom
dietpi-software reinstall 145
Sorry I forgot to mention I did see others have success with a reinstall, but that didn’t work for me. I believe it successfully reinstalled using that command however the same issue is occuring
as said, we never found a solution for this. Maybe @MichaIng has an idea.
This error happens when systemd is trying to apply sandboxing for directories which do not exist. Was this a fresh Radarr install?
was this with the service definition where we had directories that did not exist but we tried to limit access of the application to this directories? Maybe I’m mixing up thinks. :roll_eyes:
Yes, respectively we tired to explicitly grant permissions to directories (otherwise preventing for all others) which in cases did not exist. A while ago we switched to a syntax which allows the directories to be missing, but I think we didn’t force an update of Radarr (including the service file) that time.
ok let’s check service configuration for @boofbuscus . Can you share following
systemctl cat radarr
Sure, here is the output
# /etc/systemd/system/radarr.service
[Unit]
Description=Radarr (DietPi)
Wants=network-online.target
After=network-online.target
[Service]
SyslogIdentifier=Radarr
User=radarr
UMask=002
LogsDirectory=radarr
ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
TimeoutStopSec=20
KillMode=process
Restart=on-failure
# Hardening
ProtectSystem=strict
ProtectHome=true
PrivateDevices=true
ProtectKernelTunables=true
ProtectControlGroups=true
ReadWritePaths=-/opt/radarr -/mnt -/media -/var/log/radarr -/tmp
[Install]
WantedBy=multi-user.target
# /etc/systemd/system/radarr.service.d/dietpi-process_tool.conf
# WARNING: Do not manually edit this file, use "dietpi-services" to adjust values!
[Service]
CPUSchedulingPolicy=idle
IOSchedulingClass=idle
# /etc/systemd/system/radarr.service.d/dietpi-services_edit.conf
[Unit]
#Description=Radarr Daemon (DietPi)
#Wants=network-online.target
#After=network-online.target dietpi-boot.service
[Service]
#SyslogIdentifier=Radarr
#User=radarr
#UMask=002
#ExecStart=/usr/bin/mono -O=-aot /opt/Radarr/Radarr.exe -nobrowser -data=/mnt/dietpi_userdata/radarr
#TimeoutStopSec=20
#KillMode=process
#Restart=on-failure
# Hardening
#ProtectSystem=strict
#ProtectHome=true
#PrivateDevices=true
#ProtectKernelTunables=true
#ProtectControlGroups=true
ReadWritePaths=/opt/Radarr /mnt /media /var/log/radarr /tmp /mnt/6E9485699485351D/Movies
[Install]
#WantedBy=multi-user.target
Could it be something to do with the User data location? Mine has changed from default, to /mnt/Media/dietpi_userdata
Ah, in dietpi-services adjust the override for the Jellyfin service the contain dashes - in front of each path in the ReadWritePaths= line. Compare with the actual service of your output above. Or remove the override config competely of the custom path you added is not used anymore.
Sorry I’m a bit confused what to do here. Is this correct?
  • dietpi-services
  • open ‘radarr’
  • open ‘edit’ for /etc/systemd/system/radarr.service
What I see here is the only line that is ‘not’ commented out is the ReadWritePaths, which states:
ReadWritePaths=/opt/Radarr /mnt /media /var/log/radarr /tmp /mnt/6E948569948535$
So should I add dashs - to match the systemctl output above? Or comment out the entire line? What about the /mnt/6E948569948535$ at the end which is not listed in the systemctl output?
Sorry for the noob questions, still learning! Also interested in what is causing this issue and what these changes are doing to fix it, it’s all interesting stuff to me
Cheers!
Hey @MichaIng just checking in regarding the question above.
Thanks!
Sorry for the late answer. Yes add the dashes - as you described. You must have added the additional entry sometime in the past to show Radarr to write to this path. If you do not use it anymore, you could clear/remove the whole file instead:
sudo rm /etc/systemd/system/radarr.service.d/dietpi-services_edit.conf
sudo systemctl daemon-reload
sudo systemctl restart radarr
So I dashed out the lines as mentioned, including the /mnt and gave radarr and dietpi a full reboot, but radarr never came online, not even briefly like it used to.
Here’s systemctl since adding dashes
[Unit]
[Service]
User=radarr
UMask=002
TimeoutStopSec=20
KillMode=process
Restart=on-failure
# Hardening
ProtectHome=true
PrivateDevices=true
[Install]
s!
[Service]
[Unit]
[Service]
#User=radarr
#UMask=002
#TimeoutStopSec=20
#KillMode=process
#Restart=on-failure
# Hardening
#ProtectHome=true
ReadWritePaths=-/opt/Radarr -/mnt -/media -/var/log/radarr -/tmp -/mnt/6E9485699
485351D/Movies
[Install]
And I’m getting the following in journalctl
Aug 02 10:06:07 DomDietPi systemd[592]: radarr.service:
Failed to execute command: Permission denied
Failed at step EXEC spawning /opt/radarr/Radarr: Permission denied
I removed the file as you mentioned above, reboot, and still getting the same journalctl errors…
but it’s a different issue now. Can you check following
ls -la /opt/radarr/
Sure, here’s the output
total 116648
drwxr-xr-x 5 radarr dietpi    28672 Jul  6 14:53 .
drwxr-xr-x 8 root   root       4096 Jul  6 15:30 ..
-rw-r--r-- 1 radarr dietpi  2932912 Jul  6 14:51 BouncyCastle.Crypto.dll
-rw-r--r-- 1 radarr dietpi   202752 Jul  6 14:51 Dapper.dll
-rw-r--r-- 1 radarr dietpi    11264 Jul  6 14:51 DryIoc.Microsoft.DependencyInje        ction.dll
-rw-r--r-- 1 radarr dietpi   167424 Jul  6 14:51 Dynamitey.dll
-rw-r--r-- 1 radarr dietpi    96768 Jul  6 14:51 FluentMigrator.Abstractions.dll
-rw-r--r-- 1 radarr dietpi     9728 Jul  6 14:51 FluentMigrator.Extensions.Oracl        e.dll
-rw-r--r-- 1 radarr dietpi    20480 Jul  6 14:51 FluentMigrator.Extensions.Postg        res.dll
-rw-r--r-- 1 radarr dietpi     9216 Jul  6 14:51 FluentMigrator.Extensions.SqlAn        ywhere.dll
-rw-r--r-- 1 radarr dietpi   126464 Jul  6 14:51 FluentMigrator.Runner.Core.dll
-rw-r--r-- 1 radarr dietpi    33792 Jul  6 14:51 FluentMigrator.Runner.Db2.dll
-rw-r--r-- 1 radarr dietpi    75776 Jul  6 14:51 FluentMigrator.Runner.Firebird.        dll
-rw-r--r-- 1 radarr dietpi    26112 Jul  6 14:51 FluentMigrator.Runner.MySql.dll
-rw-r--r-- 1 radarr dietpi    43008 Jul  6 14:51 FluentMigrator.Runner.Oracle.dl        l
-rw-r--r-- 1 radarr dietpi    46592 Jul  6 14:51 FluentMigrator.Runner.Postgres.        dll
-rw-r--r-- 1 radarr dietpi    27648 Jul  6 14:51 FluentMigrator.Runner.Redshift.        dll
-rw-r--r-- 1 radarr dietpi    37376 Jul  6 14:51 FluentMigrator.Runner.SqlAnywhe        re.dll
-rw-r--r-- 1 radarr dietpi    55808 Jul  6 14:51 FluentMigrator.Runner.SqlServer        .dll
-rw-r--r-- 1 radarr dietpi    20480 Jul  6 14:51 FluentMigrator.Runner.SqlServer        Ce.dll
-rw-r--r-- 1 radarr dietpi   105984 Jul  6 14:51 FluentMigrator.Runner.dll
-rw-r--r-- 1 radarr dietpi    57856 Jul  6 14:51 FluentMigrator.dll
-rw-r--r-- 1 radarr dietpi   339456 Jul  6 14:51 FluentValidation.dll
-rw-r--r-- 1 radarr dietpi   204800 Jul  6 14:51 ICSharpCode.SharpZipLib.dll
-rw-r--r-- 1 radarr dietpi   189440 Jul  6 14:51 Ical.Net.dll
-rw-r--r-- 1 radarr dietpi    71168 Jul  6 14:51 ImpromptuInterface.dll
-rw-r--r-- 1 radarr dietpi    13824 Jul  6 14:51 Instances.dll
-rw-r--r-- 1 radarr dietpi    35141 Jul  6 14:51 LICENSE
drwxr-xr-x 3 radarr dietpi     4096 Jul  6 14:52 Localization
-rw-r--r-- 1 radarr dietpi   846848 Jul  6 14:51 MailKit.dll
-rw-r--r-- 1 radarr dietpi    58496 Jul  6 14:51 Microsoft.AspNetCore.Authentica        tion.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   116848 Jul  6 14:51 Microsoft.AspNetCore.Authentica        tion.Cookies.dll
-rw-r--r-- 1 radarr dietpi    88704 Jul  6 14:51 Microsoft.AspNetCore.Authentica        tion.Core.dll
-rw-r--r-- 1 radarr dietpi   106624 Jul  6 14:51 Microsoft.AspNetCore.Authentica        tion.OAuth.dll
-rw-r--r-- 1 radarr dietpi   161920 Jul  6 14:51 Microsoft.AspNetCore.Authentica        tion.dll
-rw-r--r-- 1 radarr dietpi    63104 Jul  6 14:51 Microsoft.AspNetCore.Authorizat        ion.Policy.dll
-rw-r--r-- 1 radarr dietpi    98432 Jul  6 14:51 Microsoft.AspNetCore.Authorizat        ion.dll
-rw-r--r-- 1 radarr dietpi    51840 Jul  6 14:51 Microsoft.AspNetCore.Components        .Authorization.dll
-rw-r--r-- 1 radarr dietpi    68736 Jul  6 14:51 Microsoft.AspNetCore.Components        .Forms.dll
-rw-r--r-- 1 radarr dietpi   804992 Jul  6 14:51 Microsoft.AspNetCore.Components        .Server.dll
-rw-r--r-- 1 radarr dietpi   331904 Jul  6 14:51 Microsoft.AspNetCore.Components        .Web.dll
-rw-r--r-- 1 radarr dietpi   631424 Jul  6 14:51 Microsoft.AspNetCore.Components        .dll
-rw-r--r-- 1 radarr dietpi    71296 Jul  6 14:51 Microsoft.AspNetCore.Connection        s.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    53376 Jul  6 14:51 Microsoft.AspNetCore.CookiePoli        cy.dll
-rw-r--r-- 1 radarr dietpi    89728 Jul  6 14:51 Microsoft.AspNetCore.Cors.dll
-rw-r--r-- 1 radarr dietpi    72832 Jul  6 14:51 Microsoft.AspNetCore.Cryptograp        hy.Internal.dll
-rw-r--r-- 1 radarr dietpi    36992 Jul  6 14:51 Microsoft.AspNetCore.Cryptograp        hy.KeyDerivation.dll
-rw-r--r-- 1 radarr dietpi    42112 Jul  6 14:51 Microsoft.AspNetCore.DataProtec        tion.Extensions.dll
-rw-r--r-- 1 radarr dietpi    24192 Jul  6 14:51 Microsoft.AspNetCore.Diagnostic        s.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    46208 Jul  6 14:51 Microsoft.AspNetCore.Diagnostic        s.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi   433280 Jul  6 14:51 Microsoft.AspNetCore.Diagnostic        s.dll
-rw-r--r-- 1 radarr dietpi    39040 Jul  6 14:51 Microsoft.AspNetCore.HostFilter        ing.dll
-rw-r--r-- 1 radarr dietpi    35456 Jul  6 14:51 Microsoft.AspNetCore.Hosting.Ab        stractions.dll
-rw-r--r-- 1 radarr dietpi    20608 Jul  6 14:51 Microsoft.AspNetCore.Hosting.Se        rver.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   426624 Jul  6 14:51 Microsoft.AspNetCore.Hosting.dl        l
-rw-r--r-- 1 radarr dietpi    34432 Jul  6 14:51 Microsoft.AspNetCore.Html.Abstr        actions.dll
-rw-r--r-- 1 radarr dietpi   348800 Jul  6 14:51 Microsoft.AspNetCore.Http.Exten        sions.dll
-rw-r--r-- 1 radarr dietpi    63616 Jul  6 14:51 Microsoft.AspNetCore.Http.Featu        res.dll
-rw-r--r-- 1 radarr dietpi   159360 Jul  6 14:51 Microsoft.AspNetCore.Http.Resul        ts.dll
-rw-r--r-- 1 radarr dietpi   212096 Jul  6 14:51 Microsoft.AspNetCore.Identity.d        ll
-rw-r--r-- 1 radarr dietpi    22144 Jul  6 14:51 Microsoft.AspNetCore.Localizati        on.Routing.dll
-rw-r--r-- 1 radarr dietpi    63104 Jul  6 14:51 Microsoft.AspNetCore.Localizati        on.dll
-rw-r--r-- 1 radarr dietpi    17520 Jul  6 14:51 Microsoft.AspNetCore.Metadata.d        ll
-rw-r--r-- 1 radarr dietpi   228480 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Abstra        ctions.dll
-rw-r--r-- 1 radarr dietpi   159360 Jul  6 14:51 Microsoft.AspNetCore.Mvc.ApiExp        lorer.dll
-rw-r--r-- 1 radarr dietpi  2146432 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Core.d        ll
-rw-r--r-- 1 radarr dietpi    50304 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Cors.d        ll
-rw-r--r-- 1 radarr dietpi   115840 Jul  6 14:51 Microsoft.AspNetCore.Mvc.DataAn        notations.dll
-rw-r--r-- 1 radarr dietpi    17024 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Format        ters.Json.dll
-rw-r--r-- 1 radarr dietpi   128128 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Format        ters.Xml.dll
-rw-r--r-- 1 radarr dietpi    47232 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Locali        zation.dll
-rw-r--r-- 1 radarr dietpi   272512 Jul  6 14:51 Microsoft.AspNetCore.Mvc.Razor.        dll
-rw-r--r-- 1 radarr dietpi   521840 Jul  6 14:51 Microsoft.AspNetCore.Mvc.RazorP        ages.dll
-rw-r--r-- 1 radarr dietpi   315520 Jul  6 14:51 Microsoft.AspNetCore.Mvc.TagHel        pers.dll
-rw-r--r-- 1 radarr dietpi   923264 Jul  6 14:51 Microsoft.AspNetCore.Mvc.ViewFe        atures.dll
-rw-r--r-- 1 radarr dietpi    35456 Jul  6 14:51 Microsoft.AspNetCore.Mvc.dll
-rw-r--r-- 1 radarr dietpi    70784 Jul  6 14:51 Microsoft.AspNetCore.Razor.Runt        ime.dll
-rw-r--r-- 1 radarr dietpi    70272 Jul  6 14:51 Microsoft.AspNetCore.Razor.dll
-rw-r--r-- 1 radarr dietpi    18560 Jul  6 14:51 Microsoft.AspNetCore.ResponseCa        ching.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   158848 Jul  6 14:51 Microsoft.AspNetCore.ResponseCa        ching.dll
-rw-r--r-- 1 radarr dietpi    81536 Jul  6 14:51 Microsoft.AspNetCore.ResponseCo        mpression.dll
-rw-r--r-- 1 radarr dietpi   244864 Jul  6 14:51 Microsoft.AspNetCore.Rewrite.dl        l
-rw-r--r-- 1 radarr dietpi    59008 Jul  6 14:51 Microsoft.AspNetCore.Routing.Ab        stractions.dll
-rw-r--r-- 1 radarr dietpi   839296 Jul  6 14:51 Microsoft.AspNetCore.Routing.dl        l
-rw-r--r-- 1 radarr dietpi   634496 Jul  6 14:51 Microsoft.AspNetCore.Server.Htt        pSys.dll
-rw-r--r-- 1 radarr dietpi   688256 Jul  6 14:51 Microsoft.AspNetCore.Server.IIS        .dll
-rw-r--r-- 1 radarr dietpi   238208 Jul  6 14:51 Microsoft.AspNetCore.Server.Kes        trel.Transport.Quic.dll
-rw-r--r-- 1 radarr dietpi   166016 Jul  6 14:51 Microsoft.AspNetCore.Server.Kes        trel.Transport.Sockets.dll
-rw-r--r-- 1 radarr dietpi    24192 Jul  6 14:51 Microsoft.AspNetCore.Server.Kes        trel.dll
-rw-r--r-- 1 radarr dietpi    92288 Jul  6 14:51 Microsoft.AspNetCore.Session.dl        l
-rw-r--r-- 1 radarr dietpi    78464 Jul  6 14:51 Microsoft.AspNetCore.SignalR.Pr        otocols.Json.dll
-rw-r--r-- 1 radarr dietpi    29824 Jul  6 14:51 Microsoft.AspNetCore.SignalR.dl        l
-rw-r--r-- 1 radarr dietpi   170112 Jul  6 14:51 Microsoft.AspNetCore.StaticFile        s.dll
-rw-r--r-- 1 radarr dietpi    65136 Jul  6 14:51 Microsoft.AspNetCore.WebSockets        .dll
-rw-r--r-- 1 radarr dietpi   282240 Jul  6 14:51 Microsoft.AspNetCore.WebUtiliti        es.dll
-rw-r--r-- 1 radarr dietpi   115328 Jul  6 14:51 Microsoft.AspNetCore.dll
-rw-r--r-- 1 radarr dietpi   951920 Jul  6 14:51 Microsoft.CSharp.dll
-rw-r--r-- 1 radarr dietpi  1397208 Jul  6 14:51 Microsoft.Data.SqlClient.dll
-rw-r--r-- 1 radarr dietpi    49304 Jul  6 14:51 Microsoft.Extensions.Caching.Ab        stractions.dll
-rw-r--r-- 1 radarr dietpi    85656 Jul  6 14:51 Microsoft.Extensions.Caching.Me        mory.dll
-rw-r--r-- 1 radarr dietpi    37016 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.CommandLine.dll
-rw-r--r-- 1 radarr dietpi    25752 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.EnvironmentVariables.dll
-rw-r--r-- 1 radarr dietpi    43672 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.FileExtensions.dll
-rw-r--r-- 1 radarr dietpi    35440 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.Ini.dll
-rw-r--r-- 1 radarr dietpi    42136 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.Json.dll
-rw-r--r-- 1 radarr dietpi    32896 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.KeyPerFile.dll
-rw-r--r-- 1 radarr dietpi    37528 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.UserSecrets.dll
-rw-r--r-- 1 radarr dietpi    83096 Jul  6 14:51 Microsoft.Extensions.Configurat        ion.dll
-rw-r--r-- 1 radarr dietpi    96920 Jul  6 14:51 Microsoft.Extensions.Dependency        Injection.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    33920 Jul  6 14:51 Microsoft.Extensions.Diagnostic        s.HealthChecks.Abstractions.dll
-rw-r--r-- 1 radarr dietpi   107136 Jul  6 14:51 Microsoft.Extensions.Diagnostic        s.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi    33920 Jul  6 14:51 Microsoft.Extensions.Features.d        ll
-rw-r--r-- 1 radarr dietpi    29848 Jul  6 14:51 Microsoft.Extensions.FileProvid        ers.Abstractions.dll
-rw-r--r-- 1 radarr dietpi    24216 Jul  6 14:51 Microsoft.Extensions.FileProvid        ers.Composite.dll
-rw-r--r-- 1 radarr dietpi    70784 Jul  6 14:51 Microsoft.Extensions.FileProvid        ers.Embedded.dll
-rw-r--r-- 1 radarr dietpi    91288 Jul  6 14:51 Microsoft.Extensions.FileProvid        ers.Physical.dll
-rw-r--r-- 1 radarr dietpi    47256 Jul  6 14:51 Microsoft.Extensions.Hosting.Ab        stractions.dll
-rw-r--r-- 1 radarr dietpi    22640 Jul  6 14:51 Microsoft.Extensions.Hosting.Wi        ndowsServices.dll
-rw-r--r-- 1 radarr dietpi   122520 Jul  6 14:51 Microsoft.Extensions.Hosting.dl        l
-rw-r--r-- 1 radarr dietpi   162928 Jul  6 14:51 Microsoft.Extensions.Http.dll
-rw-r--r-- 1 radarr dietpi    83584 Jul  6 14:51 Microsoft.Extensions.Identity.S        tores.dll
-rw-r--r-- 1 radarr dietpi    56960 Jul  6 14:51 Microsoft.Extensions.Localizati        on.dll
-rw-r--r-- 1 radarr dietpi   152216 Jul  6 14:51 Microsoft.Extensions.Logging.Ab        stractions.dll
-rw-r--r-- 1 radarr dietpi    42648 Jul  6 14:51 Microsoft.Extensions.Logging.Co        nfiguration.dll
-rw-r--r-- 1 radarr dietpi    22680 Jul  6 14:51 Microsoft.Extensions.Logging.De        bug.dll
-rw-r--r-- 1 radarr dietpi    59544 Jul  6 14:51 Microsoft.Extensions.Logging.Ev        entSource.dll
-rw-r--r-- 1 radarr dietpi    29848 Jul  6 14:51 Microsoft.Extensions.Logging.Tr        aceSource.dll
-rw-r--r-- 1 radarr dietpi    96920 Jul  6 14:51 Microsoft.Extensions.Logging.dl        l
And second half below:
-rw-r--r-- 1 radarr dietpi    33904 Jul  6 14:51 Microsoft.Extensions.Options.Co        nfigurationExtensions.dll
-rw-r--r-- 1 radarr dietpi    26776 Jul  6 14:51 Microsoft.Extensions.Options.Da        taAnnotations.dll
-rw-r--r-- 1 radarr dietpi    33408 Jul  6 14:51 Microsoft.Extensions.WebEncoder        s.dll
-rw-r--r-- 1 radarr dietpi  1310664 Jul  6 14:51 Microsoft.Identity.Client.dll
-rw-r--r-- 1 radarr dietpi    62840 Jul  6 14:51 Microsoft.IdentityModel.JsonWeb        Tokens.dll
-rw-r--r-- 1 radarr dietpi   108920 Jul  6 14:51 Microsoft.IdentityModel.Protoco        ls.OpenIdConnect.dll
-rw-r--r-- 1 radarr dietpi    32632 Jul  6 14:51 Microsoft.IdentityModel.Protoco        ls.dll
-rw-r--r-- 1 radarr dietpi   870264 Jul  6 14:51 Microsoft.IdentityModel.Tokens.        dll
-rw-r--r-- 1 radarr dietpi   146048 Jul  6 14:51 Microsoft.JSInterop.dll
-rw-r--r-- 1 radarr dietpi   248960 Jul  6 14:51 Microsoft.Net.Http.Headers.dll
-rw-r--r-- 1 radarr dietpi   173960 Jul  6 14:51 Microsoft.OpenApi.dll
-rw-r--r-- 1 radarr dietpi  1410672 Jul  6 14:51 Microsoft.VisualBasic.Core.dll
-rw-r--r-- 1 radarr dietpi    18072 Jul  6 14:51 Microsoft.VisualBasic.dll
-rw-r--r-- 1 radarr dietpi    24176 Jul  6 14:51 Microsoft.Win32.Primitives.dll
-rw-r--r-- 1 radarr dietpi    63600 Jul  6 14:51 Microsoft.Win32.Registry.dll
-rw-r--r-- 1 radarr dietpi    26224 Jul  6 14:51 Microsoft.Win32.SystemEvents.dl        l
-rw-r--r-- 1 radarr dietpi  1022464 Jul  6 14:51 MimeKit.dll
-rw-r--r-- 1 radarr dietpi    68608 Jul  6 14:51 Mono.Nat.dll
-rw-r--r-- 1 radarr dietpi   643584 Jul  6 14:51 MonoTorrent.dll
-rw-r--r-- 1 radarr dietpi    55296 Jul  6 14:51 NLog.Extensions.Logging.dll
-rw-r--r-- 1 radarr dietpi   724992 Jul  6 14:51 NLog.Targets.Syslog.dll
-rw-r--r-- 1 radarr dietpi   823296 Jul  6 14:51 NLog.dll
-rw-r--r-- 1 radarr dietpi   695336 Jul  6 14:51 Newtonsoft.Json.dll
-rw-r--r-- 1 radarr dietpi   200416 Jul  6 14:51 Radarr
-rw-r--r-- 1 radarr dietpi   141280 Jul  6 14:51 Radarr.Api.V3.deps.json
-rw-r--r-- 1 radarr dietpi    96560 Jul  6 14:51 Radarr.Api.V3.pdb
-rw-r--r-- 1 radarr dietpi    50419 Jul  6 14:51 Radarr.Common.deps.json
-rw-r--r-- 1 radarr dietpi   239616 Jul  6 14:51 Radarr.Common.dll
-rw-r--r-- 1 radarr dietpi    94344 Jul  6 14:51 Radarr.Common.pdb
-rw-r--r-- 1 radarr dietpi    84287 Jul  6 14:51 Radarr.Core.deps.json
-rw-r--r-- 1 radarr dietpi  1949696 Jul  6 14:51 Radarr.Core.dll
-rw-r--r-- 1 radarr dietpi   677776 Jul  6 14:51 Radarr.Core.pdb
-rw-r--r-- 1 radarr dietpi   144713 Jul  6 14:51 Radarr.Host.deps.json
-rw-r--r-- 1 radarr dietpi    39424 Jul  6 14:51 Radarr.Host.dll
-rw-r--r-- 1 radarr dietpi    30152 Jul  6 14:51 Radarr.Host.pdb
-rw-r--r-- 1 radarr dietpi   139692 Jul  6 14:51 Radarr.Http.deps.json
-rw-r--r-- 1 radarr dietpi    77312 Jul  6 14:51 Radarr.Http.dll
-rw-r--r-- 1 radarr dietpi    47084 Jul  6 14:51 Radarr.Http.pdb
-rw-r--r-- 1 radarr dietpi    51623 Jul  6 14:51 Radarr.Mono.deps.json
-rw-r--r-- 1 radarr dietpi    21536 Jul  6 14:51 Radarr.Mono.pdb
-rw-r--r-- 1 radarr dietpi    79141 Jul  6 14:51 Radarr.SignalR.deps.json
-rw-r--r-- 1 radarr dietpi     9728 Jul  6 14:51 Radarr.SignalR.dll
-rw-r--r-- 1 radarr dietpi    23096 Jul  6 14:51 Radarr.SignalR.pdb
-rw-r--r-- 1 radarr dietpi   211476 Jul  6 14:51 Radarr.deps.json
-rw-r--r-- 1 radarr dietpi   118784 Jul  6 14:51 Radarr.dll
-rw-r--r-- 1 radarr dietpi    23460 Jul  6 14:51 Radarr.pdb
-rw-r--r-- 1 radarr dietpi      376 Jul  6 14:51 Radarr.runtimeconfig.json
-rw-r--r-- 1 radarr dietpi    21504 Jul  6 14:51 ReusableTasks.dll
-rw-r--r-- 1 radarr dietpi   416768 Jul  6 14:51 Sentry.dll
-rw-r--r-- 1 radarr dietpi   200416 Jul  6 14:51 ServiceInstall
-rw-r--r-- 1 radarr dietpi   200416 Jul  6 14:51 ServiceUninstall
-rw-r--r-- 1 radarr dietpi  1229824 Jul  6 14:51 SixLabors.ImageSharp.dll
-rw-r--r-- 1 radarr dietpi    14848 Jul  6 14:51 Swashbuckle.AspNetCore.Swagger.        dll
-rw-r--r-- 1 radarr dietpi    14448 Jul  6 14:51 System.Buffers.dll
-rw-r--r-- 1 radarr dietpi   685168 Jul  6 14:51 System.Collections.Immutable.dl        l
-rw-r--r-- 1 radarr dietpi   114800 Jul  6 14:51 System.Collections.NonGeneric.d        ll
-rw-r--r-- 1 radarr dietpi   109168 Jul  6 14:51 System.Collections.Specialized.        dll
-rw-r--r-- 1 radarr dietpi   308848 Jul  6 14:51 System.Collections.dll
-rw-r--r-- 1 radarr dietpi    17536 Jul  6 14:51 System.ComponentModel.DataAnnot        ations.dll
-rw-r--r-- 1 radarr dietpi    41072 Jul  6 14:51 System.ComponentModel.EventBase        dAsync.dll
-rw-r--r-- 1 radarr dietpi    85616 Jul  6 14:51 System.ComponentModel.Primitive        s.dll
-rw-r--r-- 1 radarr dietpi   861296 Jul  6 14:51 System.ComponentModel.TypeConve        rter.dll
-rw-r--r-- 1 radarr dietpi    19096 Jul  6 14:51 System.ComponentModel.dll
-rw-r--r-- 1 radarr dietpi   395376 Jul  6 14:51 System.Configuration.Configurat        ionManager.dll
-rw-r--r-- 1 radarr dietpi    19584 Jul  6 14:51 System.Configuration.dll
-rw-r--r-- 1 radarr dietpi   213104 Jul  6 14:51 System.Console.dll
-rw-r--r-- 1 radarr dietpi    24216 Jul  6 14:51 System.Core.dll
-rw-r--r-- 1 radarr dietpi  3514992 Jul  6 14:51 System.Data.Common.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Data.DataSetExtensions.d        ll
-rw-r--r-- 1 radarr dietpi   357376 Jul  6 14:51 System.Data.SQLite.dll
-rw-r--r-- 1 radarr dietpi   470240 Jul  6 14:51 System.Data.SqlServerCe.dll
-rw-r--r-- 1 radarr dietpi    24688 Jul  6 14:51 System.Data.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Diagnostics.Contracts.dl        l
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Diagnostics.Debug.dll
-rw-r--r-- 1 radarr dietpi   433264 Jul  6 14:51 System.Diagnostics.DiagnosticSo        urce.dll
-rw-r--r-- 1 radarr dietpi    42096 Jul  6 14:51 System.Diagnostics.FileVersionI        nfo.dll
-rw-r--r-- 1 radarr dietpi   297624 Jul  6 14:51 System.Diagnostics.Process.dll
-rw-r--r-- 1 radarr dietpi    65648 Jul  6 14:51 System.Diagnostics.TextWriterTr        aceListener.dll
-rw-r--r-- 1 radarr dietpi   152176 Jul  6 14:51 System.Diagnostics.TraceSource.        dll
-rw-r--r-- 1 radarr dietpi    16536 Jul  6 14:51 System.Diagnostics.Tracing.dll
-rw-r--r-- 1 radarr dietpi   427112 Jul  6 14:51 System.Drawing.Common.dll
-rw-r--r-- 1 radarr dietpi   138352 Jul  6 14:51 System.Drawing.Primitives.dll
-rw-r--r-- 1 radarr dietpi    21144 Jul  6 14:51 System.Drawing.dll
-rw-r--r-- 1 radarr dietpi   225392 Jul  6 14:51 System.Formats.Asn1.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Globalization.Calendars.        dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.Globalization.Extensions        .dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Globalization.dll
-rw-r--r-- 1 radarr dietpi    80024 Jul  6 14:51 System.IO.Compression.Brotli.dl        l
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.IO.Compression.FileSyste        m.dll
-rw-r--r-- 1 radarr dietpi    56944 Jul  6 14:51 System.IO.Compression.ZipFile.d        ll
-rw-r--r-- 1 radarr dietpi   306840 Jul  6 14:51 System.IO.Compression.dll
-rw-r--r-- 1 radarr dietpi    85616 Jul  6 14:51 System.IO.FileSystem.DriveInfo.        dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.IO.FileSystem.Primitives        .dll
-rw-r--r-- 1 radarr dietpi   107120 Jul  6 14:51 System.IO.FileSystem.Watcher.dl        l
-rw-r--r-- 1 radarr dietpi    24192 Jul  6 14:51 System.IO.FileSystem.dll
-rw-r--r-- 1 radarr dietpi    89712 Jul  6 14:51 System.IO.IsolatedStorage.dll
-rw-r--r-- 1 radarr dietpi    83568 Jul  6 14:51 System.IO.MemoryMappedFiles.dll
-rw-r--r-- 1 radarr dietpi   215168 Jul  6 14:51 System.IO.Pipelines.dll
-rw-r--r-- 1 radarr dietpi   143512 Jul  6 14:51 System.IO.Pipes.dll
-rw-r--r-- 1 radarr dietpi    14448 Jul  6 14:51 System.IO.UnmanagedMemoryStream        .dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.IO.dll
-rw-r--r-- 1 radarr dietpi  5024920 Jul  6 14:51 System.Linq.Expressions.dll
-rw-r--r-- 1 radarr dietpi   988824 Jul  6 14:51 System.Linq.Parallel.dll
-rw-r--r-- 1 radarr dietpi   275056 Jul  6 14:51 System.Linq.Queryable.dll
-rw-r--r-- 1 radarr dietpi   617112 Jul  6 14:51 System.Linq.dll
-rw-r--r-- 1 radarr dietpi   199320 Jul  6 14:51 System.Memory.dll
-rw-r--r-- 1 radarr dietpi    89712 Jul  6 14:51 System.Net.Http.Json.dll
-rw-r--r-- 1 radarr dietpi  1974936 Jul  6 14:51 System.Net.Http.dll
-rw-r--r-- 1 radarr dietpi   576152 Jul  6 14:51 System.Net.Mail.dll
-rw-r--r-- 1 radarr dietpi    96368 Jul  6 14:51 System.Net.NameResolution.dll
-rw-r--r-- 1 radarr dietpi   185496 Jul  6 14:51 System.Net.NetworkInformation.d        ll
-rw-r--r-- 1 radarr dietpi   108696 Jul  6 14:51 System.Net.Ping.dll
-rw-r--r-- 1 radarr dietpi   258160 Jul  6 14:51 System.Net.Primitives.dll
-rw-r--r-- 1 radarr dietpi   333464 Jul  6 14:51 System.Net.Quic.dll
-rw-r--r-- 1 radarr dietpi   403608 Jul  6 14:51 System.Net.Requests.dll
-rw-r--r-- 1 radarr dietpi   786072 Jul  6 14:51 System.Net.Security.dll
-rw-r--r-- 1 radarr dietpi    39576 Jul  6 14:51 System.Net.ServicePoint.dll
-rw-r--r-- 1 radarr dietpi   669808 Jul  6 14:51 System.Net.Sockets.dll
-rw-r--r-- 1 radarr dietpi   187544 Jul  6 14:51 System.Net.WebClient.dll
-rw-r--r-- 1 radarr dietpi    34456 Jul  6 14:51 System.Net.WebProxy.dll
-rw-r--r-- 1 radarr dietpi    83056 Jul  6 14:51 System.Net.WebSockets.Client.dl        l
-rw-r--r-- 1 radarr dietpi   203376 Jul  6 14:51 System.Net.WebSockets.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Numerics.Vectors.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Numerics.dll
-rw-r--r-- 1 radarr dietpi   102000 Jul  6 14:51 System.ObjectModel.dll
-rw-r--r-- 1 radarr dietpi 11912856 Jul  6 14:51 System.Private.CoreLib.dll
-rw-r--r-- 1 radarr dietpi   281240 Jul  6 14:51 System.Private.Uri.dll
-rw-r--r-- 1 radarr dietpi   472688 Jul  6 14:51 System.Private.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi  9962136 Jul  6 14:51 System.Private.Xml.dll
-rw-r--r-- 1 radarr dietpi    71832 Jul  6 14:51 System.Reflection.DispatchProxy        .dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Reflection.Emit.ILGenera        tion.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Reflection.Emit.Lightwei        ght.dll
-rw-r--r-- 1 radarr dietpi  1255576 Jul  6 14:51 System.Reflection.Metadata.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Reflection.Primitives.dl        l
-rw-r--r-- 1 radarr dietpi    34416 Jul  6 14:51 System.Reflection.TypeExtension        s.dll
-rw-r--r-- 1 radarr dietpi    15472 Jul  6 14:51 System.Reflection.dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.Resources.Reader.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Resources.ResourceManage        r.dll
-rw-r--r-- 1 radarr dietpi    48752 Jul  6 14:51 System.Resources.Writer.dll
-rw-r--r-- 1 radarr dietpi    83528 Jul  6 14:51 System.Runtime.Caching.dll
-rw-r--r-- 1 radarr dietpi    22680 Jul  6 14:51 System.Runtime.CompilerServices        .Unsafe.dll
-rw-r--r-- 1 radarr dietpi    19568 Jul  6 14:51 System.Runtime.CompilerServices        .VisualC.dll
-rw-r--r-- 1 radarr dietpi    17008 Jul  6 14:51 System.Runtime.Extensions.dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.Runtime.Handles.dll
-rw-r--r-- 1 radarr dietpi    55448 Jul  6 14:51 System.Runtime.InteropServices.        dll
-rw-r--r-- 1 radarr dietpi    15472 Jul  6 14:51 System.Runtime.Intrinsics.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Runtime.Loader.dll
-rw-r--r-- 1 radarr dietpi   372336 Jul  6 14:51 System.Runtime.Serialization.Fo        rmatters.dll
-rw-r--r-- 1 radarr dietpi    30360 Jul  6 14:51 System.Runtime.Serialization.Pr        imitives.dll
-rw-r--r-- 1 radarr dietpi    17560 Jul  6 14:51 System.Runtime.Serialization.dl        l
-rw-r--r-- 1 radarr dietpi    42648 Jul  6 14:51 System.Runtime.dll
-rw-r--r-- 1 radarr dietpi    52848 Jul  6 14:51 System.Security.AccessControl.d        ll
-rw-r--r-- 1 radarr dietpi   850544 Jul  6 14:51 System.Security.Cryptography.Al        gorithms.dll
-rw-r--r-- 1 radarr dietpi    48752 Jul  6 14:51 System.Security.Cryptography.Cn        g.dll
-rw-r--r-- 1 radarr dietpi   135792 Jul  6 14:51 System.Security.Cryptography.Cs        p.dll
-rw-r--r-- 1 radarr dietpi   112752 Jul  6 14:51 System.Security.Cryptography.En        coding.dll
-rw-r--r-- 1 radarr dietpi   234136 Jul  6 14:51 System.Security.Cryptography.Op        enSsl.dll
-rw-r--r-- 1 radarr dietpi   152176 Jul  6 14:51 System.Security.Cryptography.Pr        imitives.dll
-rw-r--r-- 1 radarr dietpi    20592 Jul  6 14:51 System.Security.Cryptography.Pr        otectedData.dll
-rw-r--r-- 1 radarr dietpi   872600 Jul  6 14:51 System.Security.Cryptography.X5        09Certificates.dll
-rw-r--r-- 1 radarr dietpi   521344 Jul  6 14:51 System.Security.Cryptography.Xm        l.dll
-rw-r--r-- 1 radarr dietpi    37016 Jul  6 14:51 System.Security.Principal.Windo        ws.dll
-rw-r--r-- 1 radarr dietpi    14448 Jul  6 14:51 System.Security.Principal.dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.Security.SecureString.dl        l
-rw-r--r-- 1 radarr dietpi    16496 Jul  6 14:51 System.ServiceModel.Web.dll
-rw-r--r-- 1 radarr dietpi    32368 Jul  6 14:51 System.ServiceProcess.ServiceCo        ntroller.dll
-rw-r--r-- 1 radarr dietpi    16536 Jul  6 14:51 System.ServiceProcess.dll
-rw-r--r-- 1 radarr dietpi   896112 Jul  6 14:51 System.Text.Encoding.CodePages.        dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Text.Encoding.Extensions        .dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Text.Encoding.dll
-rw-r--r-- 1 radarr dietpi   144536 Jul  6 14:51 System.Text.Encodings.Web.dll
-rw-r--r-- 1 radarr dietpi  1704560 Jul  6 14:51 System.Text.Json.dll
-rw-r--r-- 1 radarr dietpi   141424 Jul  6 14:51 System.Threading.Channels.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Threading.Overlapped.dll
-rw-r--r-- 1 radarr dietpi   578160 Jul  6 14:51 System.Threading.Tasks.Dataflow        .dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Threading.Tasks.Extensio        ns.dll
-rw-r--r-- 1 radarr dietpi   156784 Jul  6 14:51 System.Threading.Tasks.Parallel        .dll
-rw-r--r-- 1 radarr dietpi    15984 Jul  6 14:51 System.Threading.Tasks.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Threading.Thread.dll
-rw-r--r-- 1 radarr dietpi    14960 Jul  6 14:51 System.Threading.ThreadPool.dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.Threading.Timer.dll
-rw-r--r-- 1 radarr dietpi    88688 Jul  6 14:51 System.Threading.dll
-rw-r--r-- 1 radarr dietpi   395888 Jul  6 14:51 System.Transactions.Local.dll
-rw-r--r-- 1 radarr dietpi    17048 Jul  6 14:51 System.Transactions.dll
-rw-r--r-- 1 radarr dietpi    15512 Jul  6 14:51 System.ValueTuple.dll
-rw-r--r-- 1 radarr dietpi    57496 Jul  6 14:51 System.Web.HttpUtility.dll
-rw-r--r-- 1 radarr dietpi    25712 Jul  6 14:51 System.Windows.Extensions.dll
-rw-r--r-- 1 radarr dietpi    16536 Jul  6 14:51 System.Windows.dll
-rw-r--r-- 1 radarr dietpi    16512 Jul  6 14:51 System.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi    22144 Jul  6 14:51 System.Xml.ReaderWriter.dll
-rw-r--r-- 1 radarr dietpi    16536 Jul  6 14:51 System.Xml.Serialization.dll
-rw-r--r-- 1 radarr dietpi    16024 Jul  6 14:51 System.Xml.XPath.dll
-rw-r--r-- 1 radarr dietpi    16000 Jul  6 14:51 System.Xml.XmlDocument.dll
-rw-r--r-- 1 radarr dietpi    23664 Jul  6 14:51 System.Xml.dll
-rw-r--r-- 1 radarr dietpi    49776 Jul  6 14:51 System.dll
drwxr-xr-x 3 radarr dietpi     4096 Jul  6 14:53 UI
drwxr-xr-x 2 radarr dietpi     4096 Jul  6 14:52 de-DE
-rw-r--r-- 1 radarr dietpi 12371800 Jul  6 14:51 ffprobe
-rw-r--r-- 1 radarr dietpi   199280 Jul  6 14:51 libSystem.Globalization.Native.        so
-rw-r--r-- 1 radarr dietpi   854464 Jul  6 14:51 libSystem.IO.Compression.Native        .so
-rw-r--r-- 1 radarr dietpi   198944 Jul  6 14:51 libSystem.Native.so
-rw-r--r-- 1 radarr dietpi   198960 Jul  6 14:51 libSystem.Security.Cryptography        .Native.OpenSsl.so
-rw-r--r-- 1 radarr dietpi  2433384 Jul  6 14:51 libclrjit.so
-rw-r--r-- 1 radarr dietpi   858808 Jul  6 14:51 libcoreclrtraceptprovider.so
-rw-r--r-- 1 radarr dietpi   791616 Jul  6 14:51 libdbgshim.so
-rw-r--r-- 1 radarr dietpi   461432 Jul  6 14:51 libhostfxr.so
-rw-r--r-- 1 radarr dietpi   461448 Jul  6 14:51 libhostpolicy.so
-rw-r--r-- 1 radarr dietpi  2589248 Jul  6 14:51 libmscordaccore.so
-rw-r--r-- 1 radarr dietpi  1774960 Jul  6 14:51 libmscordbi.so
-rw-r--r-- 1 radarr dietpi    57456 Jul  6 14:51 mscorlib.dll
Radarr is missing execution permissions. Try following
chmod +x /opt/radarr/Radarr
Check journalctl -u radarr afterwards.
Done, file now shows
-rwxr-xr-x 1 radarr dietpi 200416 Jul 6 14:51 Radarr
Journalctl still shows
Aug 02 10:17:42 DomDietPi systemd[632]: radarr.service:
are you sure this is an actual time stamp? Because the error now is from Aug 02 10:17:42 while you reported the permission issue 5h ago at Aug 02 10:06:07. Can you reboot your system and check again.
