Radarr not starting
Hello everyone
My radarr has not been working for a while now. Can someone please help?
Thanks.
ps: I can try a fresh install but not sure how to save the existing data/ profile.
│ ● radarr.service - Radarr (DietPi)        │
│      Loaded: loaded (/etc/systemd/system/radarr.service; enabled; vendor preset: enabled)                            │
│     Drop-In: /etc/systemd/system/radarr.service.d        │
│              └─dietpi-services_edit.conf        │
│      Active: failed (Result: exit-code) since Wed 2024-11-27 22:06:03 AEDT; 1s ago                                   │
│     Process: 172136 ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr (code=exited,          │
│ status=154)        │
│    Main PID: 172136 (code=exited, status=154)        │
│         CPU: 113ms
you would need to check logs
journalctl -u radarr.service
root@DietPi:~# journalctl -u radarr.service
-- Journal begins at Mon 2024-11-25 15:20:33 AEDT, ends at Wed 2024-11-27 23:12:36 AEDT. --
Nov 27 22:06:02 DietPi systemd[1]: Started Radarr (DietPi).
Nov 27 22:06:02 DietPi Radarr[172118]: The application to execute does not exist: '/opt/radarr/Radarr.dll'.
Nov 27 22:06:02 DietPi systemd[1]: radarr.service: Main process exited, code=exited, status=154/n/a
Nov 27 22:06:02 DietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Nov 27 22:06:02 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 1.
Nov 27 22:06:02 DietPi systemd[1]: Stopped Radarr (DietPi).
Nov 27 22:06:02 DietPi Radarr[172121]: The application to execute does not exist: '/opt/radarr/Radarr.dll'.
Nov 27 22:06:02 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 2.
Nov 27 22:06:02 DietPi Radarr[172134]: The application to execute does not exist: '/opt/radarr/Radarr.dll'.
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 3.
Nov 27 22:06:03 DietPi systemd[1]: Stopped Radarr (DietPi).
Nov 27 22:06:03 DietPi systemd[1]: Started Radarr (DietPi).
Nov 27 22:06:03 DietPi Radarr[172135]: The application to execute does not exist: '/opt/radarr/Radarr.dll'.
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Main process exited, code=exited, status=154/n/a
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 4.
Nov 27 22:06:03 DietPi Radarr[172136]: The application to execute does not exist: '/opt/radarr/Radarr.dll'.
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 5.
Nov 27 22:06:03 DietPi systemd[1]: radarr.service: Start request repeated too quickly.
Nov 27 22:06:03 DietPi systemd[1]: Failed to start Radarr (DietPi).
can you check content of Radarr directory
ls -la /opt/radarr/
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
 DietPi v9.8.0 : 01:01 - Thu 11/28/24
 - Device model : RPi 4 Model B (aarch64)
 - CPU temp : 37 °C / 98 °F : Cool runnings
 - LAN IP : 192.168.1.3 (eth0)
 - MOTD : DietPi v9.8 is here. Check out all changes:
          https://dietpi.com/docs/releases/v9_8/
 DietPi Team     : https://github.com/MichaIng/DietPi#the-dietpi-project-team
 Patreon Legends : Chris Gelatt, ADSB.im
 Website         : https://dietpi.com/ | https://twitter.com/DietPi_
 Contribute      : https://dietpi.com/contribute.html
 Web Hosting by  : https://myvirtualserver.com
 dietpi-config   : Feature rich configuration tool for your device
 htop            : Resource monitor
 cpu             : Shows CPU information and stats
root@DietPi:~# ls -la /opt/radarr
total 27976
drwxr-xr-x 2 radarr dietpi    32768 Oct 15 16:25 .
drwxr-xr-x 4 root   root       4096 Jul  2 10:29 ..
-rw-rw-r-- 1 radarr dietpi   167424 Sep 25 15:57 Dynamitey.dll
-rw-rw-r-- 1 radarr dietpi     9216 Sep 25 15:57 FluentMigrator.Extensions.SqlAnywhere.dll-rw-rw-r-- 1 radarr dietpi    46592 Sep 25 15:57 FluentMigrator.Runner.Postgres.dll
-rw-rw-r-- 1 radarr dietpi    37376 Sep 25 15:57 FluentMigrator.Runner.SqlAnywhere.dll
-rw-rw-r-- 1 radarr dietpi    20480 Sep 25 15:57 FluentMigrator.Runner.SqlServerCe.dll
-rw-rw-r-- 1 radarr dietpi   113312 Sep 25 15:57 Microsoft.AspNetCore.Antiforgery.dll
-rw-rw-r-- 1 radarr dietpi    58528 Sep 25 15:57 Microsoft.AspNetCore.Authentication.Abstractions.dll
-rw-rw-r-- 1 radarr dietpi   161952 Sep 25 15:57 Microsoft.AspNetCore.Authentication.dll
-rw-rw-r-- 1 radarr dietpi   631968 Sep 25 15:57 Microsoft.AspNetCore.Components.dll
-rw-rw-r-- 1 radarr dietpi    23320 Sep 25 15:57 Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
-rw-rw-r-- 1 radarr dietpi    44192 Sep 25 15:57 Microsoft.AspNetCore.DataProtection.Abstractions.dll
-rw-rw-r-- 1 radarr dietpi   433312 Sep 25 15:57 Microsoft.AspNetCore.Diagnostics.dll
-rw-rw-r-- 1 radarr dietpi    39072 Sep 25 15:57 Microsoft.AspNetCore.HostFiltering.dll
-rw-rw-r-- 1 radarr dietpi   426672 Sep 25 15:57 Microsoft.AspNetCore.Hosting.dll
-rw-rw-r-- 1 radarr dietpi   523016 Sep 25 15:57 Microsoft.AspNetCore.Mvc.RazorPages.dll
-rw-rw-r-- 1 radarr dietpi   839448 Sep 25 15:57 Microsoft.AspNetCore.Routing.dll
-rw-rw-r-- 1 radarr dietpi   641800 Sep 25 15:57 Microsoft.AspNetCore.Server.HttpSys.dll
-rw-rw-r-- 1 radarr dietpi   169224 Sep 25 15:57 Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
-rw-rw-r-- 1 radarr dietpi   446728 Sep 25 15:57 Microsoft.AspNetCore.SignalR.Core.dll
-rw-rw-r-- 1 radarr dietpi   170272 Sep 25 15:57 Microsoft.AspNetCore.StaticFiles.dll
-rw-rw-r-- 1 radarr dietpi   116384 Sep 25 15:57 Microsoft.AspNetCore.dll
-rw-rw-r-- 1 radarr dietpi   953008 Sep 25 15:57 Microsoft.CSharp.dll
-rw-rw-r-- 1 radarr dietpi    25760 Sep 25 15:57 Microsoft.Extensions.Configuration.EnvironmentVariables.dll
-rw-rw-r-- 1 radarr dietpi    36512 Sep 25 15:57 Microsoft.Extensions.Configuration.Ini.dll
-rw-rw-r-- 1 radarr dietpi    37536 Sep 25 15:57 Microsoft.Extensions.Configuration.UserSecrets.dll
-rw-rw-r-- 1 radarr dietpi   104096 Sep 25 15:57 Microsoft.Extensions.FileSystemGlobbing.dll
-rw-rw-r-- 1 radarr dietpi    24336 Sep 25 15:57 Microsoft.Extensions.Localization.Abstractions.dll
-rw-rw-r-- 1 radarr dietpi    39696 Sep 25 15:57 Microsoft.Extensions.Logging.EventLog.dll-rw-rw-r-- 1 radarr dietpi    34992 Sep 25 15:57 Microsoft.Extensions.Options.ConfigurationExtensions.dll
-rw-rw-r-- 1 radarr dietpi    33544 Sep 25 15:57 Microsoft.Extensions.WebEncoders.dll
total 27976
-rw-rw-r-- 1 radarr dietpi    58528 Sep 25 15:57 Microsoft.AspNetCore.Authentication.Abstractions.dll        -rw-rw-r-- 1 radarr dietpi   161952 Sep 25 15:57 Microsoft.AspNetCore.Authentication.dll
-rw-rw-r-- 1 radarr dietpi   104096 Sep 25 15:57 Microsoft.Extensions.FileSystemGlobbing.dll        -rw-rw-r-- 1 radarr dietpi    24336 Sep 25 15:57 Microsoft.Extensions.Localization.Abstractions.dll
-rw-rw-r-- 1 radarr dietpi  1310664 Sep 25 15:57 Microsoft.Identity.Client.dll
-rw-rw-r-- 1 radarr dietpi   498176 Sep 25 15:57 NodaTime.dll
-rwxr-xr-x 1 radarr dietpi   200424 Sep 25 15:57 Radarr
-rw-rw-r-- 1 radarr dietpi   262144 Sep 25 15:57 Radarr.Common.dll
-rw-rw-r-- 1 radarr dietpi  2356224 Sep 25 15:57 Radarr.Core.dll
-rw-rw-r-- 1 radarr dietpi      136 Sep 25 15:57 Radarr.Host.xml
-rw-rw-r-- 1 radarr dietpi    35156 Sep 25 15:57 Radarr.Mono.pdb                          -rw-rw-r-- 1 radarr dietpi      136 Sep 25 15:57 Radarr.Mono.xml
-rw-rw-r-- 1 radarr dietpi      139 Sep 25 15:57 Radarr.SignalR.xml
-rw-rw-r-- 1 radarr dietpi    15520 Sep 25 15:57 System.AppContext.dll
-rw-rw-r-- 1 radarr dietpi   310544 Sep 25 15:57 System.Collections.dll
-rw-rw-r-- 1 radarr dietpi    17672 Sep 25 15:57 System.ComponentModel.DataAnnotations.dll-rw-rw-r-- 1 radarr dietpi    86688 Sep 25 15:57 System.ComponentModel.Primitives.dll
-rw-rw-r-- 1 radarr dietpi    19208 Sep 25 15:57 System.ComponentModel.dll
-rw-rw-r-- 1 radarr dietpi    25760 Sep 25 15:57 System.Data.dll
-rw-rw-r-- 1 radarr dietpi    62112 Sep 25 15:57 System.Diagnostics.EventLog.dll
-rw-rw-r-- 1 radarr dietpi    37536 Sep 25 15:57 System.Diagnostics.StackTrace.dll
-rw-rw-r-- 1 radarr dietpi   139424 Sep 25 15:57 System.Drawing.Primitives.dll
-rw-rw-r-- 1 radarr dietpi    21152 Sep 25 15:57 System.Drawing.dll
-rw-rw-r-- 1 radarr dietpi    16152 Sep 25 15:57 System.IO.Compression.FileSystem.dll
-rw-rw-r-- 1 radarr dietpi   306968 Sep 25 15:57 System.IO.Compression.dll
-rw-rw-r-- 1 radarr dietpi    86808 Sep 25 15:57 System.IO.FileSystem.DriveInfo.dll
-rw-rw-r-- 1 radarr dietpi   108304 Sep 25 15:57 System.IO.FileSystem.Watcher.dll
-rw-rw-r-- 1 radarr dietpi    90888 Sep 25 15:57 System.IO.IsolatedStorage.dll
-rw-rw-r-- 1 radarr dietpi   143624 Sep 25 15:57 System.IO.Pipes.dll
-rw-rw-r-- 1 radarr dietpi   278792 Sep 25 15:57 System.Linq.Queryable.dll
-rw-rw-r-- 1 radarr dietpi   199432 Sep 25 15:57 System.Memory.dll
-rw-rw-r-- 1 radarr dietpi   336136 Sep 25 15:57 System.Net.Quic.dll
-rw-rw-r-- 1 radarr dietpi    84752 Sep 25 15:57 System.Net.WebSockets.Client.dll
-rw-rw-r-- 1 radarr dietpi    16032 Sep 25 15:57 System.Numerics.dll
-rw-rw-r-- 1 radarr dietpi    71952 Sep 25 15:57 System.Reflection.DispatchProxy.dll
-rw-rw-r-- 1 radarr dietpi    16656 Sep 25 15:57 System.Reflection.dll
-rw-rw-r-- 1 radarr dietpi    31496 Sep 25 15:57 System.Runtime.InteropServices.RuntimeInformation.dll
-rw-rw-r-- 1 radarr dietpi    30488 Sep 25 15:57 System.Runtime.Serialization.Primitives.dll
-rw-rw-r-- 1 radarr dietpi   104208 Sep 25 15:57 System.Security.Claims.dll
-rw-rw-r-- 1 radarr dietpi   113928 Sep 25 15:57 System.Security.Cryptography.Encoding.dll-rw-rw-r-- 1 radarr dietpi    20592 Sep 25 15:57 System.Security.Cryptography.ProtectedData.dll
-rw-rw-r-- 1 radarr dietpi    16136 Sep 25 15:57 System.Text.Encoding.dll
-rw-rw-r-- 1 radarr dietpi   142600 Sep 25 15:57 System.Threading.Channels.dll
-rw-rw-r-- 1 radarr dietpi    17056 Sep 25 15:57 System.Transactions.dll
-rw-rw-r-- 1 radarr dietpi    57616 Sep 25 15:57 System.Web.HttpUtility.dll
-rw-rw-r-- 1 radarr dietpi    16560 Sep 25 15:57 System.Xml.Linq.dll
-rw-rw-r-- 1 radarr dietpi    16544 Sep 25 15:57 System.Xml.Serialization.dll
-rw-rw-r-- 1 radarr dietpi   199424 Sep 25 15:57 createdump
-rwxr-xr-x 1 radarr dietpi 12434136 Sep 25 15:57 ffprobe
-rw-rw-r-- 1 radarr dietpi   312464 Sep 25 15:57 libMonoPosixHelper.so
-rw-rw-r-- 1 radarr dietpi   198944 Sep 25 15:57 libSystem.Native.so
-rw-rw-r-- 1 radarr dietpi   198968 Sep 25 15:57 libSystem.Security.Cryptography.Native.OpenSsl.so
-rw-rw-r-- 1 radarr dietpi   858808 Sep 25 15:57 libcoreclrtraceptprovider.so
-rw-rw-r-- 1 radarr dietpi   101536 Sep 25 15:57 netstandard.dll
ok some files seems to be missing, let’s try to reinstall
systemctl stop radarr
rm -Rf /opt/radarr
dietpi-software reinstall 145
Thanks a lot mate. Issue is resolved :slightly_smiling_face:
